86WORX
Old 11-06-2015, 04:27 PM   #29
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by UNREAL View Post
how did that 4.88 FD affects the top speed of your car? I really want an answer to that? Thank you
short version: it drops the top speed, but the car doesn't have the HP to get to it anyway so it doesn't matter.
i set this up when i was trying to see what a 4.88 would do to my cruising speed.
http://calc.teammfactory.com/gearcal...ission+1+%26+2
you can put in other Final drive ratios to see the changes. or you can put in the manual gear ratios and play with that.
Freeman is offline   Reply With Quote
Old 11-06-2015, 04:45 PM   #30
AJPG
Drives: 22RE, FA20, 4G63
AJPG is offline   Reply With Quote
Old 11-06-2015, 04:49 PM   #31
AJPG
And I was wrong!
60mph at 2,200rpms.
That pic is with the 4.88 FD
Old 11-06-2015, 09:23 PM   #32
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Knock is pre-ignition of the air-fuel mixture... based on too much compression.
Octane number is a relative measure of knock resistance. Many formulations can be called 95RON... but they all have a the same knock resistance. This is equivalent to a mixture of 95% iso-octane and 5% n-heptane.
Some chemicals resist knock better than either of the above chemicals. Ethanol is one of them... which makes it great for turbocharged applications that generate high cylinder pressures.
Real knock resistance is a function of cylinder pressures and temperatures:
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 11-07-2015, 12:45 AM   #33
AppleSauce
Drives: FR-S black. Buell XB12s 25th anniv.
Maybe i missed it skimming through... How does 4.88fd affect gas mileage? Im not too familiar with how each gear scales and stuff.
He who shall be last shall be sideways and smiling
AppleSauce is offline   Reply With Quote
Old 11-07-2015, 07:56 AM   #34
AJPG
The big difference on MPGs is with right foot, no the FD or FI alone will make a huge difference.
Old 11-07-2015, 10:27 AM   #35
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
There is no replacement for displacement.
You'll be hitting a fuel limitation quickly, whereas a larger engine does not.
I would suggest you consider a V8 swap; this is the most realistic option for your goals.
For all the hassle, cost and expense I'd honestly just get another car!
Esp if the 0-60 goals etc are high priority
86 South Africa is offline   Reply With Quote
Old 11-07-2015, 02:34 PM   #36
KoolBRZ
KoolBRZ's Avatar
While changing from 4.10 to 4.88 FD reduces the load on the engine, in theory this should give better mileage, but in reality you'll waste so much more gas having fun with the new FD that it usually reduces MPG. In the AT, the traction control comes on almost immediately with a 4.10 FD. With the 4.88 FD though, I was able to spin tires in 3 gears before the traction control kicked in. An example of bad MPG while having fun. There are websites that have gear/speed calculators to tell you what your engine speed change is, but the bottom line is the way you drive, AND the way your car is tuned will affect MPG a lot more than a 4.88 FD.
If I say yes, will that make you think I understand?
The Following User Says Thank You to KoolBRZ For This Useful Post:
UNREAL (08-20-2019)
55c, 60c, ambient, high, tempreture
Search this Thread:
Advanced Search
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 06:47 PM
Torque pro: Ambient Air question RiskyTrousers Software Tuning 3 08-24-2014 08:15 PM
Car/Ambient temperature to log data gdrider77 Software Tuning 6 01-19-2014 09:49 AM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-30-2013 12:50 AM
