#15 |
Drives: '15 FRS
My car(s) start reliably at freezing temps on E85.
Just takes a little work... lol |
#16 |
#17 | |
Drives: '15 FRS
80-82% off the flex sensor. Only time I had an issue when the car was on ECUTek is when it sat for a few weeks and I let the battery drain down. In fact, as I recall, it wasn't really all that hard to have the car start reliably every morning last winter -- it's been more work on the MoTeC since I had to start from scratch all over again, lol. Some advice: all that extra fuel you're dumping in for cold starts during cranking isn't doing anything for you without the proper ignition timing during cranking -- which can be drastically different at high ethanol content than on pump gas. |
#18 | |
I would be pretty confident dropping the e percent down to 80 would see it firing reliably at lower temps, buy will look into the cranking timing |
#19 |
Drives: '15 FRS
Heh, E98 is what the race car drinks, starts just fine in 40-45* winter shop temps before we turn the heat on. It's quite cold out here in the winter and I don't have any problems firing cars up on any ethanol content :p
#20 |
Time Traveller
Confirmed (for a while now) adding 1-2 gallons of CA91 to 9 gallons of e85 resolves any cold start issue. Will probably still update the cranking tables sometime or another.
#21 |
Drives: 2014 Subaru BRZ
It took me roughly 2 hours yesterday to fiddle with RomRaider and modify the OFT tune with the new cranking values. I was able to start my engine today in 40-50F with 1 crank. I've had to crank 3-5 times the day before. I highly recommend modifying your tune (it's super easy) and save you the troubles.
| Random tip - cold starts | Dammod | AFRICA | 34 | 09-22-2015 02:38 AM |
| Strange beep sound from engine on starts | fanaticalz | Issues | Warranty | Recalls / TSB | 5 | 05-19-2015 02:10 AM |
| Did I damage or hurt my engine ? | tonychet2 | Engine, Exhaust, Transmission | 32 | 03-11-2015 08:35 PM |
| Cold morning starts | coldy | CANADA | 43 | 04-23-2013 03:30 PM |
| Issue: Cold starts | jesseps | CANADA | 7 | 11-24-2012 12:26 PM |
