#421 |
? Makes no sense.
Sent from my SM-G960U using Tapatalk
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#422 | |
#423 |
Drives: frs
#424 | |
Drives: Q5 + BRZ + M796
At low rpms engine load and torque can still be high, heat can be higher because the engine isn’t circulating as well or efficiently, and oil pressure can be lower on rpm dependent pumps, so bearings can fail easier, maybe. |
#426 |
Drives: 2013 frs red
I would imagine that compared to stock, 4500 to 5000 rpms is rather "spirited " in a boosted twin.
#427 | |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Yes it is!! I rarely ever need to go to my peak of 300whp which is weirdly available at 6500 rpms. At 4500-5000 my power is 205-230whp while torque is 237wtq at those rpms. |
#428 |
Drives: 2017 Halo 86
When someone asks you "how much horsepower your car has", do you respond with
B. braking hp C. crank hp W. wheel hp
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
#429 |
Drives: 2023 BRZ
| The Following 6 Users Say Thank You to Pat For This Useful Post: | Code Monkey (04-25-2018), CSG Mike (04-25-2018), ichitaka05 (04-25-2018), JazzleSAURUS (04-25-2018), Phantobe (05-07-2018), strat61caster (04-25-2018) |
#430 |
#431 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Awww all the good comments were deleted
| The Following 2 Users Say Thank You to weederr33 For This Useful Post: | strat61caster (04-25-2018), totopo (04-25-2018) |
#432 |
Drives: 2013 Asphalt FRS
So what did I miss
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#433 |
Drives: 370z
Not much, I think after your reply I only made one more post this morning, then the whole chain got nuked. If you didn't see it I can PM it, I was pretty proud of that one. I didn't check the board till hours later so I don't know if any more drama was stirred.
You know, reading this nostalgic post just kind of annoys me. When it was necro'd I went back and started reading again from the beginning. All these people attacking OP. I feel like I tried to give even, thoughtful responses which were being met with nothing but sarcasm, memes, and obfuscation. The amusing thing to me, is now basically everyone agrees with OP. They way he talks may have rubbed people the wrong way, but you see what other tuners and testers say, you see all across this forum, it seems like everyone has picked up that rods are the weakest with significant boost, and there is a significant risk of failure at 300hp. I kind of feel vindicated, even though there is no acknowledgement, got annoyed at one necro circlejerk post in particular, and I got annoyed and incredulous that people want to keep arguing 2 years later. I feel sorry for the moderators. I got too angry and slung some mud, probably went farther than I should and probably crossed some board lines, but I still feel like my posts and words were justified and I feel my anger at the particular action is especially justified given the real world consequences. Especially at this stage when the platform isn't new anymore, and there are probably a lot of people jumping in who can only afford used cars, who can't afford new engines. But I am sorry I put the moderators in a bad place. I don't completely agree with the deletions, but I am glad that at least the thread wasn't locked. |
| The Following User Says Thank You to totopo For This Useful Post: | bcj (04-25-2018) |
#434 |
eventually people that boost will learn the truth. I stopped sharing along time ago, and in that time i have stopped the dreaded blow by issues rod failures and head gasket failures, running 700+ at the wheels for 2+ years. so when you decide on LA Sleeves, your welcome, when you decide on the new improved mls headgsks, your welcome, 1/2 inch studs your welcome closed deck fa20 your welcome, and the list goes on.
now people just have to figure out what machine work is needed and what specs.
| The Following 2 Users Say Thank You to FRS Justin For This Useful Post: | bcj (04-25-2018), Irace86.2.0 (03-16-2020) |
| Tags |
| kill brain cells, not facts |
| FlexFuel and Facts | Shiv@Openflash | Software Tuning | 69 | 10-16-2019 02:08 PM |
| Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 06:22 PM |
| How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 04:29 PM |
| Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 10:14 PM |
| Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 04:05 PM |
