Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 06-25-2012, 03:16 PM   #15
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I think it has pretty incredible shift feel for a stock car. The STi has so much slop in it from the factory, its completely depressing.
Ranatsu is offline   Reply With Quote
Old 06-25-2012, 03:50 PM   #16
theredtape
Drives: civic,vfr,BRZ
Originally Posted by Draco-REX View Post
Mechanical link > cable link.
Though a lot of people used to cable linkages in their economy cars will probably complain about feeling the synchros mesh and the engine vibration through the stick. *sigh*
I didn't even know there was such a thing as a cable operated manual transmission. Do you know of any cars specifically that had this? I know they use push pull cables in automatics sometimes...
I wanna read up on how a cable op transmission works.
Because Racecar.
theredtape is offline   Reply With Quote
Old 06-25-2012, 03:55 PM   #17
OrbitalEllipses
Drives: Attitude
Transverse FWD ecoboxes. A friend's Saturn SL once popped a cable from the linkage to the transmission, could only get into first gear for about a month til she finally got the part.
Old 06-25-2012, 04:00 PM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Marrk View Post
That's not what I'm saying. I am taking the word "notchy," when people use it about the FR-S/BRZ gearbox, as a negative critique. A direct linkage that feels direct need not be "notchy."
Why is this so complicated?
If I said that the car slipped out of gear and into neutral under load, you would say that that is a problem. You would not respond by saying, "Do you want a car that stays in gear or do you want a car that is involving to drive?"
:happy0180:
You will get notchiness with a good direct mech link transmission. If you aren't feeling anything in the shifting process you won't feel anything any other time either.
So yes, IMO, it does need to be notchy when cold to feel direct. Every good MT I've ever driven is notchy when cold.. current press isn't just views it as noteworthy (good or bad) because it's not normal, but neither is an excellent shifter. :shrug:
And yes, coming out of gear IS a problem. Notchiness when cold is NOT.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Marrk (06-25-2012)
Old 06-25-2012, 04:01 PM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Many modern FWD cars and, I believe, many AWD cars as well.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-25-2012, 04:02 PM   #20
R8
Spinning Triangles
R8's Avatar
Drives: RX-8
Most cars now. Hondas used to use rods, then changed to cables I believe. My Eclipse had cables too.
Forgive my newbiness, but I actually kinda thought RWD cars typically had neither? I thought cables and rods were for FWD cars where the transmission was up front and needed a "remote" way to shift it... and RWD cars typically had a shifter more or less IN the transmission itself (mounted below you)?
R8 is offline   Reply With Quote
Old 06-25-2012, 04:14 PM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Depends on the transmission and the driving position. The T-56 in the 4th generation Firebird/Camaro was long enough that the shifter bolted to the transmission casing itself. Subaru transmissions tend to be further forward due to the engine having to be in front of the front axles. So they have a linkage. The BRZ/FR-S has a very rear-ward seating position and a smaller transmission, so there is a linkage as well. But both the Subaru transmissions and the one in the BRZ/FR-S have the shifter connected directly to the transmission itself with only a support on the body.
Old 06-25-2012, 04:22 PM   #22
R8
Spinning Triangles
R8's Avatar
Drives: RX-8
Ah OK... I think I get it
This is an old cutaway pic from a 2004 RX-8. I think you guys have mentioned it having the same or similar transmission? Maybe it illustrates the idea?
Old 06-25-2012, 05:21 PM   #23
Marrk
Drives: Honda Fit
We're going in circles. Let me drive the car and we'll talk again. :happy0180:
Marrk is offline   Reply With Quote
Old 06-25-2012, 05:27 PM   #24
brz7400
brz7400's Avatar
Drives: Subaru BRZ
BRZ shifter is just fine, very slick and light to operate.
But then my other car is an '05 Corvette which has a rock crusher box and won't even go into 1st gear about 1/3 of the time on first try from stop, lol.
The BRZ shifter is slick and fast, but feels a bit fragile, so I have learned to work it gently.
Only thing I don't like about it is the centering force on it. It is so weak/light that when I try to downshift quickly from 5th to 4th, it doesn't center itself quick enough to find 4th a few times. Actually have to think and help nudge the shifter to center itself as it goes from 5th to 4th.
There is no real notchiness, unless you are trying to downshift into 1st gear, which I never do.
brz7400 is offline   Reply With Quote
Old 06-25-2012, 06:18 PM   #25
dori.
Seņor Member
dori.'s Avatar
Drives: white BRZ 6MT
Are there any RWD cars from Japan with a cable linkage? I've owned 2 in the past and both were mechanical.
dori. is offline   Reply With Quote
Old 06-25-2012, 06:23 PM   #26
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
All this talk about a notchy shifter just makes me want to go drive my car.
Coming from a german saloon that had a sloppy 6MT even with a short shifter, the BRZ is a godsend. That car was made to not feel sporty because it's a luxury car....I wanna feel every mechanical thing I possibly can in a sporty/sports car like the BRZ. Seriously, drive the car and you'll get it. It's not something that makes you think there's a problem with the trans but rather something that lets you remember you bought a sports car and not an econobox/luxury sedan.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 06-25-2012, 06:31 PM   #27
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
http://www.purcellperformance.com/Te...13%20FR-S).pdf
JP is offline   Reply With Quote
The Following 2 Users Say Thank You to JP For This Useful Post:
Allch Chcar (06-26-2012), Draco-REX (06-25-2012)
Old 06-25-2012, 07:26 PM   #28
Draco-REX
Corner Junkie
Draco-REX's Avatar
Good find.
Link to FR-S standard and premium HU manual Sport-Tech Electronics | Audio | NAV | Infotainment 22 06-02-2012 07:46 PM
Five Axis Poll Thread Link Memphis Scion FR-S / Toyota 86 GT86 General Forum 3 05-26-2012 10:28 AM
Brand new FT-86 video w/ring tone link - Final reveal ezmayo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 12-01-2011 07:40 PM
Top Gear UK are ecxited too (article link) Infernal Scion FR-S / Toyota 86 GT86 General Forum 4 10-20-2011 01:55 PM
