#99 |
I really hoping I can leave my flex fuel lines. Maybe the shop will be kind. Everything else will be stock otherwise.
2013 Series 10 FRS #553
#100 |
Just did my STAR station smog check. The visual check was very thorough, the guy called me out for not having the sound tube (i reverted my engine to stock for the test and didn't bother with the sound tube as i had it previously deleted). Guy took mercy on me but pointed out that a less lenient examiner would have failed for having the sound tube deleted.
#101 | |
#102 | |
If anything that tube introduced carbon dioxide into the cabin. It was the first thing I deleted form my car. If removing it would have caused my car to fail it's SMOG test, I would have filed suit against Toyota/Subaru for creating such a ridiculous and hazardous appendage.
| The Following User Says Thank You to MJones_RB For This Useful Post: | manualmotive (02-19-2022) |
#103 | |
Drives: 2016 Subaru Series.HyperBlue #631
I too am a south county resident and will inevitably need a smog sooner rather than later. Would you mind PMing me where you took your car for your smog? Thank you!
#104 | |
#105 | ||
#106 | |
#107 | |
#108 |
#109 |
correct but they still need proof they bough it from the dealer. Without it no carb sticker.
#110 | |
#111 |
x3 please
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#112 | |
OH HEY NOW!!!!
Drives: 2013 Scion Fr-s Asphalt
| Smog check for out of state people? | goshem | Southern California | 4 | 09-25-2015 07:20 PM |
| CA Smog Check?? | JG | Southern California | 22 | 06-08-2015 12:05 PM |
| WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho | continuecrushing | Southern California | 13 | 01-27-2015 12:19 AM |
| Need advice on passing smog in California | rmak321 | Northern California | 7 | 07-12-2014 01:52 AM |
| Smog check and visual inspection help | Corradooo | Northern California | 24 | 05-20-2014 12:57 AM |
