#183 | |
Drives: 2013 Asphalt FRS
Then you obviously don't know the definition of forced didn't educate yourself and made a total fool out of yourself by saying NOS is not F/I So Einstein explain to all of us why the NHRA and several other racing sanctions list it as F/I Could it be this: forced (fɔːst) adj1. done because of force; compulsory: forced labour. 2. false or unnatural: a forced smile. 3. due to an emergency or necessity: a forced landing. 4. (General Physics) physics caused by an external agency: a forced vibration; a forced draught. forcedly adv ˈforcedness n combined with the fact you increase cylinder o2 content from 21 to 33 percent. You should go by a book instead making embarrassing post troll exit stage left and take your friends with you
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#184 |
Drives: 2013 BRZ black
bell-end
Noun (plural bell-ends) (UK, vulgar) The glans penis. (UK, offensive, vulgar) A stupid or contemptible person Origin bell + end The question wasnt that nitrous made power LIKE forced induction, it was that you consider nitrous "forced induction". Which it is not. I wasnt stating that Chris' NA build was the motor from 2013. I thought that was obvious. Just pointing out an example that it is absolutely feasible. /rant |
#185 | |
The nitrous came up when the same person stated it was N/A no its not, Due to the physics involved by changing the o2 content of the cylinder charge. You can't increase o2 content any other way other than F/I.
#186 |
Straight from Wiki: Forced induction is the process of delivering compressed air to the intake of an internal combustion engine. A forced induction engine uses a gas compressor to increase the pressure, temperature and density of the air. An engine without forced inductionREAD:COMPRESSED AIR is considered a naturally aspirated engine.
https://en.wikipedia.org/wiki/Forced_induction You posting the definition of the word "forced" is completely out of context for this discussion. Lets look at a single cylinder with the piston in BDC. You have .500 liters of cylinder displacement. Lets say we have a nice even 20% oxygen content from the atmosphere. If you add nitrous, you see an increase in oxygen to say 33%. Your cylinder volume is still .500 liters. The volume didnt increase, just the oxygen content did. If 50% of your cylinder volume is now your nitrous mixture, that means you had to displace 50% of that volume of atmospheric air that normally would have been there. You arent ADDING volume, just substituting volume with different constituents. You cant increase the internal volume beyond your .500 liter displacement WITHOUT compressing the intake air first. |
#187 | |
Example if I had a gallon jug of lets say sugar and a gallon jug of water there is more water than sugar in that jug. its still a gallon container but the water is denser. So if you are putting more than a normal amount on the standard of N/A intake stroke because the charge is denser it is considered F/I because it still has more o2 than a normal N/A intake stroke Edit : I should add that o2 is the main focus not the mechanism of how it got there. o2 is what creates the bang so it's what's focused on. you adjust power levels by jet changes right, but that doesn't change the volume that enters the cylinder only the density of what's going in edit again sorry.... another example lets count the intake o2 N/A lets say the cylinder holds 500 o2 molecules (hypothetically for math purpose) your turbo or S/C at 20 psi pushes 1000 molecules in the cylinder and you hit a 150 shot of nos and that puts 1000 molecules in the cylinder the nos made the same o2 as 20 psi on the turbo and S/C by a chemical process. that's why the F/I mechanism is not what's important
Facebook FT86PROJECT9S 710whp Last edited by FRS Justin; 12-16-2015 at 12:59 PM. |
#188 |
Agreed A forced induction engine uses a gas compressor to increase the pressure, temperature and density of the air. The gas compressor is the turbo S/C or NOS they all do the same thing by increasing o2 limits in the same volume An engine without forced induction is considered a naturally aspirated engine. Agreed
#189 |
Drives: '14 981CS, '99 NB1
The SCTA classifies Nitrous as a Fuel and whether an engine is NA or not is qualified by whether it has a blower/turbo on it. Their classes run unblown on gas, blown on gas, unblown on fuel, or blown on fuel. I would love to see you go down to the salt flats and explain to the fastest people on the planet, how they've got it all wrong.
#190 | |
#191 |
I'm done
#192 |
More accurately, NOS is fuel additive or a combustion enhancer.
| The Following User Says Thank You to jvincent For This Useful Post: | CSG Mike (12-16-2015) |
#193 | |
Drives: Subaru BRZ Limited
#195 | |
So cars at sea level are forced induction and cars in Denver are NA. The cars have to aspirate harder where there's less oxygen right? It's all about the oxygen content right? |
| The Following 3 Users Say Thank You to xkalelx For This Useful Post: |
#196 |
Drives: 2013 FR-S M/T Ultramarine
Pretty sure my iq dropped a couple points after reading just this page from this thread.... I feel like everyone is arguing with a brick wall, you can't educate some people. Also NOS is a brand not an elemental compound.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2. OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1 C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can |
| The Following User Says Thank You to Rapiddan45 For This Useful Post: | BRZoomTX (12-16-2015) |
| Tags |
| kill brain cells, not facts |
| FlexFuel and Facts | Shiv@Openflash | Software Tuning | 69 | 10-16-2019 02:08 PM |
| Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 06:22 PM |
| How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 04:29 PM |
| Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 10:14 PM |
| Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 04:05 PM |
