Old 01-12-2016, 09:41 PM   #15
Originally Posted by FRSBRZGT86FAN View Post
@mav1178 has it right, nitrogen makes a difference when the tires are at temperature swings, nitrogen doesn't readily get effected by temperatures. In fact nissan made a big deal when the GT-R came out about how they filled the tires with pure nitrogen because normal air was too "unstable". It would probably only ever make a difference in that situation because they are constantly recording data on the nurburgring trying to aim for consistency with variables and such.
Many places made a big deal about it at one time but it has sort of dropped off the map since several government studies showed it is meaningless in a normal car. I am not going to bother to link any because I am perfectly aware there are probably an equal number saying that it is god's gift to tires.
What it is good for is a cheap and easy upsale for dealers and tire places or else it would be gone by now.
Old 01-12-2016, 09:49 PM   #16
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Smile
Originally Posted by roddy View Post
There is a minimum number of posts before you can thank...IIRC, it's 10.
Thanks!
mdm is offline   Reply With Quote
The Following 2 Users Say Thank You to mdm For This Useful Post:
roddy (01-13-2016), Tcoat (01-12-2016)
Old 01-12-2016, 10:08 PM   #17
ls1ac
ls1ac's Avatar
PV=NRT
all these gasses act the same in regard to expansion by temperature
the only advantage is that water that has condensed inside the tire may change to vapor at a rate of 22.4 to 1
Old 01-12-2016, 10:14 PM   #18
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Bah screw that I'm not paying to fill up on nitrogen. Two tires dont even have caps. They probably all have air anyway
RichardsFRS is offline   Reply With Quote
Old 01-12-2016, 10:18 PM   #19
dnieves
Drives: FR-S 10 Series
DO NOT use aluminum valve stem caps unless you want to Dremel them off when they seize up on you!
dnieves is offline   Reply With Quote
Old 01-13-2016, 12:35 AM   #20
Ultramaroon
fabulous
Ultramaroon's Avatar
H20 molecular bonds in the tire can be broken by temperature changes.
Then the individual 0 and H molecules take up more space than they did before.
Skeptical Dog says he would like to learn more about this miracle of chemistry.
humfrz (01-13-2016)
Old 01-13-2016, 01:28 AM   #21
humfrz
Me too.......
YIKES, does that mean that the old air in my tires contains free hydrogen ... ??
What if it ignites, will my tires blow up .....
When I let air out of my tires, should I not have an open flame in the area ... ??
Should I put fresh air in my tires every now & then .. ??
humfrz
humfrz is online now   Reply With Quote
Old 01-13-2016, 01:36 AM   #22
Ultramaroon
fabulous
Me too.......
humfrz
We could fill the tires with water and run the engine with the hydrogen and oxygen.
Old 01-13-2016, 02:02 AM   #23
humfrz
YES!
All we need is a heat source to start the thermal decomposition of the water molecules. Let's see, I wonder if the heat off of a turbocharger would reach up to 1,000 degrees C to get it started .....
We just may be onto something BIG here ......
humfrz
Old 01-13-2016, 02:17 AM   #24
Ultramaroon
fabulous
YES!
humfrz
Oh wow! You are a GENIUS! Now don't tell a soul. We don't want anyone to steal our ide...
...shit.
humfrz (01-13-2016)
Old 01-13-2016, 02:28 AM   #25
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
YES!
humfrz
No no no.... youre doing that wrong. You need to use power from the alternator to dissociate water into H & O2, then feed that into the engine , recombust it, and make more power.
No really it works...... saw it on an info-mercial - they cant lie....
And as for the Air vs Pure nitrogen:
The ONLY benefit it gives you is lack of moisture.
The difference between pure Nitrogen and and a Blend of Nitrogen 78% and Oxygen 21% (Air) is in the noise.
Nitrogen & Oxygen are right next to each other on the periodic table.
(Atomic Mass only differs by ~10%)
justatroll is offline   Reply With Quote
Old 01-13-2016, 03:29 AM   #26
humfrz
...shit.
Not to worry, they don't know about our secret catalyst
humfrz
Ultramaroon (01-13-2016)
Old 01-13-2016, 03:41 AM   #27
humfrz
Well, justatroll, electrolysis of water would produce hydrogen ....... but that's soooo old school (must have been an old info-mercial).
We are waaaaay far advanced from that .....
humfrz
Oh, BTW, we can't discover any more elements ...... because the bottom row of the periodic table is all filled up .........
Old 01-13-2016, 04:10 AM   #28
cf6mech
Drives: FRS Silver LS1 swapped.
Nitrogen is the only thing filled in commercial aircraft tires for a reason......yes its better i.e.......less effected by heat and cold cycling pressure changes....less abnormal tire wear....yes its the only thing I would put in my tires if I had the choice.....thats the catch though.....1...im not going to be seeking a dealership anytime I want tires serviced....2 Im not going to buy/rent bottles.....so pure air it is....
cf6mech is offline   Reply With Quote
Topped off coolant with Prestone radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 12-13-2015 10:14 PM
Replacement windshield with "green tint/green shade" extrashaky Scion FR-S / Toyota 86 GT86 General Forum 11 07-07-2014 12:02 PM
Anybody have a lead on custom fitted car covers and seat covers for the FR-S? Grateful Dave Cosmetic Modification (Interior/Exterior/Lighting) 17 08-27-2012 10:41 AM
CBS FRS at Green Toyota Integratedfool Great Lakes 0 06-25-2012 01:24 PM
