| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,100 | 85.21% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.79% |
| Voters: 3638. You may not vote on this poll | |||
#1345 | |
Drives: Mazdaspeed 3
The only reason they're replacing pumps right now is because so many people have complained about it, and are demanding action without giving the company time to come up with a viable replacement pump that doesn't exhibit these characteristics under normal use. |
| The Following User Says Thank You to Fenrir For This Useful Post: | Sigh-on-Rice (02-01-2013) |
#1346 |
Drives: S2000/FR-S
#1347 | |
First 86
Drives: Scion FRS Argento Automatic
Life is short...NO BORING CARS |
#1348 |
Drives: 2013 MT FR-S Asphalt
Drping the car off in the morning for 2nd replacement of the fuel pump. Hopfully this is the last time I need to make this trip!
#1349 |
When will Toyota/Subaru change fuel pump part to a completely new fuel pump and stop replacing the problem with another problematic same fuel pump? Still waiting....
#1350 | |
Drives: 2020 BRZ tS #54
would you go back the 3rd time and get it replaced ? yeah toy/sub needs to make a new new pump.. is there any after market ? not sure if you want to spend it out your own pocket due to most likely its still warranty..but toy/sub needs to step it up..not digging this crickets
#1351 | |
#1352 | |
![]() but yeah ill get mine checked out..hopeful i dont have to wait months for the pump to come if i get mine change out.. |
#1353 | |
| The Following User Says Thank You to FR-S Matt For This Useful Post: | marky (02-04-2013) |
#1354 | |
The TSB itself says that the noise isn't abnormal, it's undesirable. A TSB isn't admission of a faulty part. There's been plenty of TSBs for undesirable characteristics on vehicles that aren't broken or damaged, or have any impact on the car outside a bruised ego. Abnormal indicates there is an actual problem, which there is 0 evidence of in this case. Also, the "consequent fire" you are referring to was a result of poor workmanship and shoddy mechanics. It has nothing to do with the chirping being discussed here. |
#1355 |
Drives: 2013 Asphalt FR-S
I was going to say.. it it probably related to the DI system. Not sure if i have the chirp but i certainly have the diesel sounding clatter lol
~Namaste~ |
#1356 | |
First 86
http://www.ft86club.com/forums/attac...6&d=1352490977 In regards to the "consequent fire" comment I made, it was not in reference, obviously, to the poor Lad who had his HPFP replaced and then caught fire due to questionable technician competence. Again if you had read carefully I posed the question "And could it not be an indicator of a future failure and consequent fire?" This was in reference to other cars with HPFP that have had failures and caught fire (VW, Audi).
#1357 | |
However, the Subaru one (as I have a BRZ, so that's what I've been looking at primarily) located here makes no mention of abnormal. It even goes so far as to explicitly state (in bold, no less), that this isn't a detrimental noise. Fair enough on the fire comment, and again my mistake. Was that really an issue on VW/Audi DI systems? I've heard plenty about their pumps being notoriously junk and failing to provide enough fuel leading to detonation and exploded motors, but hadn't heard about the fire thing. |
#1358 | |
First 86
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 02:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 11:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) -- General Topics | 49 | 07-02-2012 04:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
