| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,100 | 85.21% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.79% |
| Voters: 3638. You may not vote on this poll | |||
#1289 | |
Drives: Subaru BRZ soon
Here is what is written in the BRZ gas trap : ![]() The french GT86 manual tells that the car can use SP95 and SP95E10 (with ethanol) but performances will be lower and engine can do *unexpect noise*. Of course, I fully understand this kind of gas (SP 95 or SP 98) is not aviable in USA. So it won't help a lot but it explain why there not or far less complains from EU users. In Belgium, Germany, Luxembourg, France and Netherlands SP 98 (pure gas) is really common. I don't know for other EU countries. My 2 cents from Belgium !
| The Following 4 Users Say Thank You to Pascal_TTH For This Useful Post: |
#1290 |
Drives: BRZ(sold), STI
Apparently you don't even read this thread. There are people in Canada, using ethanol-free Shell 100% of the time, with chirp. It just takes longer to develop.
#1291 | |
That's what I learn form french topics/forums.
#1292 | |
I'm not sure what oil grade has to do with HPFP. But anyway, thanks for relaying what people are saying on French/Belgian forums. |
#1293 | |
Drives: Mazdaspeed 3
Ethanol isn't the only factor here. EPA requirements in the US call for different detergents and additives to be added to the fuel, and as is the nature of things, causes the Canadian fuel to be virtually identical (minus the ethanol, of course). While it's reasonable to assume that the ethanol expedites the situation, it's not the entire underlying cause. Should have clarified in my post. |
#1294 |
First 86
Drives: Scion FRS Argento Automatic
I would really like to get a solid answer from Toyota/Subaru on what really causes the chirping noise. There is some indication it is a manufacturing defect and yet many posters have said that a change in gas brand, octane rating, ethanol vs non-ethanol can affect the noise. For my car I noticed a brief chirping on my first tank of gas, then no chirping for 5 months, then after a 3 hour drive in the mountains the chirp was in full song, at which point I took it to the dealer where they listened and ordered a new fuel pump. In the 2 months that I waited for the new pump I didn't have one chirp. No comprende!
Life is short...NO BORING CARS |
#1295 | |
#1296 |
Drives: 2013 MT FR-S Asphalt
You sure you aren't confusing that with the Mazda manual?
#1297 |
First 86
The Subaru TSB is a bit ambiguous in that on one hand that "it is the result of the positioning of the plunger stopper inside the high pressure fuel pump", but then continues on to say "Some may have a plunger stopper position that when combined with certain fuel temperatures or fuel formations, may result in aeration....causing this sound..." With my car I consistently used Chevron 91 and all through the hot summer no chirp. But one 3 hour drive in the mountains in relatively cool November and it sings like a sparrow. No clear answer from my perspective.
#1298 | |
Quite sure, actually. But it's good to know you've run out of legitimate arguments and have to resort to petty personal attacks to feel good about yourself.
The wording the Subaru TSB is mixed with legal jargon to avoid using absolutes. "May" and "some" are the key words in those statements. The conditions are more related to engine temp than outdoor temp. Mine did it on the way to work this morning after a spirited jaunt through some twisty back-roads, and it's 12° F outside. Earlier last year, I would drive in 104° F weather with nary a chirp to be heard. I had a decent write up at one point I found elsewhere regarding this noise in similar DI systems and what it was in the fuel that was causing it, but can't seem to find it now. It was a combination of the detergents and other emissions additives used. I'll keep digging, though. |
#1299 | |
First 86
#1300 |
Drives: Asphalt A/T
Well...3 months, 4 maybe? after the fix the crickets are back!
#1301 | |
#1302 |
First 86
I had DI on my 2 Mini Coopers-the DI made the engines sound like a diesel. My wifes' Lexus IS 250 has DI but is very quiet (sound deadening to the max). My concern about DI is that the fuel pumps run such high pressures ,and many high pressure fuel pumps have failed in Mini Coopers, BMW's, VW's, and Audi's. Hence my worry about the chirping being a possible indicator of future failures. I bailed on my Mini's before the warranties were up because of this.
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 02:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 11:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) -- General Topics | 49 | 07-02-2012 04:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
