#15 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
That shouldn't matter too much. As long as they can strengthen their legs or sit closer.
#16 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
No way you can walk up a flight of 3 stairs and not be able to depress the clutch with just your big toe while seated backwards. Lightest clutch I've ever driven. Position shouldn't be as big a deal as all that.. as others have mentioned, betting money on aftermarket clutch or related modification
| The Following User Says Thank You to Toyarzee For This Useful Post: | Tcoat (12-10-2015) |
#17 |
Drives: 10 Series #974 6m/t
sounds like you need an upgrade give Skynet a call..on a serious note they should sell knee braces that might help with the compression/decompression of the joint cap if it is that serious.
#18 |
No rice, no life
Drives: 2013 Asphalt FR-S
"Stiff" is relative, so I wouldn't think there's anything wrong with the clutch. I have a bad left knee, so my leg also gets sore after high-intensity workouts such as rush hour traffic. You could try experimenting with different seat positions to find which angle gives you the least fatigue. I actually sit pretty close to the steering wheel.
Do you slide your heel when you change gears or do you just keep it dug in the carpet? Pain in the back of the knee sounds like you might be overextending your ankle.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
#19 |
What if you rig up a solenoid or similar electrical device actuated by a button on the shifter? Press button tells the device to press the clutch for 1.5 seconds. Maybe use some kind of cam so you have a gradual pedal release.
Or get an auto Jk I understand the problem. Other than a different position or avoiding the situation I don't have a fix. I'd definitely look at that mod mentioned earlier though Last edited by Ashikabi; 12-10-2015 at 01:55 PM. |
| The Following User Says Thank You to Ashikabi For This Useful Post: | Tcoat (12-10-2015) |
#20 |
Pulling out the clutch spring makes it REAL light, but that's not really your problem. Pushing your seat way back helps keep your knee out of it's "prone" position. Sadly, high traffic areas are better dealt with using automatic transmissions.
#21 |
Drives: 2005 Toyota Camry
Poor technique is making you have discomfort. That's all there is to it.
If you think this is stiff, wait till you try out an aftermarket performance pressure plate. -alex |
#22 | |
Drives: 2015 WRB BRZ Premium
The clutch spring is actually an assist spring in these cars, not a return spring. By removing it the pedal actually gets stiffer.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
#23 |
Drives: 2013 Pearl White 6MT
#24 |
#25 |
Drives: 2013 GBS BRZ Limited
I sold my last MT supra and bought a 99 Solara AT for exactly that reason.
I used to spend >2 hours a day with half of that in stop and go traffic and my knee was killing me. That and the FWD Solara with traction control could literally drive circles around the Supra in the snow. |
#26 |
Drives: 02 Celica GT
If you check out the clutch and it is all OEM I would recommend seeing a Physical Therapist. They can determine if it is a musculoskeletal issue or a positional problem that is affecting the dynamics of the knee and giving you pain. Both of these issues are easily correctable and within their skill set to treat and resolve! You should just be able to walk in/schedule an appt. without a referral from your primary care physician. Don't let old age keep you from driving a stick!
| The Following User Says Thank You to AKBrrrrrrrrZ For This Useful Post: | humfrz (12-10-2015) |
#27 | |
Sporadic Member
Drives: 2016 Halo FR-S M/T
I would still suggest to check if your clutch pedal is missing the spring or take it to a dealer or local mechanic to determine if there is an aftermarket clutch installed on the car. |
#28 |
That makes sense. When I was installing my MTEC springs, people were pulling out their springs to give it more "feel." Thanks for clearing that up.
| The Following User Says Thank You to MJones_RB For This Useful Post: | Nickosport (12-10-2015) |
| Tags |
| :popcorn: |
| Knee Pad Set For FR-S and BRZ | zetaproducts.net | Interior Parts (Incl. Lighting) | 4 | 12-18-2012 10:07 AM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 | Redline360 | Transmission and Driveline | 2 | 07-30-2012 11:01 AM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 01:06 PM |
