Old 12-03-2015, 10:37 PM   #15
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Originally Posted by Mr.ac View Post
The reason you spun out in the rain was simply driver error.
Thank you. Second thread and now getting somewhat hostile, yet a handful of people still offer the same advice and op is still taking the same level of corrective action.
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
Tcoat (12-04-2015)
Old 12-04-2015, 01:08 AM   #16
pantdino
Drives: Firestorm 2013 FR-S
My 1995 M3 with 185K miles has a little leak that I deal with.
But there is no excuse for a modern car with 50K miles to have an oil leak of any kind.
You should not have to deal with this.
By dealing with it yourself you are letting Toybaru get by with inadequate design or manufacture.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 12-04-2015, 01:33 AM   #17
Originally Posted by HachiRo View Post
Obviously I would like to know if there are any similar issues, solutions, or experiences before trying to go through any issues or delays a dealership might bring up. Honestly, it'd be nice if you just left this thread alone. I'm open to actual help, not snarky suggestions. Thank you.
Hey guys,
So I've posted onto another thread about this before and we couldn't determine exactly if it was just residue from a belt or actual oil, but there's a crap ton of oil gunk and build up on my driver side skid plate. When I look into the engine-bay and downwards, there's black crap everywhere lol. This morning was raining and as I was turning I spun out which freaked me out because I drive quite carefully. My first thought was something I read about how an oil leak can get onto the wheels making it more slippery. Opened the engine bay and saw a puddle on the skid plate above the rest of the black residue. Also, some came out the bottom of the car. I checked oil levels (oil change 3 weeks ago) and there was still a good amount. It's pretty much straight below the oil filter cap. Car is at 50k miles, bought used from a Nissan dealership a year ago.
Will post pics asap.
Is it a serious issue/any recommendations on tackling the issue?
I am on my home computer and can see the pics better. I retract my earlier theory about belt particles as I can clearly see they are reflective now.
Now for my version of a "snarky" response.
That does look like finely spread oil with dirt stuck to it.
Is it urgent? No. Should it be fixed? Yes.
If you are unable to diagnose it and are not sure how to fix it then your best bet is to take it in and have the pros look at it. This is not something that makes a good beginner DIY project.
If you have enough oil pouring out that it is getting into your wheels you have much larger issues anyway.
I did not see the other remarks but from what is here now I stand behind Go Away's comment 100%. You are under warranty take it in and get it checked.
go_a_way1 (12-04-2015), HachiRo (12-04-2015), stugray (12-04-2015)
Old 12-04-2015, 01:37 AM   #18
A first run car with a newly designed/produced engine can have things come up. Shit happens.
Old 12-04-2015, 02:42 AM   #19
stugray
Drives: 2013 GBS BRZ Limited
I don't know why I bother...
oil dye
The Following 2 Users Say Thank You to stugray For This Useful Post:
86kahl (12-05-2015), Tcoat (12-04-2015)
Old 12-04-2015, 05:38 AM   #20
Gringosteve
Drives: UK Spec GT86
Looks identical to mine. If it is the end plate it is a small job. If it is the cam cover the engine needs to come out
Gringosteve is offline   Reply With Quote
The Following User Says Thank You to Gringosteve For This Useful Post:
Tcoat (12-04-2015)
Old 12-04-2015, 03:55 PM   #21
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Is the cam plate accessible from the top of the motor? was it an easy install? I don't have a leak but i would like to prevent this from happening.
Old 12-04-2015, 03:58 PM   #22
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Cam plate is the easy fix and what is pictured in that bottom quoted picture.
Old 12-04-2015, 04:44 PM   #23
Gringosteve
Sorry cam plate and timing cover
Old 12-04-2015, 05:08 PM   #24
stevemp5
Drives: scion fr-s
Cam plate is left side of the engine and are oil deposit is right side.. i do not think is that
stevemp5 is offline   Reply With Quote
Old 12-04-2015, 05:08 PM   #25
Gringosteve
I'm guessing timing cover then..
Old 12-06-2015, 05:06 PM   #26
504
504's Avatar
Drives: 2014 86 GTS
You guys are way over thinking it, as stated above it isn't the cam plate because it is on the wrong side. It's spillage of oil from service when whoever serviced it filled the oil. Usually dealers do this because they don't seem to care and they tend to overfill it. Dust and belt residue sticks to it making it look old and dirty, check if the bit under the oil filler is oily or had signs of oil which the mechanic may have tried to clean up, the best thing to do as stated by others is to clean and monitor. I'm fairly confident it won't come back (until next service at least!)
504 is offline   Reply With Quote
Old 12-07-2015, 01:34 PM   #27
shellslinger
Drives: Whiteout FRS
As everyone had stated if you're under warranty take it in ASAP. I just took in my car for this issue and they are pulling the engine right now to re-seal the timing cover.
Mine looked exactly like what the OP had posted. Almost mirror image.
shellslinger is offline   Reply With Quote
Old 12-07-2015, 10:51 PM   #28
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I just put my car on the lift to swap out headers.
My car (Feb 2013 manufacture date) has oil slowly seeping from the timing cover.
I'm the only one who has changed oil on my car. This is not just a case of "overfilling the oil".
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Gringosteve (12-08-2015)
Search this Thread:
Advanced Search
Protek Skid Plate Install whataboutbob Cosmetic Modification (Interior/Exterior/Lighting) 79 04-21-2017 04:01 PM
OEM Skid Plate - Subaru/Scion cant get it? JTOFJPN Engine, Exhaust, Transmission 10 04-19-2017 06:49 PM
FS: Protekt Skid Plate - BRZ harkbrz Canada Classifieds 1 12-10-2014 08:58 PM
Part number for the skid plate that.. Yamajee Cosmetic Modification (Interior/Exterior/Lighting) 0 11-01-2014 09:12 AM
Sand/grit on top of skid plate 1Cor10:23 Scion FR-S / Toyota 86 GT86 General Forum 0 12-18-2013 01:11 PM
