#15 |
Drives: Scion FRS (RAVEN)
I'll talk more later at work right now lol but check my Instagram for more detailing videos. Here's a clip of a long lasting year coating I got on my frs https://instagram.com/p/zTIhUMCAp2/
#16 | |
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Sent from my A0001 using Tapatalk |
#17 |
I was using a PC + meguires 205 and 105 followed by P&S ultracoat.
#18 |
That's the best combo to remove swirls. Maybe try Menzerna FG400 it cuts better in my opinion then follow up with m205, paint should mostly be perfect. And a orange buff and shine pad for the cutting compound and then a polishing pad and you should be good
| The Following User Says Thank You to Kamakanani0 For This Useful Post: | KalbiCool88 (11-04-2015) |
#19 | |
I'm interested to get the paint scratches on my black BRZ removed. I'm too inexperienced to venture trying to fix them on a soft paint like ours. I do 2 bucket washes and different wash pads for upper and lower region, but previous owner left his mark. Sent from my iPhone using Tapatalk |
#20 |
It's just time and a lack of a private garage (I live in an apt complex in San Francisco) that's mainly the problem here.
| The Following User Says Thank You to KalbiCool88 For This Useful Post: | Kamakanani0 (11-05-2015) |
#21 |
Sealants are basically the new wax, So many of them out, and honestly best ones on my opinion are sonax polymer net shield, really easy application with that it's in a can and just spray on a applicator and wipe on wipe off. Also another great sealant is garry deans juice boost even easier because you can put it in your wash bucket and it'll seal as you wash then your done . And igreenlovers poly coat or Quartz is the bomb coatings easy to apply and shine is crazily enhanced
#22 | |
Drives: GR Corolla
| The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | Kamakanani0 (11-04-2015) |
#23 |
Yeah I keep telling myself that too, but I just look at my car and I die on the inside seeing the condition that it's in.
#24 |
Drives: GR Corolla
Same here, especially since I don't have a garage. I just detailed mine not too long ago, and was going to wash it today, but it may rain on Sunday and Monday...don't want to waste my effort, time, and water only to have it get dirty again in a few days.
#25 | |
Habitual Troublemaker
Drives: 1997 Subaru Impreza, 2014 BRZ
Compounds and polishes are used for paint correction. They are abrasive and are used to "level" the paint. Compounds are usually more aggressive than polishes. Think of them as liquid sandpaper. Sealants and waxes are not paint correction products. They have no abrasiveness. They are protection products. You apply them to the paint to keep the paint protected. Think of it like this car is to wax/sealant, as skin is to sunscreen. There are hybrid products out there where you have polish/sealant as one product, often referred to as AIO (All-in-one). They won't be able to do more aggressive correction (like compounds) but it will be able to do some light paint correction, and seal the paint at the same time. The difference between wax and sealant is not a whole lot. Sealants are typically longer lasting, but don't quite give off the same "glow" as wax does. Though, this is always changing. Sealants are typically synthetic, where wax is organic based. Waxes uses some level of carnauba as the base. What you use is really up to you. If you are living somewhere warm/hot, it is usually better to use sealants as it is more durable and lasts longer. However, there are things you can do to make your wax just as durable (like 2 layers of wax instead of one). You could also include a premium coating (OptiCoat, CQuartz) in this category also. Coatings are pretty much sealants on steroids, but require a bit more attention/work to apply. As for Chemical Guys. I think their stuff is mediocre/junk. There's certainly stuff that's decent, but not great, but most are far from the refined product they claim to have. Hype. There's nothing wrong with a lot of the stuff. Car wash is car wash. Tire dressing is tire dressing. All purpose cleaner is all purpose cleaner. The great thing about CG is that their volume products (1 gallon) sizes are hard to beat at the price. Just being devil's advocate, if their stuff is so good... why do they have like 4 or 5 versions of every type of products? |
#26 |
| The Following User Says Thank You to darkonion For This Useful Post: | KalbiCool88 (11-04-2015) |
#27 | |
#28 | |
Lighter colored (white/silver) cars don't show imperfections as much, but still can benefit from paint correction. |
| The Following User Says Thank You to darkonion For This Useful Post: | Kaotic Lazagna (11-04-2015) |
| Any recommended detailers? | Seabrz | Northwest | 5 | 10-25-2013 05:28 AM |
| Which would you rather? A question for the detailers | giraffee | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 13 | 08-26-2013 11:28 PM |
| Detailers in GTA | Minovsky | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 06-25-2012 03:53 AM |
| Detailers in SB to OC? | Bonburner | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 06-24-2012 03:55 PM |
