#212 | |
Road-hole
Drives: 2013 Whiteout FR-S
That's not what I said...
THAT'S WHAT I said...and there is a finite amount of air that can fit in a 2.0l engine. If you aren't adding oxygen in some other way, you will not be able to generate past a certain limit at a given boost... otherwise, where are the 350hp 2.0l engines at 5 psi? Sure, if you completely rebuild the engine with titanium everything and run 14:1 compression at 7 psi of boost, you just might get a 2.0l engine making 500hp... with gigantic valves, etc... That's not the argument though. I didn't say that the math I gave was comprehensive, but it should've done the job at showing the finite-ness of displacement. That's great about your 1 litre motorcycle engine making 200hp N/A... I'd be willing to bet dollars to donuts that if you turbo that bike at 7 psi, you won't get 400hp out of it either...don't care how big the turbo is, not without additional oxygen enrichment. Jaden |
#213 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
I am saying that NA horsepower is not a consistent indicator of how an engine will perform when turbocharged. I am not disputing that a fixed amount of air can enter a 2 Liter engine. That is true. I am saying, throw out the NA rules when you turbo the car. If you could take the car and run it (naturally aspirated) in big chamber where the ambient pressure was Sea Level ISA + 7 PSI (21.7 Absolute), and you took the same car and turbocharged it at sea level to 21.7 PSI Manifold Absolute Pressure, you would get different horsepower numbers. You would also get different Manifold pressure numbers. Intake and exhaust port velocities would not match. IAT's would not match. That was why I tossed in the comment about valves. The guys over at Element make power all the way to 9K RPM. How? The powerband levels off and starts to suffer after 7K. Upsized valves. That's it. Turns out, +1mm intake and exhaust actually cost NA horsepower, but can help maintain high volumetric efficiency on a turbocharged engine more than 2000 RPM after VE peaks NA. NA flow, and thus HP, does not correlate consistently to turbocharged Flow, and thus HP. Yes, you are right, there is only so much air you can pack in to 2 Liters and thus, only so much fuel you can burn and so much energy you can extract. There is a ceiling on power. That ceiling does not begin and end with "Boost" 7 PSI isn't always the same 7 PSI. There are reasonable limits on this as well. But perhaps most Interestingly, your argument hinges on the idea that airflow is the sole determinant of horsepower. Airflow is actually a rather minor variable. Ask the people who run 2:1 stoichiometric on nitromethane. Airflow determines only how much fuel you can burn. That's it. How much fuel you burn per horsepower generated is called Specific Fuel Consumption. If you can lower the SFC, (this is where the fun, and the tuning, starts) you can make more HP on less boost. If you can maintain the same SFC as you enrich the mixture, you can make even more. This is why Ethanol makes this argument so interesting ......And not just because I'm drinking on a day off. And for sh*ts and giggles, no, the bike wouldn't make 400 HP on 7 PSI. It didn't even displace 1 liter. It displaced 636 cc's or .636 liters, and made 130.5 HP. (Math says 130.5 hp / 0.636 L = 205.1 HP/L ) Do I look like the kind of douchebag who would drive a liter bike? Don't answer that. Or do... Hell with it.
Inline 4 is best 4
There are many ways to displace. -Spartarus |
#214 | |
Road-hole
I know this...
I said the exact opposite of 7 psi being 7 psi in multiple threads and multiple times (including this one, BTW). I also KNOW that you can't use N/A at sea level to accurately assess what the car will do at a given F/I boost level, but you CAN use N/A at whatever to get a good damned idea as to what the MAX you're going to get at 7 psi is though. I will stick by my offer for anyone to show me a car that makes more than 65% of the power it makes at ambient air pressure at 7 psi of boost with any turbo and no changes to valving(valve sizing not VVT, I don't care what they do with VVT), other oxygen enrichment, etc... The argument that started this WHOLE thing was someone asking what if they told me that they could pop a big turbo on a twin and make 500 hp at 7 psi... My response was that I said it would be impossible. I still stand by that. I don't care how big of a turbo you pop on a twin, you will not make 500 hp at 7 psi of boost without some other type of oxygen enrichment...or completely building the engine to specifically allow a ton more airflow. Jaden |
#215 | |
...Just add nauseum
I am saying you can't. You can guess a median power figure, but that is a coincidence only, and is due to the logic most companies use to size the turbos for their kits... And it's becoming less true as technology moves on. It's like guessing top speed based on OEM tire width. A linear correlation may even exist! But if it does, it's a coincidence. I used the upsized valving as an example to illustrate just exactly why you can't use NA HP as a "max" figure. Changing nothing else about the engine, the two "maximum potential" numbers diverge. The OEM car wan't shipped with perfect sized valves and runners for performance, what if they had been upsized or downsized from the factory? "Show me a car" Ok then, Just off the top of my head, Dustin at Dynosty with the 3SGE BEAMS swap. Unopened stock engine, 11.5:1 compression, no direct injection. Stock makes 197 BHP, about 159 WHP. They made 330 WHP on pump gas at 8 PSI, at the stock rev limit, and published the numbers. The NA WHP is about 48% of the turbocharged WHP. Far shot better than 65%. Chris at Speed by Design made 277 WHP on an FRS that baselined at 163 WHP. That'd make the NA HP 58% of the turbo HP. Again, pump gas. See here's the thing. I understand you stand by your statement with reagard to making 500 HP @7 PSI. You may be right, you may be wrong. Regardless, my point is whether or not you are, it's an unsubstantiated guess, not grounded in any sound mathematical principles. You're gambling. Once again, if you want to learn, I have time to type. I can make the math work for 500 HP at 7 PSI. will the fuel, engine, and turbo keep up? Dunno, that's what experimentation is for. That's why tuners make money. I know my turbo won't make 500 on 7 PSI, but it's little, and it's old, and it's not very efficient, but it'll kill the 65% guess dead dead dead. To address your last point, upsizing the valves can be done accurately in a garage with a Grizzly Mill and some carbide cutters, that cost less than your turbo kit. It does not constitute completely building the engine, it's a relatively minor modification. That's why I selected it as an example... And the Griz because it's what I use.
Inline 4 is best 4
There are many ways to displace. -Spartarus Last edited by Spartarus; 05-17-2016 at 10:20 PM. |
#216 | |
Drives: '15 FRS
500hp on 7psi is possible on a 2L engine. Regardless of how much you want to continue arguing this point, you still went completely off topic and out of context with my original post -- seems like a situation of "nothing else to see here so let's steer the ship somewhere else". |
#217 | |
Drives: '15 FRS
No homo. |
| The Following 5 Users Say Thank You to VitViper For This Useful Post: | Decay107 (05-18-2016), Jmonty (05-19-2016), johan (05-18-2016), Spartarus (05-18-2016), Ultramaroon (05-18-2016) |
#218 |
Drives: Asphalt FR-S MT
| The Following User Says Thank You to kcam86 For This Useful Post: | nickmerronesucks (06-09-2016) |
#219 | |
Road-hole
Great on you.
Just throwing a bigger turbo on the car and calling it a day is not going to make more than 65% more power. The whole point yeah I mean you can bring up examples of people that made a huge major breathing modifications to the cars and produced more than 65% more power and that still doesn't negate my argument which is that just throwing a bigger turbo on it will not let you make a bunch more power unless you have the ability for the engine to breathe that much more air. |
#220 | ||
Drives: '15 FRS
Not sure if I can use plainer English to make this statement? |
#221 | |
Road-hole
I agree with you...
I unequivocally agree with you on that point, it doesn't matter if the engine can't take the stress of 500whp... Jaden |
#222 |
Dismember
Drives: 2013 Red Scion FR-S
Meanwhile, I believe some people are running around with 500whp and stock internals. Just saying. maybe they're not running forever, but they're running!
#223 |
Drives: '15 FRS
#224 |
Dismember
[ame="https://www.youtube.com/watch?v=_Jtpf8N5IDE"]Queen - Who Wants To Live Forever (Official Video) - YouTube[/ame]
| The Following User Says Thank You to EAGLE5 For This Useful Post: | GhostOp86 (05-18-2016) |
| 2013 White Turbo FR-S (450whp) (Update) (For Sale Again) | Synack | Cars for Sale/Trade | 40 | 02-27-2016 01:55 AM |
| 2006 STi 450whp $25000 | JoeShmoe | Cars for Sale/Trade | 0 | 08-28-2014 05:46 PM |
| 450whp Turbo FRS - TR3 Performance | JPxM0Dz | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 02-19-2014 01:40 PM |
| Auto-Craft Japan Turbo FT86 | BPAuto | Forced Induction | 5 | 05-21-2013 11:57 AM |
| ft86 turbo RWD or AWD? | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 01-18-2010 05:11 AM |
