| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,100 | 85.21% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.79% |
| Voters: 3638. You may not vote on this poll | |||
#4243 |
Drives:
Yes, my 2014 with 1800 miles, started making loud cricket noises around 1200 miles
Sent from my SM-N900T using Tapatalk |
#4244 | |
Hail Magnet
I'm not disagreeing with you from the fatigue standpoint--the pump may still fail. But, for something with such high tolerances with this engine, the PSI of the fuel pump has to stay pretty high, and if it was wearing that quickly, the car would be throwing codes like crazy due to improper fuel pressure at the injectors. My hypothesis at this point is that the crickets fading is due to normal wear of the pump. I'd also love to see two pumps pulled apart, one that used E0 all the time, another that used E10 and compare the wear. That would tell us immediately if there is a degraded performance. I'd love to know what the forecast lifetime of these pumps is supposed to be. |
#4245 | |
Drives: GTI, BRZ
#4246 |
Drives: 2013 Subaru BRZ
#4247 |
[QUOTE=strat61caster;1809730]I've noticed a resonance at 70-80, like the wind whistling over the mirrors but it goes away when I go faster, it doesn't get louder. So I'm not sure what you've got going on, might be the same, might not.
I can get the noise to stop with letting off the throttle, comes right back with light load and seems to quiet up with wot |
#4248 | |
Drives: around
The fatigue, if a factor, would come from the cyclic loading of those parts at resonance. If the resonating parts were the reed and seat of a check valve, something "might" eventually give up the ghost. Yes, I'm speaking entirely in hypothetical terms. I have zero idea what that pump looks like on the inside. Hunter, your point about error codes is duly noted. My last car had an OBD-I box. It's going to take a while for me to adjust my mental landscape.
| The Following User Says Thank You to litemup For This Useful Post: | HunterGreene (06-23-2014) |
#4249 | |
Hail Magnet
#4250 | |
Drives: around
But our high-tech super-duper ECM would detect all that, no? (NOT sarcasm) |
#4251 | |
Here's a 400+ page thread: http://forums.tdiclub.com/showthread.php?t=308323 On the gas engines the HPFP is driven off the camshaft and that interface can suffer premature wear that can lead to particles in the engine, seems less costly and more preventable: http://www.golfmkv.com/forums/showthread.php?t=73095 |
#4252 |
Drives: 2014 Ultramarine 6MT FR-S Monogram
Bought the car in February 2014. So far I can only hear the crickets when I'm outside the car when its running. I've only used 93 octane fuel (with 10% ethanol) since I bought it. Ethanol free fuel is just too far away to make it practical to fill up there.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
#4253 | ||
Drives: GTI, BRZ
There was also the issue with seals on the pump failing (as far as I know it was only on the cheaper aftermarket pumps) and causing fuel to contaminate the oil. Again, I'm not saying that's' even remotely like what's happening with these cars, but it took VW a long time to say it was anything other than an isolated problem, so I wouldn't exactly be surprised if Subaru/Toyota/Scion was doing the same thing. |
| The Following User Says Thank You to Lawn_Mower For This Useful Post: | strat61caster (06-24-2014) |
#4254 | ||
Drives: 2014 BRZ Limited
#4255 |
I can't believe there still isnt a fix to this. I also have the chirps on my 2013, and its loud enough that people look at me when im next to them at a red light.
#4256 |
Well after near 5000 miles of no crickets THEY ARE BACK. That would be on the 3rd replaced fuel pump. Not impressed with how they determined a normal functioning fuel system after they replaced the fuel pump. Sounds like they can't fix it so the "solution" is to default to "normal" for this car and engine.
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 02:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 11:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) -- General Topics | 49 | 07-02-2012 04:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
