Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Search Forums
Showing results 1 to 30 of 486
Search took 0.47 seconds.
Search: Posts Made By: 1Cor10:23
Forum: Engine, Exhaust, Transmission 09-12-2018, 03:09 PM
Posted By mrg666
I would make sure that o-ring stays in place...
I would make sure that o-ring stays in place while pushing the MAF sensor. MAF sensor should sit flush. Sometimes the o-ring does not stay in its groove while pushing the MAF sensor in place. You can...
Forum: Engine, Exhaust, Transmission 08-28-2018, 08:54 AM
Posted By Trueweltall
https://www.amazon.com/dp/B005RUR0F6/ref=biss_dp_t...
https://www.amazon.com/dp/B005RUR0F6/ref=biss_dp_t_asn
Forum: Engine, Exhaust, Transmission 08-27-2018, 05:20 PM
Posted By CSG Mike
Part number ;) Anything that fits the specs...
Part number ;)
Anything that fits the specs will work.
Buna-Nitrile
22 mm ID
26 mm OD
2 mm Width
Forum: Engine Swaps 05-27-2018, 10:01 AM
Posted By ILLSMOQ
Basically it replaces the engine harness from the...
Basically it replaces the engine harness from the two main connectors down. The rest of the harness that feeds into the engine bay remains. I weather proofed the loose connectors and tucked them...
Forum: Engine Swaps 02-20-2018, 03:25 PM
Posted By Sportsguy83
There's no way to fit the massive (compared to...
There's no way to fit the massive (compared to stock trans) T56/TR6060 on there without hammering, unless you do like someone who actually cut up and installed a brand new, wider tunnel in there.
Forum: Engine Swaps 02-20-2018, 02:39 PM
Posted By DustinS
Yes it is required in a few spots. You also have...
Yes it is required in a few spots. You also have to cut a bit more out that they don't show.
Forum: Suspension | Chassis | Brakes -- Sponsored by 949 Racing 05-18-2017, 04:18 PM
I think 7 kg/mm front and 8 rear would be a great...
I think 7 kg/mm front and 8 rear would be a great set up for you. We can set you up if want, send me a PM. Just put together an Ohlins spring package for someone else.
- Andrew
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 07-20-2016, 11:41 AM
Posted By VerusEric
It's not completely rigid nor can the required...
It's not completely rigid nor can the required diameter mount to fit through everything have the capacity to hold the downforce we're looking at.
Forum: Tracking / Autocross / HPDE / Drifting 07-12-2016, 10:45 AM
Posted By Chico
Yes! I installed the AP kit in the spring and the...
Yes! I installed the AP kit in the spring and the last two times at the track I've noticed a loud clicking noise when turning left or right. Haven't heard it street driving. I just assumed it was the...
Forum: Tracking / Autocross / HPDE / Drifting 07-11-2016, 04:11 PM
Posted By DocWalt
If they turned it equally on both sides, don't...
If they turned it equally on both sides, don't worry about it.
Forum: Engine, Exhaust, Transmission 06-28-2016, 04:49 PM
Posted By Phantobe
The flange had a lip so if I recall correctly you...
The flange had a lip so if I recall correctly you couldn't use a wrench on the nut (clearance issue), I think I had to use a swivel head & ratchet. So just make sure you have some sockets & ratchets....
Forum: CANADA 06-15-2016, 12:41 PM
Posted By wparsons
Thanks! He's already had a bit of seat time in a...
Thanks! He's already had a bit of seat time in a race car :D
https://scontent-iad3-1.xx.fbcdn.net/t31.0-8/13308481_10153529752721837_3364600961361282962_o.jpg
Forum: CANADA 06-15-2016, 11:10 AM
Posted By wparsons
Ha! Haven't even copied them off the memory card...
Ha! Haven't even copied them off the memory card yet. Hoping I can get them copied over, edited and uploaded on the weekend, along with the video/data overlay.
I was always slow with getting...
Forum: CANADA 06-13-2016, 09:43 PM
Posted By Skurj
Looks like you guys got faster as the day went...
Looks like you guys got faster as the day went on, I plateau'd about midday. Was a great day, great weather, and i look forward to the rest this year being as nice!
I am sure there is more time...
Forum: CANADA 06-13-2016, 04:08 PM
Posted By wparsons
Carsten is wicked fast (M3), he won the shootout...
Carsten is wicked fast (M3), he won the shootout last year!
Here's the results from Event 1, which had both kinks:
http://www.casc.on.ca/sites/default/files/2015_event_1_results.pdf
Event 2...
Forum: CANADA 06-13-2016, 03:05 PM
Posted By wparsons
FRS/BRZ's start out in GT4 bone stock, depending...
FRS/BRZ's start out in GT4 bone stock, depending on mods they move up classes.
You can post (or PM) a mod list and I can roughly place it, or you can also run through the classification site...
Forum: CANADA 06-08-2016, 07:19 AM
Posted By wparsons
The schedule is basically the same as it has been...
The schedule is basically the same as it has been for the last couple years. It's like this due to three reasons...
1) It ensures we aren't over working volunteers and keeps them coming back
2)...
Forum: CANADA 06-07-2016, 10:30 PM
Posted By sergiomordo
I will be there, couldn't get my camber plates in...
I will be there, couldn't get my camber plates in on time so car won't be perfect :/ Bunch of my friends and coworkers are coming as well :)
Forum: Canada Classifieds 05-29-2016, 02:24 PM
Posted By drewbot
I'm going to save you from the other posters: ...
This is the CANADA classifieds. Naturally, the prices in the threads will be in CANADIAN dollars.
$750 CAD ~ $575 USD
Forum: Canada Classifieds 05-26-2016, 09:18 PM
Posted By Trac Toy
Some one sell this man a trunk lid!
Forum: Engine, Exhaust, Transmission 05-19-2016, 09:20 PM
Posted By brianhj
M8 x 1.25
M8 x 1.25
Forum: Canada Classifieds 05-17-2016, 06:57 PM
Posted By Trac Toy
Mosty interested cause I didn't have to give up...
Mosty interested cause I didn't have to give up my trunk.
Forum: Canada Classifieds 05-13-2016, 12:29 PM
Posted By Lynxis
That is exactly the wing I want but your trunk is...
That is exactly the wing I want but your trunk is the wrong colour and I don't have the money anyway. GLWS!
Forum: Canada Classifieds 05-12-2016, 08:27 PM
Posted By Trac Toy
Are you saying your looking for a trunk trade or...
Are you saying your looking for a trunk trade or just looking to sell the wing and trunk as a whole?
Forum: Canada Classifieds 05-08-2016, 11:24 PM
Posted By Dango1
FS: Rocket Bunny v1 spoiler with trunk.
Well known and loved spoiler. I had my fun and now going back to street mode so giving up my big wang. Comes already installed on a wrb trunk so it's and easy swap.
Price: $2,200 obo.
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 04-26-2016, 04:06 PM
Posted By continuecrushing
pretty sure the q300 fits just fine
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 04-07-2016, 10:36 AM
Posted By VerusEric
This was likely a quick install for pictures or...
This was likely a quick install for pictures or something of that nature. I know a few guys running around on just the front two and rear two mounts, but we wouldn't suggest it.
I cannot find...
Forum: Canada Classifieds 04-02-2016, 09:00 PM
Posted By infinity21
I can attest that Cor measured a few dozen times...
I can attest that Cor measured a few dozen times before drilling so that wing is pretty darn straight :lol:
Forum: Cosmetic Modification (Interior/Exterior/Lighting) 03-29-2016, 02:05 PM
Posted By VerusEric
We will look into this. There is an inherit flaw...
We will look into this. There is an inherit flaw with the toe hook mount that was overlooked previously. However there may be a way around this, we will look into it and test.
Forum: Canada Classifieds 03-28-2016, 09:17 PM
Posted By puma
this guy is selling one ...
http://www.quebecfrs.com/forums/a-vendre-(prive)/valise-en-carbone-vis-greddy-rb-replica-front-lip/
