| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
| View Poll Results: FWD: put bad tires in front or rear | |||
| Bad tires in front |
22 | 40.74% |
| Bad tires in rear |
32 | 59.26% |
| Voters: 54. You may not vote on this poll | |||
#57 | |
Thanks
Not rotating your tires and just letting the fronts wear out is silly if you actually drive in rain or snow. But I know this is how the general public run their cars. So the root of the problem. Why did he bald his fronts while his rear are still in good working order? Doubly interesting if he works at a tire shop...
| The Following User Says Thank You to ZionsWrath For This Useful Post: | meWant (12-11-2015) |
#58 | |
Drives: 04' Saab 9-5 Aero
A shit ton of tire smoke, and a smelling torque converter later and I was back on my way home with very clenched butt cheeks. If you don't have an uber hot hatch with like +250ft/lb of torque you simply lack the power to pull the car out the turn, and you WILL crash. In regards to the front vs. back tires... rear every time (assuming for some reason you don't buy tires in sets of 4?)
_____________________
You know what they say... pick two: cheap, fast, reliable. Last edited by Joakim3; 12-25-2015 at 01:22 AM. |
#59 | |
Drives: Nevermorange FRS
SCCA T4 - FRS
| The Following User Says Thank You to rice_classic For This Useful Post: | KR-S (12-12-2015) |
#60 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Well what if you put the worn tires on the left side and the good ones on the right side??? That way you have a 50/50 mix and you can still turn left good, you just have to be careful you dont slide up the corner on a right turn if you are going really fast??
#61 |
Drives: '12 C63 P31, '17 GTI Sport, '00 MR2
I'm shocked. Shocked that so many of you knuckleheads voted for "front tires".
Doing that is gonna eventually bite you in the ass. Signed, someone that lifted on a semi-damp road mid-turn and almost spun the car around whilst driving home FROM the tire shop (and had them put the new tires on the front) ![]() (and those rear tires weren't that bad - like 75% tread life left.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#62 |
Drives: 2015 AOZORA EDITION
^ My FWD car when i had bald tires in the rear i almost spun out in the hwy.
Sent from my SM-N920W8 using Tapatalk |
#63 | |
Bannéd
Drives: 2013 DGM BRZ
![]() I understand your point, but the evidence you use is completely obvious. "I'm shocked. SHOCKED that any of your would even consider driving on all seasons in the winter! That's going to end up biting you in the ass. Signed someone who went off the road trying to drive at 90mph in the snow with a fresh set of all seasons."
The fascinating thing about my signature is that by the time you realize that it is of no importance, it will also be too late to stop reading it. Good luck getting those five seconds of your life back. |
#64 |
Granny Shifter
Drives: 2014 FR-S
Having your good tires in front are all fine and dandy until it rains. Just something to keep in mind. With that being said, if you have "bad tires" you should consider getting them replaced and not drive on them to begin with.
#65 | |
Granted in most cases you should almost never want to lift while changing directions at speed. And trying to equate it to all season tires in the winter is a bit of a stretch. Unless you live in a northern climate where it does snow a lot. Then yes you're an idiot for cheaping out and not snow tires.
#66 | |
Bannéd
I'm mostly just surprised this thread has lasted this long. I also have no intention of ever owning a FWD again so I'm mostly just spewing bullshit.
| The Following 2 Users Say Thank You to Special_K For This Useful Post: | Ultramaroon (12-25-2015), WolfpackS2k (12-21-2015) |
#67 |
Hahaha
| The Following User Says Thank You to WolfpackS2k For This Useful Post: | Special_K (12-21-2015) |
#68 |
Drives: 2013 Brz C38 (bought not built :P)
no tires. I like to live dangerously.
#69 |
FWD: Traction goes up front and driver must refrain from lifting.
End of lesson.
SCCA T4 - FRS
#70 | |
You can still spin a car without lifting... If you have to do an emergency lane change or slam on the brakes the rear tires are going to break loose before the front simply due to load-transfer (something that would be made x100 times worse if you had new tires up front and shitty ones in the back). I'd rather the car plow into the turn and still retain some control of the cars direction than oversteer in a FWD with zero hopes of recovering the slide short of pulling the e-brake, counter steering and saying a little prayer....... or crashing Even though it's an old video... the principle remains the same (and this came from Michelin, who are arguably the last word in tire manufacturing) http://blog.allstate.com/new-tires-rear/
You know what they say... pick two: cheap, fast, reliable. |
| The Following User Says Thank You to Joakim3 For This Useful Post: | HunterGreene (12-30-2015) |
| PSA: Don't drive like me (unless you want a bent wheel) | mav1178 | Tracking / Autocross / HPDE / Drifting | 11 | 07-25-2015 04:37 PM |
| FS: 245/40/18 Yokohoma S Drive Tires | Rabbit86 | Canada Classifieds | 10 | 04-24-2015 10:20 AM |
| OK wheel gurus, wheel are here, now for tires | FRSGT86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 02-12-2013 02:36 AM |
| TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? | No5ki | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 01-06-2013 09:30 PM |
| How to drive your tires to go fast. | Asterisked Accolade | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-06-2012 04:01 PM |
