86WORX
Old 07-25-2012, 01:30 AM   #1429
OrbitalEllipses
Drives: Attitude
Originally Posted by Coheed View Post
recirc the wastegate back to the exhaust and it should make it very quiet.
Spool noise. Not blowoff noise, not wastegate venting. You still get that whine with aftermarket turbos, right? I remember when the GTX series came out Garrett made a big deal about them not being loud as fuck.
Old 07-25-2012, 01:53 AM   #1430
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by subatoy View Post
yes but you are taking about COMPLETELY different engines. one that is meant to be turboed and one that it's not. Also NA Boxer engines don't take mods well, only forced induction will give you some solid results.
i do agree that the location of that intake is probably the worst unless people make a hoodscoop!
How does the design parameters determine whether gains are available with a cold intake charge? Because you lost me there.
Just because Subaru NA boxer engines don't take to mods well, doesn't mean that this one won't. I bet 200whp is well within reach of the majority staying NA, and it will come easily in comparison to earlier EJ motors.
Any engine can be turbocharged. These days, they are all practically set up to do double duty. NA or turbo. The biggest differences between a turbo engine and NA is the cam profile and compression ratio. Everything else remains largely the same. My comment was about the 28whp gains the AEM intake had on the MZR engine, by minimizing high temperature at the intake before the turbo. That point is completely relevant in this case.
Coheed is offline   Reply With Quote
Old 07-25-2012, 01:57 AM   #1431
NickFRS
Drives: 2013 Asphalt FRS
I wont buy till there is a little more of a professional build out there. Waiting to see what this turns into down the road a couple months. Not saying this isn't professional but maybe you should play with different placements, different turbo's, and intercooler choices before hitting the market. This kinda just looks like a garage ebay turbo kit.
NickFRS is offline   Reply With Quote
Old 07-25-2012, 02:03 AM   #1432
Coheed
Coheed's Avatar
The disco potato is relatively quiet. It's the 6-blade turbos that are loud when spooling. The GT3076r sounds like a loud turbine jet engine winding up.
The 7-blade turbos aren't really that loud. But the 11-full-blade setup on the GTX turbos is a bit quieter.
Old 07-25-2012, 02:09 AM   #1433
Coheed
Coheed's Avatar
I thought it was well-thought out, but to each his own I guess.
I like how the setup is designed around the factory manifold. This means a cat-less manifold should bolt right in without modification at all and open up a bit more. Add a cat after the turbo instead.
The piping is stupid simple, and the install looks clean. The intercooler is a bit small, but honestly you don't need much of an intercooler with lower pressure ratios. Even a really small intercooler can flow plenty air, it just can't cool the air charge when you throw 20+psi boost. I'm running air/water intercooler setup right now and the core is way small compared to a similar a/a setup, so flow isn't the issue. Just to set an example. But a larger heat sink takes longer to heat soak...
I would powder coat the pipes with a textured black finish, use black couplers, and go with a factory looking setup. Nothing flashy at all except the nice shiny front-mount.
Old 07-25-2012, 02:20 AM   #1434
NickFRS
I've never seen a build with the Intake right on top of the engine... I wonder what the intake teps get up to when the car is in traffic or stopped at a light....
Old 07-25-2012, 03:43 AM   #1435
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by Draco-REX View Post
Move the battery to the back, turn the intake pipe 180 degrees, and box in the area. You can draw air from the fender, or from the back of the hood (high pressure area) if you trim back the weather strip. More aggressive people could cut the fender behind the fake "vent" and turn it into a real intake.
About that, I wonder how well that actually works. There should be a separation bubble where the hood breaks abruptly for the space where the windshield wipers are, but then the air hits the bottom of the windshield and stagnates or something. Seems like you would be sucking air out of the separation zone, which I'm guessing is actually at comparatively "low pressure" but I might just be talking out of my ass.
Old 07-25-2012, 05:14 AM   #1436
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
I haven't read through the whole thread, but shouldn't there be an air filter on the intake portion of the turbo? I bet it works as a good street sweeper.
TOMIMOTO is offline   Reply With Quote
Old 07-25-2012, 05:32 AM   #1437
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
There is. It sits behind the intake manifold. Look at the pics in this ginormous thread.
cobrabyte is offline   Reply With Quote
Old 07-25-2012, 05:34 AM   #1438
TOMIMOTO
TOMIMOTO's Avatar
Ahhh.... I see. I just looked at the first couple pics real quick.
Old 07-25-2012, 06:35 AM   #1439
Don@Accelerated
Don@Accelerated's Avatar
I'm sorry you feel that way, but I stand behind allowing anyone to have there own opinion.
Consider this. This is the third design of the kit. I've had 3 different turbos, 3 different placements and settled on the V Band turbine Inlet set. Intercooler choice has little impact on performance if its near the target goal. The choice for this intercooler was driven from a no cutting perspective. Its capacity is up to 350hp. There is also a 600hp intercooler I have as well for the setup, but it requires the crash bar to be modified or sent to me to be modified.
I have larger turbo's i'm currently working on testing, but they are far to large for the stock engine!
-Don
Don@Accelerated is offline   Reply With Quote
Old 07-25-2012, 06:41 AM   #1440
Don@Accelerated
The air intake could always be in a cooler placement. That is however the only place to put it without modification. I can't make people buy a hood. I can't make people cut the fender. Running it over the engine requires additional modification. For the little gain that could be had, I can't make the kit include unreasonable parts.
I can put the intake in a few other placements, but I can't expect the end user to have the type of tools required to make the modifcations possible.
If you do have the ability to make those changes, I'll sure make an available option to accomodate.
Remember this basic kit requires no cutting on the car!
The Following 2 Users Say Thank You to Don@Accelerated For This Useful Post:
BRZranger (07-25-2012), colHolm (07-25-2012)
Old 07-25-2012, 08:30 AM   #1441
swift996
swift996's Avatar
Great choice on turbo and love the look of the car too.
Question (sorry with 66 pages, I didn't look through). Have you seen any increase in the transmission temp? Have you thought about placing some thermal wrap or a heat shield to help eliminate heat transfer from the turbo?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
sierra (07-25-2012)
Old 07-25-2012, 10:07 AM   #1442
Don@Accelerated
The area the turbo sits gets plenty of airlow. I haven't collected any transmission temp data yet. I have driven the vehicle hard and then had it on the rack directly afterward. The external temp of the transmission wasn't any hotter than a normal spirited drive. Thats not to say the fluid is not hotter, but its not likely to have the case cooler and the fluid hotter.
The best option i've seen is the 2000 degree high temp ceramic coatings. They look great and functionally last much longer than the turbine wraps.
Don
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 12:24 PM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-04-2012 12:24 AM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 08:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 09:14 PM
