#85 | |
Drives: FRS
| The Following 2 Users Say Thank You to 8R6 For This Useful Post: | humfrz (01-04-2016), Ultramaroon (01-04-2016) |
#86 |
fabulous
Focus, Panda. Just consider it a commercial break.
![]() ...or a PSA.
#87 |
Drives: 2005 Toyota Camry
#88 | |
Drives: 2016 Oceanic, "base" model
But this discussion about the Fumoto valve did make we think about why nobody makes a remote oil drain kit. That would be even better than the Fumoto valve. Because the flat four engine is so short and sits so far back, it is the most PITA of all my cars for me because I have to slither so far under the car to get access to the drain bolt (which almost cancels out how easy it is to get the oil filter). So, instead of a drain plug, install a banjo bolt and fitting and a tube or a 90* AN elbow with braided steel line that goes to the front of the car... Hmmm... I wonder if that would work... Last edited by MrDinkleman; 01-04-2016 at 08:47 PM. |
#89 |
Well as long as you're going to all that work, you might as well run another line and put an oil cooler on the end. Put a Fumoto valve at the low point near the wheel well, and you can drain the oil by simply turning the wheels hard to one side, and sliding a drain pan behind the wheel.
If I say yes, will that make you think I understand?
#90 |
Drives: 2015 Firestorm Scion FRS
how much muscle did you put to screw the bolt back on? That's insanely tight to strip the threads off. That has to be double the torque to screw on lug nuts.
Simple solution: fumoto valve! Screw it on once and don't strip the threads off the first time and you'll never worry about stripping off the oil pan bolt ever again! |
#91 |
Drives: Lightning Red
Hope it's just the plug and that can be fixed...when I was a rookie I cracked my tranny case because the washer felt off and I didn't notice!
GL |
#92 |
Drives: 2015 Firestorm 08/05/15
Agreed partner. How difficult is it for somebody to get their lazy ass under the car take off the panels use old fashioned hand tools and change the damn oil. Just Damn. They need to learn about the machine underneath them. No way in hell I’d trust the fugimoto valve long term.
#93 |
#94 |
ProCrastinationConsultant
I love my fumoto valves. And I've barely used them
| Tags |
| damage, oil change |
| FR-Sandwhich: Total or not total? | Joshwahhhs | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 10-03-2015 09:11 PM |
| Looking for a set of OEM BRZ DRL Strips | s0sl0w | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-13-2015 10:18 PM |
| What headlights to pair with LED strips? | l0aded | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 06-24-2014 05:37 PM |
| Rubber Strips on the top of the car | zackcp04 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 05-31-2014 11:44 PM |
| RGB LED strips help | BadLuckZN6 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-21-2014 02:21 PM |
