View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,100 85.21%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.79%
Voters: 3638. You may not vote on this poll
Old 11-04-2015, 12:08 PM   #4789
stevesnj
stevesnj's Avatar
Does this pump just supply the DI only?
My 2016 Build thread
Old 11-04-2015, 12:26 PM   #4790
Nope. Whole fuel supply.
stevesnj (11-04-2015)
Old 11-14-2015, 03:16 PM   #4791
AlexDiDino
Drives: 2016 Scion FR-S Steel
Less chirping since I changed to Chevron.
I waited until the tank was almost empty and filled the tank with the high grade Chevron and the chirping became less noticeable sometimes I do and sometimes I don't. While using the premium gas from the station I have used for years the chirping was very loud. My wifes Lexus 350-IC has no problems with it. I live in Las Vegas and cannot find a Sunoco gas station or gas without ethanol.
I do not drive the car much so I am almost ready to fill it up again. MY mileage is 750 miles. Any ideas?
AlexDiDino is offline   Reply With Quote
Old 11-14-2015, 03:44 PM   #4792
skribblez
Drives: 2015 BRZ
Have a 2015 model and fill either 91 or 93 from Esso in Canada. Haven't heard any chirps.
skribblez is offline   Reply With Quote
Old 11-14-2015, 03:54 PM   #4793
Drove it when it was really hot out though? Esso and 26+ degrees was always certain chirps for me. Shell or CT and never heard a peep outta the little guys. I know they are gone until spring now though.
Old 11-14-2015, 04:12 PM   #4794
skribblez
Drives: 2015 BRZ
Nope didn't a single chirp even at 26+ degrees. I'm sure the Esso from London, Ontario is the same in Markham, Ontario.
Old 11-14-2015, 04:17 PM   #4795
Oh I doubt that the Esso in the same station is the same from delivery to delivery. They have a pretty big margin they can work with and still be in "spec". I will never understand why one gas works for some and not other but we see it all the time on here.
Old 11-14-2015, 05:21 PM   #4796
Ultramaroon
fabulous
Ultramaroon's Avatar
Wait, wha? Are we talking about the cricket pump?
In-tank pump supplies all at high-volume, manifold injector rail pressure.
HPFP feeds off of MI rail and boosts pressure to feed DI rail.
Old 11-14-2015, 11:34 PM   #4797
stevesnj
stevesnj's Avatar
Well now im confused
Old 11-14-2015, 11:38 PM   #4798
Ultramaroon
fabulous
You were originally correct. The cricket pump feeds only the DI.
It takes its fuel from the low pressure rail feeding the manifold injectors.
stevesnj (11-14-2015)
Old 11-18-2015, 04:05 PM   #4799
Brayden_23
Drives: Asphalt 2015 FRS
When I bought my car new, no crickets for the first ~400 miles. After I changed out stock intake for Injen intake, had crickets almost always at idle. Now that I have about 3k miles, chirping only occurs on occasion. Been trying to figure out if there is a pattern for moments when it chirps and when it doesn't, but my research has been inconclusive thus far.
Brayden_23 is offline   Reply With Quote
Old 01-12-2016, 02:34 AM   #4800
AlexDiDino
I have been using Chevron 91, the highest available in my area, for almost 2 months now and the chirping has stopped.
Old 01-12-2016, 10:34 AM   #4801
HunterGreene
Hail Magnet
HunterGreene's Avatar
How many miles on your car now?
It has priests in it?
Old 01-12-2016, 11:24 AM   #4802
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Over 40k miles pumping 93 octane running OFT stage 1 tune. Don't remember last time I've heard a chirp.
Rican_D is offline   Reply With Quote
Search this Thread:
Advanced Search
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) -- General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
