#15 | |
I figure what he was feeling (after replacement) was a stronger pressure plate (if it was replaced) and/or a more aggressive clutch disk surface (cause it was new). There is nothing about a throw out bearing to get "soft". It simple sits there, going round and round), until it's forced to push against the fingers of the pressure plate. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (11-14-2015) |
#16 | |
The TOB has been the go to explanation for every weird feel, noise, vibration and everything else under the sun lately and although there certainly are enough documented issues with them they have also been found to not be the problem just as many times. People are overlooking the simple answers to usually minor problems because they become so convinced it is the bearing they don't even look at anything else. There is usually no mistaking a throw out bearing going bad because the squeal will start well before failure (usually) and you will know there is something up not just think there is.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (11-14-2015) |
#17 |
fabulous
^^^this^^^
#18 | |
Drives: 2014 Subaru BRZ Limited (MT)
Is it strange that I've also notice a tiny bit MPG loss? It has gone from 25.1 to 23.4 , it's mostly because like I said early, i gotta give it a little more gas/rev it more to get it going. Also my car isn't as loud after the clutch got softer. I have an Invidia N1 catback. I would set off car alarms driving through parking lots haha by accident. Really hope the clutch bleed will do the trick. If the expert tells my car is fine and it's all in my head, I might just get a ECUTEK tune sooner than I thought.
#19 |
In all seriousness, it's probably the throw out bearing. They are so poorly designed for this car. I'm having the same issue(s).
| The Following User Says Thank You to Brndn704 For This Useful Post: | Packofcrows (11-14-2015) |
#20 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Working on getting pictures but my TOB had side with metal sticking out. Thats what made my clutch clunky, reverse and 1st seemed loose and car would slightly rev itself like if something was dragging. Brb checking texts i got while asleep.
Here's pic, notice issue on bottom right. Bit of metal sticking out. Also bearing seem warped to anyone? ![]() Other side: ![]() Dealer said, "the issue was that it was leaking grease." LMAO
#21 | |
but damn sometimes I think I should have waited for a later model so they can work out the kinks Did your dealer cover it?? and hows the car driving now? |
#22 |
#23 |
#24 |
#25 |
#26 | |
Just guessing ..... ![]() humfrz |
#27 | |
fabulous
Screech replaced with PSHHHHH when clutch pedal is depressed?
#28 |
The Fail Boat
Drives: CWP S.B.
First Post Please be gentle. Might need New clutch, suggestions plz?
Wait mine sounds like
Vroooom ktsh. Vroooooooom ktsh (Very short & distinct) Sorry I just find this way to describe the sound too funny to not jump into the action. But on serious note ....any insight? This happens if I'm trying to shift fast ....>___> Sent from my iPhone using Tapatalk |
| Tags |
| clutch adjustment, no worries, transmission |
| BOYCE's Hot Lava Gentle Beast | BOYCE | Member's Car Journals | 155 | 03-30-2014 02:22 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 01:06 PM |
| Gentle Leader - "Docked!" (New England) | DMViper | New England | 135 | 06-07-2012 09:35 PM |
