Old 11-23-2015, 07:40 AM   #15
ollie
ollie's Avatar
Drives: GT86
Originally Posted by Cedars View Post
Also another question, the car I bought is branded as TRD GTX, white (thats all that was available) with a TRD kit fitted locally, problem is the kit is probably 2015 and under white and the car is a 2016 mettalic white, there is a slight difference in color, which I didnt notice when I bought it, its a bit of a drag and unexcpected (zero mileage) am in the process of checking with the dealer what can be done. Now my question is, would you recommend I repaint the kit (dunno if thats possible) to the exact same color? Cover it with some sort of a decal? Or just forget about it?
You will never get a 100% same finish, that's why most smash repair companies alway say they can't match it exactly. Mine was painted in orange and they got pretty close.
ollie is offline   Reply With Quote
The Following User Says Thank You to ollie For This Useful Post:
Cedars (11-23-2015)
Old 11-23-2015, 07:48 AM   #16
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
@Cedars
Please post some pics of your car, we'd love to see it!
Old 11-23-2015, 07:51 AM   #17
Cedars
Drives: gt86
Originally Posted by Sarlacc View Post
@Cedars is this your car?
Hi, nope that's a Dubai plate mine is an Abu Dhabi plate but otherwise looks exactly the same, notice the slight color difference? I have the exact same.
I'll try and post some pics for you.
That kit belongs to the 2012/2015 gt86 white while the 2016 is a slightly different color.
Cedars is offline   Reply With Quote
Old 11-23-2015, 07:56 AM   #18
Cedars
Drives: gt86
One more thing, red light comes on at 7400 rpm and cut off at 8200 or 8400 rpm right? That's the standard?
Old 11-23-2015, 08:26 AM   #19
1st86 Driver!
Originally Posted by carma143 View Post
I'm personally very against this "safety" feature. In my experience of watching others people on the road get frustrated, they either hold up traffic by stopping to put down an address or take out their phones and try to navigate by that instead. MUCH more dangerous if you ask me.
Depending on the headunit you have, the voice navigation should work. I have the 2014 Panasonic headunit in my 2013, and the command:
"Destination <street number><Street name><City><State>" (US obviously) works almost 95% of the time. The "Find Next" and then a point of interest works about 70% of the time although can be a little frustrating.
Old 11-23-2015, 08:46 AM   #20
xmadror
Drives: BRZ Sport Tech 13
Could it be the nav is locking after I start moving? Interesting.
Thanks a lot.
My '13 brz sport tech nav will only be unlock if the parking brake is on, otherwise it's always locked.
Also, if I open my door before turning the engine off I get the beeping, but not if I turn off the engine 1st and then open the door.
xmadror is offline   Reply With Quote
Old 11-23-2015, 09:17 AM   #21
Cedars
Drives: gt86
That could be it. Turn off engine then open door = no annoying beep. Open door then switch off engine= annoying beep. I'll try it.
Old 11-23-2015, 09:20 AM   #22
Well now... Hmmmmmmm
Red line is 7,400.
Keep going to 8,200 or 8,400 and yes, the red light will go out.
Eventually, forever (or at least until you put a new engine in)
Did your car not come with an owner's manual? If not you may want to get one. If so you need to give it a read. Soon!
Old 11-23-2015, 09:21 AM   #23
The beep is there to tell you that the fob is still in the car and if you are opening the door before shutting it off it thinks you are leaving.
Who opens their door and then shuts off the car every single time anyway??????
Old 11-23-2015, 09:28 AM   #24
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Cedars, I had a feeling you had a GTX 86.
As long as you don't believe that there are any power differences, you're all good.
Old 11-23-2015, 09:29 AM   #25
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
I realized that the plates were from a different country, so I changed my post before I saw you had replied.
We discussed the color difference on that Dubai car briefly.
Before the owner was banned from the forum and the thread was deleted.
Not to worry though, your posts are on a whole other level so far
I personally would argue that the problem is that the white color has changed between model years, and the only solution I would accept would be if the dealer plucks off all the body kit stuff and respray them before putting them back on.
If the parking sensors are a different color too (as they seem to be on the Dubai car) those should simply be replaced with new ones in the correct color.
Old 11-23-2015, 09:39 AM   #26
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
??!!!???!!?????! Is this a serious question? Friend, the red light isn't the ONLY thing that's going to cut off at 8400 if you keep taking the engine that high.
You can adjust when that red light comes on; it's purpose is to warn you that you are approaching the engine's redline .. the "never exceed" rpms which on ours is 7500. Read the manual or search this forum and you'll find a procedure that will allow you to set that light at any RPM you wish. I'd suggest going a little lower than 7400, ESPECIALLY if you're used to taking the car up to 8400!!! Set it at 7000.. heck, set it at 6500 as sort of aversion therapy.
Barry
MuseChaser is offline   Reply With Quote
Old 11-23-2015, 09:46 AM   #27
KR-S
Sporadic Member
KR-S's Avatar
Unless OP did some serious money-shifting to the engine, the engine RPM cutoff is at 7400 RPM. I wouldn't worry about it unless OP's car had its cutoff raised somehow or he's constantly banging on the car 7400 RPM.
The Following User Says Thank You to KR-S For This Useful Post:
Cedars (11-23-2015)
Old 11-23-2015, 10:01 AM   #28
Cedars
Drives: gt86
Hi Thanks for that. So you think they can repaint the bumpers? Is it doable on bumpers? Dont they have to strip it down to the aluminium or carbon first, or do
they just repaint the thing on top of original?
Search this Thread:
Advanced Search
Is this normal in the OFT?? benlaz88 Software Tuning 4 12-04-2014 10:23 PM
Is this normal? BlackyRose Engine, Exhaust, Transmission 8 10-04-2013 12:54 PM
Is this normal? ArKiTeCkT Engine, Exhaust, Transmission 3 10-29-2012 03:54 AM
Is it normal to see a .... Mango22 BRZ First-Gen (2012+) -- General Topics 10 10-12-2012 03:54 PM
