Southern California SoCal
Old 03-31-2021, 03:28 AM   #85
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Originally Posted by jflogerzi View Post
pretty sure the CAL-ID does not change for ecutek or OFT as you are editing the stock ECU... But just flash back to a stock map.
True, the CAL ID is locked for the ECU right? I have a 2013 ECU with a 2016 motor w/ a 2016 E85 flex tune loaded. Its been awhile since i loaded the tune so ima go back and double check the cal-id.
Decimus is offline   Reply With Quote
Old 04-29-2021, 03:48 PM   #86
re-animator
Got a notice to smog my car for re-registration and looks like i got selected to go to a STAR station. I think these are more tightly controlled/inspected smog stations and based on basic research i think certain models of cars are selected to go to a STAR station because they are more likely to fail or more likely to have some funny business that the state doesn't trust all smog techs to look for.
what they don't know of course is that i can put headers on right after i pass. then it looks like 2 years of no torque dip lol
re-animator is offline   Reply With Quote
Old 04-29-2021, 04:49 PM   #87
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Welp, that's California
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
Old 04-29-2021, 07:24 PM   #88
jflogerzi
jflogerzi's Avatar
Yea what I get to look forward to in the next few months. The main thing is the flex fuel kit that's gonna fail me I bet. Header is easy to remove
2013 Series 10 FRS #553
Old 04-30-2021, 09:37 AM   #89
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Why would flex fuel fail you? Isn’t E85 closer to carbon neutral when compared to petrol?
Stonehorsw is offline   Reply With Quote
Old 04-30-2021, 11:25 AM   #90
jflogerzi
jflogerzi's Avatar
I believe it's a change plus it pulls it 0-5volt signal evap signal causing this to show not ready. I am hoping I can reconnect this signal wire and just leave the flex fuel sensor. Any change good or bad is not allowed in CA
Old 04-30-2021, 02:05 PM   #91
Stonehorsw
Stonehorsw's Avatar
For me doesn’t make sense, they should praise you and give you some carbon credits
Old 04-30-2021, 03:41 PM   #92
MJones_RB
MJones_RB's Avatar
Just passed my smog, pretty much stock other than some Crawford Power Blocks. I had a catch can, which I de-installed before the test. No issues.
MJones_RB is offline   Reply With Quote
The Following 2 Users Say Thank You to MJones_RB For This Useful Post:
Decimus (05-10-2021), KMA KiCKz (04-30-2021)
Old 04-30-2021, 05:12 PM   #93
jflogerzi
jflogerzi's Avatar
Rights I agree buts it's CA lolz
Old 05-02-2021, 05:39 PM   #94
Bonburner
Purchased 6/22/12
Bonburner's Avatar
catch cans are a smog issue?
Old 05-02-2021, 09:20 PM   #95
jflogerzi
jflogerzi's Avatar
Depends on the shop.
Old 05-02-2021, 11:00 PM   #96
Sapphireho
Connection issues
Sapphireho's Avatar
Drives: '15 ultramarine
Always have been in California.
Old 05-10-2021, 02:50 AM   #97
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Yes - it wont pass visual
Old 05-10-2021, 01:19 PM   #98
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I just got the old FRS smogged today for the first time, everything went smoothtly. Car passed, no rollers, no lift. Just popped in the OBDii and blipped the throttle a few times, visual inspection and I was done.
I knew there was nothing on the car that would fail smog, but you never know. I was concerned I might have to show my J02 recall certificate (which I have) however he didn't need to see that. The guy said my catback was totally fine. This was in Orange county (south) Ca.
DandoX is offline   Reply With Quote
The Following 2 Users Say Thank You to DandoX For This Useful Post:
MJones_RB (05-10-2021), Tcoat (05-11-2021)
Smog check for out of state people? goshem Southern California 4 09-25-2015 07:20 PM
CA Smog Check?? JG Southern California 22 06-08-2015 12:05 PM
WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho continuecrushing Southern California 13 01-27-2015 12:19 AM
Need advice on passing smog in California rmak321 Northern California 7 07-12-2014 01:52 AM
Smog check and visual inspection help Corradooo Northern California 24 05-20-2014 12:57 AM
