86WORX
Old 12-14-2015, 04:28 PM   #43
mrk1
Drives: Sterling BRZ Ltd
So if you made 300hp NA, you would replace the rods and pistons... got it.
It can, and has been done.
This thread is about FI and the cylinder pressure involved, NA is a different animal. Regardless of HP I can't see a NA car producing the cylinder pressure of a boosted motor.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
raven1231 (12-14-2015)
Old 12-14-2015, 04:29 PM   #44
mrk1
Why? You can take a stock FRS, put on a header, front pipe, C23, nitrous, and easily make 300hp.
You're really just showing how limited your experience is with these posts. Think outside the box, instead of limiting yourself to what you commonly see on this board.
Is Nitrous still considered NA?
The Build Thread
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
DustinS (12-14-2015), raven1231 (12-14-2015)
Old 12-14-2015, 04:32 PM   #45
Read the OP; poster claims 300hp needs new rods/pistons no matter what, although this IS the FI forum
Yes. You're not forcing more air mass into the air, but the composition of that air is different.
clayrush (12-14-2015)
Old 12-14-2015, 04:34 PM   #46
FRS Justin
Drives: 2013 Asphalt FRS
Do you know the fundamentals of nitrous? Last time I checked it added cylinder pressure. Mike your reaching stop 300hp n/a that no one has scene add nitrous lol just stop
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-14-2015, 04:34 PM   #47
mrk1
FI section, FI in the thread title
I think calling a nitrous car NA is a stretch
The Build Thread
Old 12-14-2015, 04:42 PM   #48
FRS Justin
Please reread my first post, poster never claimed 300hp needs new rods/pistons no matter what. Stop twisting things
Your adding oxygen and condensing the cylinder charge so you packs more air in so yes you are forcing air in. Come on man really...
I would love to see a 150 shot of nitrous hit that little 2.0 on a stock bottom end it would be epic 1 time....and I seriously doubt it would make 300 and live
710whp
Old 12-14-2015, 04:43 PM   #49
There is more to in-cylinder pressure than boost.
So many tuners desperately try to hit MBT in controlled environments, and then have their customers pop the motors when conditions deteriorate in the real world.
Old 12-14-2015, 04:44 PM   #50
Allowing more oxygen in, not forcing more mass of air in. Your MAF and MAP will read identically.
The air is still being sucked in by the engine, not being shoved in or being compressed.
in·duc·tion
inˈdəkSH(ə)n/
noun
noun: induction
the stage of the working cycle of an internal combustion engine in which the fuel mixture is drawn into the cylinders.
clayrush (12-14-2015), lantsalot (03-27-2018)
Old 12-14-2015, 04:45 PM   #51
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
Soooooo somebody gonna show this NA 300hp frs or naw?
cdq85 is offline   Reply With Quote
The Following 8 Users Say Thank You to cdq85 For This Useful Post:
DriftinFRS (12-16-2015), Fakk (12-16-2015), FR-S Neck (02-25-2016), FRS Justin (12-14-2015), kch (12-14-2015), Lonewolf (12-14-2015), NyC Zn6 (12-14-2015), sosick (02-16-2016)
Old 12-14-2015, 04:47 PM   #52
mrk1
This sounds like a summary of tuning in general, any setup
The Build Thread
CSG Mike (12-14-2015)
Old 12-14-2015, 04:51 PM   #53
mrk1
in·duc·tion
inˈdəkSH(ə)n/
noun
noun: induction
A nitrous bottle operates at about 1000psi, is that not "shoving in"
The Build Thread
Old 12-14-2015, 04:55 PM   #54
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
That is a good point but its adding a new fuel source rather then compresed air right??
Old 12-14-2015, 04:57 PM   #55
FRS Justin
Edelbrock Performance Nitrous Systems Support
HOW DOES NITROUS OXIDE WORK?
As stated before, nitrous oxide is an oxidizer. An oxidizer supports combustion by supplying additional oxygen. Initially, the nitrous doesn't help the process. This is because as long as the one oxygen molecule is bonded to the two nitrogen molecules, the oxygen isn't free to aid combustion at all. Only after they've been exposed to the heat of the combustion process will the chemical bond be broken (the bond breaks around 570 degrees), allowing the free oxygen molecule to then contribute to the combustion process. Additional fuel is added along with the nitrous to maintain a stoichiometric air/fuel ratio. The end result is more horsepower being created pretty much the same way a blower or turbocharger does.
710whp
Old 12-14-2015, 05:03 PM   #56
mrk1
Depends how you look at it, wet or dry kit. Nitrous is 33% oxygen which is really the goal here no matter what we are talking.
Dry vs wet, why nitrous also has nitrogen is another discussion (absorbs heat, stability)
The Build Thread
go_a_way1 (12-14-2015)
kill brain cells, not facts
FlexFuel and Facts Shiv@Openflash Software Tuning 69 10-16-2019 02:08 PM
Anyone Else? Hearters Blowing when off. Kiske Issues | Warranty | Recalls / TSB 7 04-09-2014 06:22 PM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 04:29 PM
Supra Blowing Up radroach Off-Topic Lounge [WARNING: NO POLITICS] 2 07-21-2013 10:14 PM
Facts you may or may not know about your GT86/BRZ/FR-s FiRStsc10n Scion FR-S / Toyota 86 GT86 General Forum 41 07-09-2013 04:05 PM
