Don't forget HKS.
A subtle improvement on the low-end... engine seems to be running a bit smoother -- noticed this "at idle" and when working through 1st to 2nd gear. My comparison point is what I've been keeping track of over the last 3 weeks since I took delivery. A somewhat "stumbling idle" and what I would characterize as some carry-over of that as revs build were on my list of things to address with dealer at 1st service. After this morning's commute... maybe not. Maybe there is some "placebo effect" coming into play (i.e, maybe I WANT it to be better) but I'm hoping that I'm being pretty objective. Taking a slow approach to modding.. considering a silicone intake tube next... and then a Nameless Offset Axleback exhaust. Commentary: I LOVE driving this car... haven't had this much fun driving in a long time! And the fact that it didn't cost an arm & two legs is just gravy! |
glad you like it :thumbsup:
These cars are now a days so well tuned that the engine couldn't really use any more air than it gets from OEM filter. Unless you are competing, there is no real need... |
It may not necessarily need the extra air before a tune but if you want a stage 2 tune intake upgrade is recommended. The engine can definitely take advantage of more air flow if the F/A ratio is tweaked. Yes at stock you probably won't gain a lot but really how much do you expect for a $40-$50 upgrade and unless you get an intake with a sensor tricker like AEM a tune is necessary to take maximum advantage of the difference. IMO it's worth it also i wouldn't take a brand new oiled filter to the track without breaking it in and it is always a good idea to blot an oiled filter out of the bag because it can start a bit juicy.
@Jacob G. I want to thank you for the useful suggestion of blotting a new oiled filter just out of the bag. I have always had to oil my own before. When I get a DIF, I will heed your advice. [I would have pressed the THANKS button but I don't get one until I have 10 posts???????]
Or not use an oiled filter ... And why would you, when you have so many other options? Why risk doing the damage when you don't have to...?
For a stock car, do you seriously think when Toyota could benefit from the marketing aspects of advertising more Hp for the car, with a $20 part (mfr cost, or maybe less), that they would try to save the extra $5 and forego the Hp gain, when they can obviously could use it for marketing purposes. Especially if its as easy as implied! Now if you are turbo'ing or SC'ing and you need more air, then That's a different story. True, for $50, I don't expect anything, but then if I don't expect anything why would I do it?? |
One of the guys at the evasive dyno meet today, only mod is a drop in apexi air filter and Perrin engine pulley.. He dyno at 171.. I put 175 with a injen intake, greddy evo 3 exhaust and Perrin engine pulley.. We was all just as shocked
Keep in mind, other threads have shown (proven?) that you can easily do back to back dyno runs and see more than a few hp difference. Especially if you reset the ecu, or if you are looking at a hp chart provided by the seller of said product (as above). Point being, more than a very minor hp gain is not going to happen on this car. Last thing: There was no increase in hp when there was no filter at all, I dont understand how a filter could possibly make hp.
Having said that I have used a K&N in the past, largely out of curiosity and just for fun, and yes, my car felt faster. |
Cosworth filter here... 100% synthetic media... NO oil.
High flow. |
I'd be very curious to see one of the "members" posting a before and after Dyno run with just a filter, and no other mods? And not posting the worst before run and the best after run for comparisons.
Also, if the OEM filter Dyno run would be the last run, and not the first run. First couple of runs typically warm up the engine and are really not suitable to set standard of measure. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
