#15 |
Drives: 1997 Chevy S10
I just installed coilovers and RE71R's and I noticed immediately that the steering felt much lighter.
#16 |
To @BDotG: Do you have adjustable caster/camber plates installed? If so, what are your alignment numbers for front caster, camber, and toe, and rear camber and toe? A 1.8" drop is not insignificant, so have you made any effort to correct the roll center - this can definitely affect steering feel.
This post is old, so if you've already solved the issue, please let us know what you did to fix it. Last edited by RJasonKlein; 01-20-2016 at 02:38 AM. Reason: Corrected a typographical error. |
#17 |
Drives: Toyota GT86
What exactly you do you mean it "feels light"? Can you describe a situation, your actions and the response of the car in details?
#18 |
Drives: frs
I'm telling you, install the anti dive/caster correction kit from whiteline. Then enjoy a little heavier steering wheel, and improved correction to center- plus improved feel and feedback. You will not be disappointed. This car loses caster when lowered. That adds to the vagueness.
#19 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#20 |
Drives: 2013 brz limited
yes, after install kw v3 i feel much lighter
#21 | |
Drives: Asphalt 2013 FR-S
I think ultimately I realized it was a combo and slightly stretched tires & wide wheels spacers (surprised it took me that long to figure that out). I have since moved to some meaty ass tires on wider rims and the set up feels perfect. Just had a performance alignment done and current at -1.1 camber front and -1.5 rear. Car feels planted. |
#22 |
#23 | |
Not Bаnned Anymore
#24 | |
The top hats that came with the coilovers could be changing the caster which would make the steering light. I've seen quite a few setups where the top hats are basically the same part, bolts go in one hole or the other or they're mirror images, if installed incorrectly they could reduce caster giving a lighter steering response, slow return to center, and general vagueness as now the power steering is too strong for the system. If the caster number isn't on your alignment sheet then they cut corners. Well that is the OE specs for the rear and about what camber bolts get you in the front, for most people tire wear takes priority over maximum grip. |
#25 |
Not Bаnned Anymore
Ahh makes sense. I am planning on running -2.5 and -1.5 this spring
#26 | |
Drives: Asphalt Scion FR-S
How is the camber set at the top mount and the hub?
You may be observing reduced steering effort due to a reduction in absolute scrub radius. I followed Racecomp Engineering's recommendation and have my dampers mounted so the front strut is as vertical as possible by maxing out negative camber at the hub for improved SAI. Quote:
Good bit of info here on caster, SAI, and camber: http://www.ft86club.com/forums/showthread.php?t=48107 @CSG Mike or @Racecomp Engineering can shed some more light on this.
| The Following 2 Users Say Thank You to JDKane527 For This Useful Post: | CSG Mike (01-20-2016), RJasonKlein (09-10-2016) |
#27 |
Teflon thrust washer + spherical top + camber reduction via camber plate = formula for lighter steering.
Sounds about right
#28 |
Drives: frs
Not the roll center correction kit, I have it too. And yes the car would need realigned with either kit when ride height is changed. Even without either kit it needs realigned when ride height is adjusted that much. The anti dive/ caster correction kit is the front control arm bushing in the front location of the arm that has an offset hole that adds caster to the front wheels. The roll center correction kit brings the roll center closer to ground level. Some argue that it isn't necessary, but I can testify that the sum of all of the above parts, plus energy suspension rear bushings in all locations that don't already have pillow ball/cross axis bushings, is an even more amazing and responsive car.
| The Following User Says Thank You to twag4 For This Useful Post: | go_a_way1 (01-20-2016) |
| Tags |
| coilovers, light, steering |
| ABS and Slip Light on after steering wheel re-install | Yamajee | Issues | Warranty | Recalls / TSB | 11 | 03-29-2017 01:56 PM |
| Best Steering Wheel Column for Feel - Rake and Reach | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-21-2015 10:24 PM |
| OEM Steering Wheel Reinstall...Light Still On? | dizzario | Electronics | Audio | NAV | Infotainment | 13 | 06-22-2014 10:23 PM |
| Steering Feel Question Concerning Tic Solid Steering Bushings | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 10-31-2013 05:52 PM |
| Steering Wheel Feel | ap5512 | BRZ First-Gen (2012+) -- General Topics | 8 | 12-08-2011 12:16 PM |
