follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 30 of 59
Search took
0.01
seconds.
Search:
Posts Made By:
Sithspawn
Forum:
Engine, Exhaust, Transmission
02-14-2016, 01:19 PM
35
GCS Automatic Paddle Shifter Extensions
14,103
Posted By
Sithspawn
A buddy of mine in Taiwan had a few friends get...
A buddy of mine in Taiwan had a few friends get these and they were pissed that the set screws damaged the factory paddles. The set screws are really small diameter and in order to apply sufficient...
Forum:
Issues | Warranty | Recalls / TSB
11-06-2014, 07:01 PM
2
Dead Pixel?
1,509
Posted By
Sithspawn
Yeah, my radio had a whole dead line going across...
Yeah, my radio had a whole dead line going across it. Got it replaced under warranty, no issue.
Forum:
10-26-2014, 03:12 PM
177
Automatic Transmission Fluid Cooler. ??
73,137
Posted By
Sithspawn
My pleasure. It is uncommon for anyone to do...
My pleasure. It is uncommon for anyone to do this level of research and data logging, much less share the data. Even the company I used to work for didn't bother, but boy did they sell a lot of...
Forum:
10-26-2014, 12:32 AM
177
73,137
Posted By
Sithspawn
I wouldn't recommend removing the factory heat...
I wouldn't recommend removing the factory heat exchanger from the system. You want the fluid to come up to temperature since viscosity changes with temperature. You may have noticed that the car...
Forum:
10-11-2014, 04:37 PM
177
73,137
Posted By
Sithspawn
Not really. Besides, I only have about 25%...
Not really. Besides, I only have about 25% Redline and 75% OEM fill.
Forum:
10-10-2014, 09:06 PM
177
73,137
Posted By
Sithspawn
Considering that you have the WS fluid already,...
Considering that you have the WS fluid already, I'd just go ahead and use that. I'm not a chemist, but as an engineer, if the fluid meets the specifications for the application, it is fine. Redline...
Forum:
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
10-09-2014, 07:31 PM
45
AT Fluid Change?
14,983
Posted By
Sithspawn
Update: We tested out the airflow modifications...
Update: We tested out the airflow modifications at the track on Tuesday night and we are exactly where we want to be: temps peaked out at 221 degrees Fahrenheit at the end of the last...
Forum:
10-09-2014, 07:28 PM
177
73,137
Posted By
Sithspawn
Actually, I added Redline D6 transmission fluid...
Actually, I added Redline D6 transmission fluid to replace the fluid that was lost when I took my sample for analysis and when splicing in the cooler lines as well as making up for the additional...
Forum:
10-09-2014, 02:13 AM
177
73,137
Posted By
Sithspawn
It was good to meet you last night. I ended up...
It was good to meet you last night. I ended up running a personal best on that track last night (beating out my old personal best held by my WRX with 330hp and a good bit of suspension work). These...
Forum:
10-08-2014, 08:37 PM
177
73,137
Posted By
Sithspawn
Update: We tested out the airflow modifications at the track last night and we are exactly where we want to be: temps peaked out at 221 degrees Fahrenheit at the end of the last session...after we...
Forum:
10-04-2014, 08:18 PM
177
73,137
Posted By
Sithspawn
Yeah, we used brass fittings for our connections....
Yeah, we used brass fittings for our connections. I also noticed that you are using worm clamps with braided stainless lines. Not really the best way to do that. You are supposed to use the...
Forum:
Member's Car Journals
10-02-2014, 04:10 PM
419
Tye300's 86
219,084
Posted By
Sithspawn
Thank you for your honest and unbiased review. I...
Thank you for your honest and unbiased review. I would like to take the opportunity to correct the issues you describe and send you a new pair of paddles. I strive to produce the best parts that I...
Forum:
Cosmetic Modification (Interior/Exterior/Lighting)
10-02-2014, 03:13 PM
16
Stark Performance Paddle Shifter Extensions Install and Review
10,994
Posted By
Sithspawn
Forum:
10-01-2014, 07:53 PM
177
73,137
Posted By
Sithspawn
Hey guys, I did not make it out to the track last...
Hey guys, I did not make it out to the track last night due to a few different factors. We'll just have to do it next week.
In the meantime, here are the pictures requested for the airflow...
Forum:
09-28-2014, 12:24 AM
177
73,137
Posted By
Sithspawn
We went with a Setrab Series 6 19row oil cooler. ...
For R&D purposes, we put one pair of sensors (temp and pressure) in the transmission line going to the factory cooler and one pair of sensors...
Forum:
09-21-2014, 02:10 AM
177
73,137
Posted By
Sithspawn
I got the transmission cooler hooked up, but...
I got the transmission cooler hooked up, but didn't get much opportunity to put it through its paces yet. So far, steady state driving shows the temps are quite a bit lower than stock (I didn't have...
Forum:
09-12-2014, 09:55 PM
45
AT Fluid Change?
14,983
Posted By
Sithspawn
Update: I got a chance to do a mountain run...
Update: I got a chance to do a mountain run today, but there were quite a few people going up the mountain so I didn't really get much of a chance to do a lot of spirited driving. For the short...
Forum:
09-12-2014, 09:52 PM
177
73,137
Posted By
Sithspawn
Forum:
09-11-2014, 05:10 PM
26
Gas Leak?
17,488
Posted By
Sithspawn
roflmao!
roflmao!
Forum:
09-11-2014, 01:47 AM
44
AT Paddle Shift Extensions look pretty sick
18,943
Posted By
Sithspawn
Let's see here. So you are saying that if...
Let's see here. So you are saying that if someone shelled out $15k for aluminum injection molds and the per unit cost is say $5 (not including packaging, adhesive, etc.) and retail is $35, how many...
Forum:
09-10-2014, 03:41 AM
45
AT Fluid Change?
14,983
Posted By
Sithspawn
Update: I did not get a chance to do the mountain...
Update: I did not get a chance to do the mountain run, but I did take the car to the track as well as some street driving and highway cruise. Also, the highest pressures logged were 13psi. It seems...
Forum:
09-10-2014, 03:40 AM
177
73,137
Posted By
Sithspawn
Forum:
09-09-2014, 03:22 PM
45
AT Fluid Change?
14,983
Posted By
Sithspawn
Update: I got the Innovate gauges installed and...
Update: I got the Innovate gauges installed and got everything to steady state at idle last night. Here's what I've discovered so far. The factory lines running to and from the factory cooler are...
Forum:
09-09-2014, 03:21 PM
177
73,137
Posted By
Sithspawn
Forum:
09-04-2014, 01:58 PM
177
73,137
Posted By
Sithspawn
Pressure is indeed a concern that I have. That...
Pressure is indeed a concern that I have. That is why I am going to be hooking up pressure sensors to the transmission cooler lines. Now, I have read that the B&M has more pressure drop and is...
Forum:
08-30-2014, 04:54 PM
45
AT Fluid Change?
14,983
Posted By
Sithspawn
I just picked up some gauges to monitor temps and...
I just picked up some gauges to monitor temps and will be publishing the results of my testing pretty soon.
Forum:
08-30-2014, 04:32 PM
177
73,137
Posted By
Sithspawn
I'm going to be doing some R&D on this one. I...
I'm going to be doing some R&D on this one. I just picked up a pair of Innovate MTX Oil Temp/Pressure gauges to do some logging before and after installation of a trans cooler. This way, I can...
Forum:
08-12-2014, 05:56 PM
46
Manuel vs automatic transmission?
10,910
Posted By
Sithspawn
I had a manual FR-S and have driven manuals for...
I had a manual FR-S and have driven manuals for 15 years. When it came time to lemon out the old one, I test drove the auto for S's and G's and was blown away by how it performed. I have never...
Forum:
08-08-2014, 02:54 PM
48
Poll:
Interest poll for paddle shifter upgrades
16,048
Posted By
Sithspawn
How quaint...reminds me of one of these: ...
Forum:
08-08-2014, 02:23 PM
48
Poll:
16,048
Posted By
Sithspawn
Turn in Concepts just announced on Facebook that...
Turn in Concepts just announced on Facebook that they have the paddle shifter extensions in stock.
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
01:19 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
