Old 11-23-2015, 09:10 PM   #29
Krovi
Krovi's Avatar
Drives: '14 Midnight Purple FR-S
Originally Posted by puma View Post
we have the same problem on our race car with RCE tarmac2 (KW) and stock end link. We had to grind as much material as possible on the endlink so it doesn't touch the body of the car. They have been holding on fine so far for the whole season.
Alright thanks guys, I have Whiteline adjustable endlinks on order hoping they'll be slimmer on the strut-side for more clearance, I'll let you guys know how it goes.
Originally Posted by solidONE View Post
how much lower than stock are you guys?
'14 MIDNIGHT PURPLE FR-S 『フェイリス』
Follow me on Instagram @overlim.it
Krovi is offline   Reply With Quote
Old 11-23-2015, 09:57 PM   #30
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
^ Neither of your cars seem "too low," but it's hard to say especially when you're trying to eyeball it while they're both using larger diameter wheels than stock.
Intent > Content
Old 11-24-2015, 09:57 AM   #31
puma
crew chief
puma's Avatar
Drives: Race car FR-S
we are not running really low, i would say 1-1,5" lower than stock
I have checked the whitelines and they are pretty much the same thickness as stock so i am afraid these won't work for you either.
puma is offline   Reply With Quote
The Following 2 Users Say Thank You to puma For This Useful Post:
Pat (06-30-2020), solidONE (11-24-2015)
Old 08-11-2016, 09:16 AM   #32
sergiomordo
sergiomordo's Avatar
Drives: 2014 Scion FR-S Whiteout
I have exactly the same problem. Lowered 1" on Swift Sport springs. Have RCE camber plates up front. When I maxed out camber at -3.2, I seriously damaged the wheel well with the endlinks. After backing off the camber to -2.6, everything seemed fine. After driving for couple weeks I checked again yesterday and my driver's side is completely fine, however I can see some rubbing marks on the passenger side. I confirmed with RCE that camber plates were installed correctly so no clue why this is happening.
Any suggestions for a low profile endlink?
I also started hearing some noise when I turn the wheel lock to lock, also from passenger side. Almost like smth is stuck and is forced to move, making tuck, tuck, tuck sound lol. Possible that 1" lowering is too much for stock endlinks?
sergiomordo is offline   Reply With Quote
Old 08-11-2016, 09:37 AM   #33
Cybmx
Drives: 2016 Hyperblue Brz
I have this same issue, no solutions yet other than running less camber. Searched for lower profile end links but no results. The washers on the stock end links seemed pretty thick, I'm wondering if removing them or replace them with thinner washers might just help a slight bit?
Cybmx is offline   Reply With Quote
Old 08-12-2016, 02:01 AM   #34
RJasonKlein
RJasonKlein's Avatar
Originally Posted by e1_griego View Post
I'm hitting on both sides I think. And I'm going to a shorter and lower profile setup. Will post after it works. I didn't buy off the shelf frs stuff.
Did you ever find a solution that eliminated the endlink clearance issue? I'm running MCS singles, too, and would appreciate the guidance.
Last edited by RJasonKlein; 08-12-2016 at 02:01 AM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 08-12-2016, 03:34 AM   #35
e1_griego
e1_griego's Avatar
Drives: Many
I went with shorter whiteline endlinks. I think my 17x9 +42 wheels with 245/40/17 tires may catch on the lock here and there, but the 17x9 +35 with 255/40 setup caught pretty regularly.
Narrower tire seemed to fix most of it.
e1_griego is offline   Reply With Quote
Old 09-26-2016, 09:19 PM   #36
NickB34
Drives: 2014 BRZ
Did you go with the KLC180-195??
NickB34 is offline   Reply With Quote
Old 09-26-2016, 10:39 PM   #37
e1_griego
e1_griego's Avatar
Drives: Many
Yup.
Old 09-26-2016, 10:44 PM   #38
brz11b
Drives: United States
i have adjustable end links as well. the driver side is adjusted wrong and i never fixed it. i rubs 2. probably not good for it but what ever
brz11b is offline   Reply With Quote
Old 09-28-2016, 02:43 AM   #39
kingkenny
Drives: 2014 Toyota GT86
My rub on the sway and inner wall nearly full lock , -3 camber , Tein SRC , super pro 20mm front sway , megun tie rod . Rubbing since I have the tie rod ...
I thought it wasn't that bad , just leave it like that over a year .
kingkenny is offline   Reply With Quote
Old 09-28-2016, 11:02 AM   #40
wparsons
wparsons's Avatar
Originally Posted by Dango1 View Post
Seen this happen once. Coils were installed wrong left/right. Caused too much castor and endlink to make contact. Maybe check that?
Has anyone with rubbing actually checked this? The front struts are definitely not symmetrical, and putting the left on the right could cause issues.
flickr
ST coilovers and front camber bolt question. dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-01-2015 04:52 PM
FS (MI): Front strano swaybar, rear wrx swaybar Aznsky Brakes, Suspension, Chassis 4 11-04-2014 03:09 PM
Front swaybar endlink problem CyberAkuma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-28-2014 10:15 PM
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 10:32 PM
Knocking after lowering *Solved, swaybar endlink* atledreier Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 02-25-2014 12:59 PM
