Old 11-06-2015, 02:49 AM   #15
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Call up Vishnu performance, they're up in the East Bay somewhere I believe. Not sure if they do maintenance work at their shop, but they could likely tell you where they go for that stuff. Shiv has been in the Subaru scene for ages. He's the one selling the OpenFlash Tablets/headers/etc.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 11-06-2015, 04:03 PM   #16
redlined600
redlined600's Avatar
Drives: Fr-s
Look for something mechanical first, vsc won't make the car wobble in a straight line.
Tire pressure
Lugs tight
wheel bearing
alignment
Bent wheel/wheel balance
Suspension joints
The Following 2 Users Say Thank You to redlined600 For This Useful Post:
stevesnj (11-09-2015), wparsons (11-06-2015)
Old 11-06-2015, 05:28 PM   #17
wparsons
wparsons's Avatar
^^ 100% this!
flickr
Old 11-09-2015, 01:54 PM   #18
AlexWood
Drives:
Did you replace all 4 tires? I had the same issues as you when I replaced just the rear tires. The fronts would lose grip and wobble all over the place on the highway. I would say the alignment would be your best bet but check your tires too, make sure they are orientated properly if they are directional tires.
AlexWood is offline   Reply With Quote
Old 11-09-2015, 02:49 PM   #19
stevesnj
stevesnj's Avatar
Dry u-joints can do this too. Dirty speed sensors. Just pull them out check for dust, dirt, grease and just wipe them off. May have to undo the Neg Batt cable first.
My 2016 Build thread
slipping, tires, traction
Transmission Slippage? mikev77 Engine, Exhaust, Transmission 15 11-01-2015 10:29 PM
Gear slippage from 3-4 zypher10 Engine, Exhaust, Transmission 0 10-18-2015 09:42 PM
