86WORX
Old 06-09-2016, 01:23 AM   #225
VitViper
Drives: '15 FRS
I was like, hm, wouldn't it be cool if your ECU could calculate effective power (meaning power that actually moved the vehicle -- so if you're spinning you're not winning). And voila, another feature is born.
Just a little FRS on E40 fuel at 13psi. Given the car made 460ish on E76 on 15-16psi, it's pretty damn close (bear in mind "effective" power, some is lost through tire slip, etc, before the vehicle is accelerated).
You can see me switching gears and putting around...
VitViper is offline   Reply With Quote
The Following 2 Users Say Thank You to VitViper For This Useful Post:
CSG Mike (06-09-2016), johan (06-09-2016)
Old 06-09-2016, 06:47 AM   #226
FRS Justin
Drives: 2013 Asphalt FRS
YOU HAVE MY FULL ATTENTION!!!!
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 06-09-2016, 12:41 PM   #227
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Ah, Motec. I love how inexpensive you are.
Old 06-09-2016, 01:49 PM   #228
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
its been money well spent for my build. i wish it did it from the start rather than dealing with e-tunes, flashing, not being able to alter anything on my ecutek tunes, etc.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 06-09-2016, 03:04 PM   #229
VitViper
Drives: '15 FRS
This. So much this. No matter how good a factory ECU based system is (and ECUTek is quite good), it's never GREAT. With the MoTeC you knock down all the hurdles and finally take control over what you want to do. It just doesn't compare, and until someone's experienced it themselves they just can't comprehend it. Hence lots of "it works bro" keyboard warriors online. A carburetor works too bro!
The Following 3 Users Say Thank You to VitViper For This Useful Post:
CSG Mike (06-09-2016), Decay107 (06-09-2016), FRS Justin (06-09-2016)
Old 06-09-2016, 06:00 PM   #230
VitViper
Drives: '15 FRS
I added the ability to do some factoring to smooth out the HP/TQ generated by the calculations (you can still view instantaneous).
Then I tossed her on the dyno for some touch up and turned her up a notch. Looks like I'm bottle-necking at the 2.5" overpipe finally, the VE/fueling is starting to show it.
Here's a fun comparison. The only thing different in these 2 plots is I turned on the port injection. On the plot that was jiggity (solid) the DI injector was being run at 7.7ms. As you can tell the motor absolutely does not like it.
Old 06-09-2016, 06:12 PM   #231
johan
Drives: '14 981CS, '99 NB1
That big ass turbo is saving your engine lol.
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
Irace86.2.0 (12-13-2022)
Old 06-09-2016, 06:22 PM   #232
VitViper
Drives: '15 FRS
I like it lol
Old 06-09-2016, 07:49 PM   #233
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
You personally have more faith in the factory rods than I will ever. One thing is for sure is I didn't see any gauges. I had a hard time finding a mount and gauge combo until I found my CravenSpeed steering column mounted Pods. I only use the left pod but you can run 2 if need be.
I'm not sure if you're still in the market. If covers the pointless analog speedo paired with the AEM failsafe boost/AF gauge.
http://www.cravenspeed.com/the-flexp...unt-for-scion/
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 06-09-2016, 07:52 PM   #234
VitViper
Drives: '15 FRS
Why would I need gauges?
Old 06-09-2016, 07:56 PM   #235
GsxrMe
GsxrMe's Avatar
You don't need anything, but more of peace of mind when using it as a daily driver like me. I got mine to kill my ignition when my A/F or Boost is out of its programmed limits.
2014 Subaru BRZ
Old 06-09-2016, 08:19 PM   #236
VitViper
Drives: '15 FRS
I think you're missing the point... LOL. My car is on my own custom MoTeC programming. It's doing anything and everything you can imagine and much more than some gauges which I find quite ugly will ever do for you. I've ripped all that garbage out of all our other cars when I've installed MoTeC systems in them as well haha.
The Following User Says Thank You to VitViper For This Useful Post:
e1_griego (06-09-2016)
Old 06-09-2016, 08:35 PM   #237
VitViper
Drives: '15 FRS
I added some factoring to give you a more smoothed out view today. As the instantaneous calculations have lots of spikes (for obvious reasons). How much to factor is set by the user (and obviously factoring too much can "lower" the power estimate -- but hey, it's just an estimate!)
Old 06-09-2016, 08:49 PM   #238
johan
Yo dogg, this proves your dyno reads high #poser #internettroll #fake
The Following 4 Users Say Thank You to johan For This Useful Post:
DustinS (06-24-2016), thehapaone (06-09-2016), Ultramaroon (06-11-2016), VitViper (06-09-2016)
2013 White Turbo FR-S (450whp) (Update) (For Sale Again) Synack Cars for Sale/Trade 40 02-27-2016 01:55 AM
2006 STi 450whp $25000 JoeShmoe Cars for Sale/Trade 0 08-28-2014 05:46 PM
450whp Turbo FRS - TR3 Performance JPxM0Dz FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 02-19-2014 01:40 PM
Auto-Craft Japan Turbo FT86 BPAuto Forced Induction 5 05-21-2013 11:57 AM
ft86 turbo RWD or AWD? CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 31 01-18-2010 05:11 AM
