View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,100 85.21%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.79%
Voters: 3638. You may not vote on this poll
Old 04-02-2017, 09:23 AM   #4971
stevesnj
stevesnj's Avatar
Originally Posted by Joyride86 View Post
Any updates on the chirping status? It's gotten warmer in my area and the chirping is back. If the fix still works in the warmer climate, I'll probably be swinging by the dealership to get this done. If not, I'm not gonna waste my time.
Well no one knows 100% i works, thee TSB came out in October and one factor is warm ambient air temp. If it's audible make an appointment at the dealer print out the TSB from here and bring it with you. Basically if you hear the chirp this version of the pump is supposed to fix the issue.
My 2016 Build thread
Old 04-02-2017, 09:24 AM   #4972
stevesnj
stevesnj's Avatar
Originally Posted by dhuang View Post
~2500 miles on the new pump. No chirping with 93 QT gas.
Normally it chirps like mad once warmed up. Happy camper here
What's the outside temps?
Old 04-03-2017, 02:53 AM   #4973
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
No chirps since I got the HPFP replaced. Temps have ranged from 20F - 90F. We'll see again when it gets into the Hotlanta summers.
dhuang is offline   Reply With Quote
The Following 2 Users Say Thank You to dhuang For This Useful Post:
Asphalt TG (04-09-2017), stevesnj (04-03-2017)
Old 04-10-2017, 02:24 PM   #4974
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
It's been 4+ years and we still can't get a 100% confirmation this issue has been addressed and fixed? That's a shame.
2016 Camaro SS is offline   Reply With Quote
Old 04-10-2017, 03:04 PM   #4975
stevesnj
stevesnj's Avatar
Totally false, so far some have reported no chirps with the October 2016 TSB pump replacement in 80 degree temps. During the summer the reports of those, like me who had the pump changed in the winter, are waiting for the warm hot air temps. The warm temps are a necessary factor that caused the chirps. Be patient sir.
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
HunterGreene (04-12-2017), smg1138 (04-10-2017)
Old 04-10-2017, 03:19 PM   #4976
Anthonyc77
Drives: 2017 Toyota 86 Halo
3500 miles on my 2017 with no chirping. Perhaps the revised camshafts/fuel pump have fixed the issue for 2017 onward? (93 fuel only, mixed gas stations)
Anthonyc77 is offline   Reply With Quote
Old 04-10-2017, 03:21 PM   #4977
anthonybrz
anthonybrz's Avatar
Drives: 2017 Subaru BRZ
I'm About to hit 1,800 miles in my 17 BRZ and don't even have hint of crickets, even with high temps here in Texas. The car has run 91 and 93, all containing "10% ethanol." My 14 BRZ started having crickets at about 600 miles.
anthonybrz is offline   Reply With Quote
The Following User Says Thank You to anthonybrz For This Useful Post:
smg1138 (04-13-2017)
Old 04-12-2017, 02:44 PM   #4978
HunterGreene
Hail Magnet
HunterGreene's Avatar
3-400 miles on the new pump (Oct 2016 version), had cold and hot days, not a chirp. My original pump chirped between 2-300 miles.
It has priests in it?
Old 04-18-2017, 02:00 AM   #4979
Zoh
Drives: None
2017 with 7900 miles. Just started chirping yesterday/today.
That being said, I picked mine up at the end of August, so if there was a new HPFP in October, then idk. I thought the one from the recall was the same as the '17, but I could be wrong.
- Zoh
Zoh is offline   Reply With Quote
Old 04-18-2017, 10:29 AM   #4980
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Did you check the part numbers? I think some of the earlier 2017's may have gotten the older fuel pump. New pump should be SU003-07326.
smg1138 is offline   Reply With Quote
Old 04-18-2017, 10:30 AM   #4981
stevesnj
stevesnj's Avatar
Can you post an audio clip. The pump on the 2017 car is the same pump used in the TSB. I'm hoping you are hearing something else.
The Following User Says Thank You to stevesnj For This Useful Post:
smg1138 (04-18-2017)
Old 04-18-2017, 07:20 PM   #4982
Zoh
Drives: None
I haven't, and I definitely got one of the first 2017's in the country, from what it seems. Haven't heard of anyone in the USA with an older pickup date than mine so far. (8/28/16)
I'll see if I can check tonight. Is it easily visible?
- Zoh
Old 04-18-2017, 07:21 PM   #4983
Zoh
Drives: None
Yeah, I'm sure I can do that later tonight.
It sounded exactly like crickets though, so... Here's to hoping I have an older pump design since mine's an early '17
- Zoh
Old 04-18-2017, 07:44 PM   #4984
You just need to look at the top of the pump If it is flat it is a new type.
smg1138 (04-18-2017), stevesnj (04-18-2017)
Search this Thread:
Advanced Search
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) -- General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
