Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
Drives: Fr-s
IRP shifter issue
I could just be my bad luck but it can't hurt to check yours.
I bought one of these used and upon receiving it I noticed the shift lever was really loose on the longitudinal pivot(that allows the shifter to move left to right). I took it apart, cleaned it all up and put it back together again. That when i noticed that despite tightening down the lock nut on the longitudinal bolt it was still easy to loosen up. Since there is nothing "locking" the bolt down it's free to back out, after use I'm sure it would loosen up again. What I found is that the thread for the lock nut was not machined far enough, so it wasn't actually holding anything tight (like the bolt from backing out). A picture is worth a thousand words. ![]() It's not like the bolt would fall out since, at some point it would back up against the lock nut, but if your shifter feels sloppy now you know why. ![]()
The Following User Says Thank You to redlined600 For This Useful Post: | humfrz (12-03-2017) |
#2 |
What do you expect for $500 ...... something well made .......??
![]() humfrz |
#3 |
[insert cool phrase here]
Drives: BRZ Premium
Hope you have a lifetime warranty on that perfect example of a manufacturer defect.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#4 |
Drives: GTS 86
Send the picture to them. I am sure they will be able to replace it.
#5 | |
Drives: Fr-s
They don't owe me anything as I bought it used. It's a easy fix regardless, but as stated above a clear manufacturing mistake.
#6 | |
Drives: GTS 86
I reckon you should still send them an email with the picture, to see what they can do for you. Maybe send a replacement bolt or something along those lines. |
The Following User Says Thank You to Hawk77FT For This Useful Post: | redlined600 (12-03-2017) |
#7 |
#8 | ||
Drives: Fr-s
I'm sure it will be all good once I fix the bolt.
#9 | |
Drives: GTS 86
The Following User Says Thank You to Hawk77FT For This Useful Post: | FirstWinter (12-07-2017) |
#10 |
Drives: Fr-s
As a follow up to this post, IRP sent me a new bolt. I didn't ask for anything and they certainly didn't owe me a thing yet still went out of their way to ship me a new bolt. Pretty awesome of them.
#11 |
how hard was it to install lol? I have been thinking about it and read the DIY but it still seems like a PITA.
#12 |
That should be standard, but then again not every manufacturer stands by their product. Vmoda fixed my headphones under warranty and all I did was ship it to them. I have the sneaking suspicion Astro would not do the same. No matter because I have since learned that "gaming" headphones are shite compared to ones made for listening to music, yet they cost the same. Regardless, if a company treats you right I'd stick with them. I'm still leery about this particular shifter because it seems like a rattle machine. My car is 2 years old and already has enough rattles that I didn't introduce myself
#13 |
Drives: Slow
Can I get an update from IRP owners regarding the rattle? I'm in the market for one and I really like the IRP short shifter but not if it rattles. With the "fix" from IRP, is the rattle completely gone?
#14 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
forks in shifter issue | Flame9020 | Issues | Warranty | Recalls / TSB | 16 | 02-18-2017 03:42 PM |
shifter issue | srgssgtmatt | Issues | Warranty | Recalls / TSB | 5 | 09-15-2016 02:01 PM |
Short shifter clearance issue with driveshaft | Gank61 | Engine, Exhaust, Transmission | 16 | 03-08-2016 06:48 AM |
shifter issue? | abutterman | Issues | Warranty | Recalls / TSB | 54 | 02-26-2014 05:10 PM |
Issue with Kartboy short shifter | tisb0b | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 10-20-2013 06:15 AM |
