| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,100 | 85.21% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.79% |
| Voters: 3638. You may not vote on this poll | |||
#687 |
Turtle Factory
Drives: Mint M3
I am not really concerned with the sound. My only worry is if there is a long term negative affect from whatever is causing the the chirp?
#688 |
Drives: Skoda Yeti DSG diesel 4x4
| The Following User Says Thank You to sierra For This Useful Post: | alrashwa (08-14-2012) |
#689 |
Drives: '12 370Z Monterey Blue
#690 |
Drives: White WRX Hatchback, Toyota Pickup
Interested in this as well. And though it may have been posted 10 pages ago, can you also list what brand/kind of oil you're using? Thanks!
2013 Subaru BRZ, SSM Limited
vin: 6007xx build: 3/2012 |
#691 |
Drives: Whiteout 6MT FR-S; E30 BMW's
#692 |
Kouki-Monster
Shell. 91 V-Power always. There's supposed to be 0 Ethanol in 91 Shell here. The only V-Power I have ever known to have Ethanol is the 93 stuff and they indicate it.
Rich Anderson
EMPOWER AUTO |
#693 | |
#694 | |
Driving Coach
MMT will not make your octane nearly as high as high as the feel of it in your engine would seem to lead you to believe. This is because MMT makes your fuel denser and burn slightly longer giving you additional torque than simply higher octane couldn't achieve. This process also can have the unfortunate result of contributing to gunk build up in the injectors and valves, especially if used in excess of .8 oz per gallon. |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | Marrk (08-15-2012) |
#695 |
Drives: 2013 BRZ, 2002 WRX
Octane booster did not change anything for me. 2oz of 2-cycle oil has done the trick though. No noticeable side-effects. Super low ash formula.
#696 | |
It's been proven to shut the chirp up at 1000:1 in the 86. I use it in my diesel because it's quieter, gets better mpg and compensates for the low lubricity of recent very low sulphur diesel to ensure it lasts like they used to. When I fill up I glance at the trip odometer which I always zero at the pump because i'm fuel consumption obsessive and keep a log. It's easy with metric to work it out and I know since I average 8L/100km that 600km means 48L which is 240ml of 2T at 200:1. The 1L container has a measure window so I just tip about 250ml into the tank and then fill up, it doesn't need to be exact. I'll translate that into US figures for the 50L 86/BRZ tank. 13.2USG = 1690oz So for the first fill up add 1690 divided by 1000 = 1.7oz Using 30mpg we get about 400miles to a tank. That's 0.1oz for every 25miles at each fill up after that. So for 280miles add 1.1oz. That's easy enough to do in your head like I do at the pump. Use a high quality 2 stroke oil with very low ash content which will clean, lubricate and combust completely. Can someone please check my figures? |
#697 | |
Drives: '13 Ultramarine
That post you quoted is from a while ago and I have had time to experiment a bit more since then. I have found that as little as 1-2 oz of good quality 2-stroke oil will do the trick. I just add a small amount directly to the tank, then fill it with gas. From what I have seen and done, sierra's comments are pretty much spot-on (I didn't check his math though...). |
#698 |
Thanks a ton guys. My friend at Toyota Japan even recommended this method, so I'd say it's a solid one.
| The Following User Says Thank You to alrashwa For This Useful Post: | ill86 (08-15-2012) |
#699 | |
Drives: Honda Fit
With all due respect, you have given an awful lot of advice regarding what other people should put in their cars, and you have spoken with abundant authority on the subject, and yet you do not even own one of these cars, nor do you have any firsthand experience with one. I wish you would disclose this before posting each and all of your future statements. Just begin by saying, "I don't have a car, but here's what you guys should do with your cars." 'Kay? |
#700 | |
It's been used in car engines for many reasons for years without any negative reports that I've ever seen, only positive results. I know that some worry about warranty but it's being used in tiny quantities to solve a problem until they can engineer a fix, if they actually bother? Until then it compensates for the negative effect of the ethanol. I only harp on about it because I feel it's a good thing that's very easy and cheap to do until it gets fixed. You can also be pretty confident it wont deteriorate. |
| The Following User Says Thank You to sierra For This Useful Post: | ill86 (08-15-2012) |
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 02:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 11:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) -- General Topics | 49 | 07-02-2012 04:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
