#15 |
Drives: 2016 Halo FRS
Get a louder exhaust and some hello kitty stickers
#16 |
If the TOB is turning all the time, as mentioned above, then that's just a shit poor design.
| The Following User Says Thank You to White64Goat For This Useful Post: | rice_classic (12-11-2015) |
#17 | |
However, you must have a high quality bearing .... ![]() Back in the day, when the TOB retracted, every time it was called upon to do its thing, it was cold and stationary and got slammed up against the nasty fingers of the pressure plate ...... that were rotating at engine speed. Musta felt kinda like this ..... ![]() humfrz |
#18 |
Drives: 10 Series Scion FR-S
My TOB is making noise as of late, I just ordered a TOB from rockauto for 36 bucks and may replace it during winter vacation.
#19 |
Drives: 2013 Brz C38 (bought not built :P)
I'll have to change mine in the summer but thinking I'll go with the ACT heavy duty one (hopefully it's made of stronger material, more resistant)
#20 | |
Drives: 2014 BRZ Limited
Does this require dropping the transmission? I'm having a squeak after I depress a warm clutch so I'm guessing. Replacing the throws it bearing could help. |
#22 |
Off Topic
| The Following User Says Thank You to gramicci101 For This Useful Post: | zc06_kisstherain (08-16-2016) |
#23 | |
The clutch fork can be somewhat lubricated without removing the transmission. The transmission (or engine .... ) must be removed to change the TOB (Throw Out Bearing). humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | jcw99 (08-18-2016) |
#24 |
Drives: Argento>FRS
I took mine in 1week ago for that squeaky clutch. Dealer replaced TOB . Now I have this annoying rattle at 1st gear when coming up on rpm, goes away above 2k rpm..told the mechanic the same day and he said let it wear out for a couple of weeks and if its still there bring it back in.
| Melted Throw Out Bearing | danthedirt | Issues | Warranty | Recalls / TSB | 59 | 01-25-2018 06:32 PM |
| Throw-out bearing | mhigham | Issues | Warranty | Recalls / TSB | 71 | 08-18-2016 11:21 AM |
| throw out bearing clips... | Shit Luck | Engine, Exhaust, Transmission | 0 | 04-12-2014 07:34 PM |
| FS: NJ O.E.M. Clutch, flywheel, throw out bearing | Michaeljp92 | Transmission and Driveline | 9 | 02-04-2014 12:42 AM |
| Throw out bearing/Left Front speaker/Paint Chips | 2014scionfrs | Issues | Warranty | Recalls / TSB | 11 | 01-06-2014 12:20 PM |
