| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,100 | 85.21% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.79% |
| Voters: 3638. You may not vote on this poll | |||
#2703 |
Drives: BRZ Limited Rally Blue
Fix your crickets
I wanted to give everyone a heads up on what worked (and more) for me.
My crickets started very early on- I don't remember exactly. Between about 1800 and 3300 mi. though they got to the point of ridiculousness. Probably worse than most from what I can glean from the forums. That led me here. I took it into the dealership and sure enough they ordered a pump. I'm waiting on parts. They said it is an improved deisgn- we shall see. My noise was so loud I'm concerned that there may have been degradation to the HFDP. Anyhow, I'll get the new pump installed just in case. .....---In the mean time. 1 bottle octane booster + a tank of 87 straigh gas (0%ethanol). put into about a quater tank of 93 10% ethanol. AND THIS IS IMPORTANT. I read the lexus forums that this thread referenced and bout a quart of the TWC3 Quicksilver premium synthetic blend marine 2 cycle oil. VERY CAREFULLY added it to the fresh tank strictly following 1oz. per 5 gallons of gas. The car drove well on the way home- still making noise. Next morning I got up and started her up and let it idle all the way to warm up. Cleaned the windows while this was going on. Odd....no crickets. Opened the hood up- nothing AND the whole engine was running smoother than a baby cricket's ass. Since day one I thought the engine felt like she wanted to fly apart with the hood up. Figured this was a boxer thing...not anymore. So then drove her into work. Not a chirp. Idle is PERFECT at 600 rpm. Engine is so quiet at stop lights with the windows down I almost can't hear the engine. My pulls are noticeably stronger and more responsive. I feel like I'm not driving the car I bought at all now. I was losing so much power and driveability to this problem. Even my main belt and pulleys just roll around visually smoother and quieter. My next test will be adding the oil to a full tank of 93 10% ethanol. I have little doubt this will work just as well. My roomate put the 2 cycle oil in his Evo 9 MR and within a few minuets his rough idle was gone. I will forever put this in every tank of gas in every vehicle I ever own again. This is what I did, and will continue to do. It worked for me. Good luck!! That noise was unexceptable. [I live in souther MS so we have heat and humidity every day]
#2704 |
Drives: BRZ(sold), STI
My replacement pump #3 (the one with the colored dot on the box that I verified myself) just started chirping again, after ~3months and 1.5k miles. So, I'm gonna predict that yours will too.
#2705 | |
Drives: BRZ DGM Limited
Now at 6400 miles the idle is smoother and smoother each day, with no crickets. And this is with 92 octane 10% alcohol gas. |
#2706 | |
Drives: 2013 frs
Doesn't 87 gas contain 10% ethanol? And 91 and higher contain 0%?? When I go to shell I always use shell v power 91 and it says contains 0% ethanol? |
#2707 |
Drives: Raven FR-S MT
Most of the stations around here will carry 91 or 93 octane e10. There's just a handful of zero-ethanol stations, and one or two of them have 93 zero e.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT 1978 Triumph Spitfire 1500 ---------------------------------------------- ![]() |
| The Following User Says Thank You to userjack6880 For This Useful Post: | Young_makaveli (09-06-2013) |
#2708 |
in my area, the only e0 I can find is straight 87 octane. None of the Shell stations near me have any ethanol free gas at any octane rating. I'm sure this changes depending where you are....
| The Following User Says Thank You to phalacy For This Useful Post: | Young_makaveli (09-07-2013) |
#2709 | |
There are exactly 5 gas stations that are ethanol free in California according to that pure gas site everyone links. In any case ethanol is a band aid, over a year in and no pump failures. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Young_makaveli (09-08-2013) |
#2710 |
Drives: 2013 frs
Just hit 1000km and still no chirping or crickets
![]() Fingers crossed |
#2711 |
Drives: ‘22 BRZ Limited
Mine hasn't been chirping much at all lately. I'm at around 4,500 miles. Seems to have gotten quieter over the last 1000 miles. Still getting either shell or mobile 93. Maybe it's just the cooler temperatures.
#2712 |
SCBYD0
Drives: 18 BRZ (WRB)
Mine chirps but it isn't too bad. Have had it since the early stages of the 1K break in period.
Most times it begins chirping after the car has completely warmed up after X amount of miles when going out. When i'm running low on gas it oddly goes away until i fill up. |
#2713 |
Drives: 2013 Subaru BRZ Sport-Tech in White
Dealer has replaced my pump and so far so good. I stick to Shell 91
#2714 | |
Drives: 2013 FR-S (RIP), 2017 Toyota 86
I've been running Shell VPower 93 since day one and the crickets have only been getting louder. Pretty sure it has 10% ethanol. |
#2715 |
For a lot of people the noise just goes away, mine has 13k miles, original pump, all 91 E10 and it's almost gone, most people don't hear it and think I'm crazy.
#2716 | |
Drives: FR-S 10-series #405
I have been running Shell 93 from the Chicagoland area since the beginning, and did indeed develop crickets after the first tank in my 10 series. (There are no gas stations nearby that sell pure gasoline).
As I was researching that, I came across other potential additives. These seems to address the problems introduced by ethanol directly: http://petelandrysrealgas.com/2013/0...ive-of-choice/ http://www.channel3000.com/news/Brig...z/-/index.html http://www.briggsandstratton.com/us/...fuel-treatment I'm wondering if moisture in the gasoline is causing the crickets, and if these "water displacement" additives approach might be an ideal solution. (Curious, oil displaces water too...I wonder how much different the net effect is anyway, say compared to the 2-stroke oil...) |
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 02:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 11:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) -- General Topics | 49 | 07-02-2012 04:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
