Old 11-02-2015, 04:09 PM   #15
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by snuff58 View Post
Pat:
about 1/3 to 1/2 turn. I gauge it on perceived flow in the clear tubing. My ending results were good. Very solid pedal and no fade at the track under hard braking.
I experienced issues only opening it that much on my E30. I also used clear tubing and watched flow. But I had much more success with a full turn than half a turn.
brake bleeding
Search this Thread:
Advanced Search
DIY - Stainless Steel Lines - Speed Bleeders - Fluid Bleed/Flush F1point4 DIY (Do-It-Yourself) Guides 99 08-24-2017 07:05 PM
How often do i need to change/bleed brake fluid (DoT 5.1) dejxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-15-2015 12:50 PM
Issues swapping brake lines Jericon Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-28-2014 02:28 PM
Swapping brake fluid barabia Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-12-2013 10:58 PM
Brake caliper bleed order 96z2 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 10-12-2012 01:54 AM
