#15 | |
Drives: 2005 Toyota Camry
The dealer is correct, this would have been under the base bumper-to-bumper warranty. Your best hope is for this to become an actual hole within 5 years. -alex |
#16 |
Drives: 13 Hot Lava, 01 Miata, 09 Outback
#17 | |
Suppose it also helps if they have built a rapport with the dealer and approached them in a professional polite manner.
#18 | |
#19 |
Drives: 2013 GBS BRZ Limited
The way that panel is "warped" and the way the cracks formed it almost looks as if the body was deformed in that area.
In my other car (also a uni-body) that is called the "longeron" and it takes almost all of the load on the car. Any chance the car was accidentally taken off-roading, been "mowing the weeds" at the track, ever been stolen or joyridden when you were not present? In any case it does not look like your run-of-the-mill random body corrosion. |
#20 | |
The problem is that he doesn't have much leverage at a dealership he hasn't purchased from since they're not really obliged to do it. -Justin |
| The Following User Says Thank You to Justin.b For This Useful Post: | FRSBRZGT86FAN (12-16-2015) |
#21 |
Drives: 2014 BRZ SWP LTD
Looks like you slammed the door into something, gotta be more careful of how the passenger closes the door.
Instagram: stimson |
#22 |
Drives: Firestorm 2013 FR-S
I agree. It would be reasonable to call a "perforation" something you can see light thru or push an object thru. Steel that has turned to iron oxide is still there, although it has no strength.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
#23 |
Oh, my ...... that's just the start .......
![]() Best stock up on wire mesh and bondo ....... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Cole (12-17-2015) |
#24 |
I think waiting for a rusty hole is crazy. Contact Scion Customer support, they are very helpful and tell them you didn't expect this to happen and you're disappointing this happened so quickly on a new car and they need to take care of it. The warranty is one thing, but what if it's due to misapplied anti corrosion coating during manufacture and where else on the car is this happening that you can't see. Here's the number...
CALL US To speak with a Scion Customer Experience Representative, call: 1.866.70.SCION Mon–Fri 5:00 a.m. – 6:00 p.m. PST
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#25 | |
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | stevesnj (12-17-2015) |
#26 |
I don't know what sort of luck you will have with Scion themselves since the warranty for rust is very clearly for perforation. May have some luck if he can find a sympathetic dealer but doubt there will be any such sympathy from corporate Toyota.
I am very curious as to what went wrong to cause that bubbling and rust though as in has been very rare here and when I checked my winter/salt driven car I found it to still be pristine.
#27 |
Is there any evidence of damage and/or repair? Can you see body filler under the paint where it's opening up? That would usually be a stuck to the back side of the paint and would be a light color but significantly thicker than the paint itself.
If this is a repair done incorrectly by the dealer before the car was delivered then you may be able to chase them down that way. -Justin |
#28 | |
| Corrosion Warranty Claim | aghuman | Issues | Warranty | Recalls / TSB | 27 | 04-02-2015 09:40 PM |
| Safe mods to avoid warranty- feedback/experience? | slags | BRZ First-Gen (2012+) -- General Topics | 8 | 09-19-2014 02:05 PM |
| Any experience with mod-friendly dealers and warranty? | 1Cor10:23 | CANADA | 8 | 03-08-2014 09:33 PM |
| Good warranty experience | dave77 | Issues | Warranty | Recalls / TSB | 9 | 01-21-2014 01:12 AM |
| Corrosion on sway bar mounts | SubiePig | Issues | Warranty | Recalls / TSB | 5 | 10-29-2013 06:01 PM |
