| View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up? | |||
| Yes (Please only vote after you have 300 miles or more on the odometer) |
3,100 | 85.21% |
| No (Please only vote after you have 300 miles or more on the odometer) |
538 | 14.79% |
| Voters: 3638. You may not vote on this poll | |||
#169 |
Drives: Skoda Yeti DSG diesel 4x4
I haven't seen it mentioned on any Australian forums.
I have seen it mentioned that US diesel is some of the lowest quality in the world, unless that's changed with the new diesels being sold there recently? Maybe the past low tech nature of the engines because fuel consumption, with the cheap fuel, hasn't encouraged change, means the fuel standard needs to be upgraded to suit modern engines? Last edited by sierra; 07-09-2012 at 04:00 AM. |
#170 |
Drives: '13 Ultramarine
I have been using Sunoco/Petro Canada Ultra 94 gasoline, which contains "up to 10%" ethanol. On my next fill, I'll try Shell 91 which contains no ethanol, and see if it makes any difference. I have some good 2-stroke oil here, but I hesitate to try this in case it causes an issue with the catalytic converters.
| The Following User Says Thank You to roddy For This Useful Post: | excited86 (07-09-2012) |
#171 |
Drives: Waiting for the ND Miata
Some people either don't notice (have the stereo crank way up) or the chirping noise just haven't started yet.
#173 |
Drives: White 86 GTS AT
Can understand you missing it but I have made mention of it: LeftFootBrake's White GTS AT
#174 |
Drives: white frs auto, 02 corvette mn6
I havent noticed the noise but I did fill up with 100 octane onthe second fillup and I never let it get below a half tank
#175 | |
Drives: none
Is petro canada ulta 94 giving you problem? |
#176 | |
If it's squealing at idle because it's dry can you imagine what it's doing at normal rpm? You make the auto sound a good thing. |
#177 | |
Drives: none
#178 | |
Just get a good quality racing oil and use a much smaller amount. What could be better??? |
#179 |
give us this day
Drives: AE86 - FRS
So has anybody whos experienving the chirping tried using higher octanes? did it go away?
#180 |
Drives: none
This is a logistic nightmare. So I have to put some of this everytime I fill the tank?
#181 |
Ef Arr Ess
Drives: Ablaze MT (2016)
Should I take back my deposit and wait for a fix on this?
That chirping sounds awful to me... |
#182 |
Drives: Honda Fit
I really, really dislike this option. Is everyone who is promoting the It's-the-lack-of-lube-in-USDM-gas theory content, then, with the idea that the BRZ-FRS appears to be the only direct injection engine in the US that has a problem with USDM gasoline? Does this make sense? |
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 02:06 PM |
| Video of chirping at idle | Julio86 | Engine, Exhaust, Transmission | 15 | 02-01-2013 11:37 AM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) -- General Topics | 49 | 07-02-2012 04:45 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
