#113 |
Drives: Late 2014 Subaru BRZ
Um, boost by gear would be an EVAP delete and a EBC with a custom map from a pro I'm assuming? ECUTEK of course.
I really wish tuners would talk about this more. This could save so many transmissions lower gears. I don't need 20 psi in my first three gears FFS. Let's keep this going, I really like.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#114 | |
Drives: '15 FRS
3rd gear WOT at 17psi on E60 fuel. Needs more power IMO, lol. [ame="https://www.youtube.com/watch?v=IjJTNwoe9_o"]FT86 FRS 3rd Gear Pull - YouTube[/ame] |
| The Following User Says Thank You to VitViper For This Useful Post: | GhostOp86 (04-28-2016) |
#115 | |
Drives: 2013 Asphalt FRS
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#116 |
Drives: '15 FRS
| The Following 3 Users Say Thank You to VitViper For This Useful Post: |
#117 |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
I just picked up a gen 2 64/66, I know Justin has a gen 2 6266 that he absolutely loves and makes great power with
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
| The Following User Says Thank You to #maverick# For This Useful Post: | FRS Justin (04-28-2016) |
#118 |
Drives: '15 FRS
I use primarily Comp. Although I have had good luck as far as making power with the Gen2's -- customer's S2000 made 700 wheel on the Gen2 6262 at 21psi lol.
#119 |
Yea the new Gen2s are outstanding I just found I have to use a .030 restrictor with my -4AN line in addition to the internal restrictor so I dont blow out the seals. These BB dont need that much oil. My 5858 is on its second rebuild lol. Thinking back I shouldve just used a -3AN line lmao
| The Following User Says Thank You to #maverick# For This Useful Post: | FRS Justin (05-03-2016) |
#120 | |
Drives: Built FA20
It has nothing to do with the tune when your mechanical parts simply fail. |
| The Following User Says Thank You to nickw14 For This Useful Post: | blueap2 (05-03-2016) |
#121 | |
Road-hole
Drives: 2013 Whiteout FR-S
sorry...
Jaden |
| The Following 3 Users Say Thank You to Jaden For This Useful Post: |
#122 |
Dismember
Drives: 2013 Red Scion FR-S
How you drive also matters. Flooring it above 3500rpm probably makes a huge difference. At lower RPM, the stresses hit each part for a longer period of time. At 3500rpm, the time spent under pressure is probably half that of 1750rpm. Peak cylinder pressure doesn't last as long. Of course, at 7500rpm, you've got a lot more heat building up. That again is also a matter of how the car is driven. If you're going up to 8000rpm once, it's not a problem. If you're on the track and slamming the car to redline, heat builds up.
And then there's the tune. And then there's maintenance. And then there's luck.
#123 |
Drives: Built FA20
But there IS an inherent weakness in construction. Most people blame the tuner because it is the most logical thing to do initially. But when you tear your engine down and you see a rod snapped in half, yet your car was running fine just a few days ago, how can you still say you had a bad tune? I understand very well how tuning works, and I understand that small imperfections can wreak havoc on engines after periods of time whether short or long. However, the FA20 is known for having weak rods. Ask any shop that has tested the limits of the engine, or who has build these engines. They will tell you the same thing.
| The Following 3 Users Say Thank You to nickw14 For This Useful Post: |
#124 | |
Road-hole
lol...
When you have people that break rods on stock cars and you have others that are running for tens of thousands of miles on 400whp builds, you have to ask what is more likely, that there are a few cars that had poor quality control and got defective rods, or that there are a couple of cars that got exceptionally well made rods and HAPPENED to boost those cars with the exceptional rods? IMO, the most likely scenario is a combination of there being some defective rods out there AND there being some bad or marginal tunes out there. Any time you're boosting a 12.5 CR engine, tuning becomes precarious. If every boosted car was bending and breaking rods and stock cars WEREN'T, then you'd have a point. As it stands, I don't see this as being a likely case. Jaden |
| The Following User Says Thank You to Jaden For This Useful Post: | pgranberg11 (05-04-2016) |
#125 | |
#126 | |
Road-hole
the same way I explain stock twins blowing...
Jaden |
| The Following User Says Thank You to Jaden For This Useful Post: | FRS Justin (05-04-2016) |
| 2013 White Turbo FR-S (450whp) (Update) (For Sale Again) | Synack | Cars for Sale/Trade | 40 | 02-27-2016 01:55 AM |
| 2006 STi 450whp $25000 | JoeShmoe | Cars for Sale/Trade | 0 | 08-28-2014 05:46 PM |
| 450whp Turbo FRS - TR3 Performance | JPxM0Dz | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 02-19-2014 01:40 PM |
| Auto-Craft Japan Turbo FT86 | BPAuto | Forced Induction | 5 | 05-21-2013 11:57 AM |
| ft86 turbo RWD or AWD? | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 01-18-2010 05:11 AM |
