86WORX
Southern California SoCal
Old 07-21-2021, 06:45 PM   #127
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
Did you show the tech who failed you the CARB sticker or certificate?
I sure did. They said its the computer system that failed me not them. They have no way of bypassing it.
mrha is offline   Reply With Quote
The Following 2 Users Say Thank You to mrha For This Useful Post:
Decimus (07-22-2021), Lonewolf (07-22-2021)
Old 07-21-2021, 07:04 PM   #128
jflogerzi
jflogerzi's Avatar
WOW that sucks... Hopefully you don't need to go through state ref
2013 Series 10 FRS #553
Old 07-21-2021, 07:49 PM   #129
mrha
#1819
mrha's Avatar
I got a reply from Vortech. They said that the serial number on my supercharger belongs to a Tuner kit they are unable to help me.
I am going back to stock.
Old 07-21-2021, 07:50 PM   #130
jflogerzi
jflogerzi's Avatar
Oh wow.... Was your kit advertised as a carb kit?
Old 07-22-2021, 01:18 PM   #131
mrha
#1819
mrha's Avatar
I inherited the kit from someone else and it has an EO number on the plate and came with the Vortech ecutek programming kit and map sensor.
Old 07-22-2021, 09:59 PM   #132
Lonewolf
Lonewolf's Avatar
Drives: Moped
I'm sorry to hear that. Sure looks like the smog nazis have really upped the ante now...
Old 07-24-2021, 01:04 AM   #133
Wraith
Drives: 2013
cant you by pass this with a factory ecu ???
I mean mine will be NA and mostly stock except maybe the tune, exhaust and instake...
I mean how hard is it to buy a factory ecu from a wrecked frs or brz
Wraith is offline   Reply With Quote
Old 07-24-2021, 01:09 AM   #134
jflogerzi
jflogerzi's Avatar
Carb is very picky when it comes to approved mods. They need to be by the book
Old 07-24-2021, 01:26 AM   #135
Wraith
Drives: 2013
Im pretty sure ... that an exhaust will pass since its after the cat no ??? or has this change ???
as for the tune. just swap out to the factory ecu from a wreck brz or frs.
my perrin intake is carb oe... so Im good there... should pass
Old 07-24-2021, 01:30 AM   #136
jflogerzi
jflogerzi's Avatar
Perrin intake is not carb legal.... Exhaust does not matter as long as it's post secondary cat in the FP and everything else is stock. Tune just put stock ECU back on but I am curious with CA not looking for modified ECUs... Oft should be good but I am worried ecutek might be screwed because the license file stays behind and this might mess with the checksum
Old 07-24-2021, 01:50 AM   #137
Wraith
Drives: 2013
perrin intake says it is ...
https://www.ftspeed.com/part/fr-s-br...t#.YPua8Y5Kjcs
the intake comes with an oe carb sitcker. All I have to worry about is the PLM UEL header. Which is like a couple of hours work to swap the stock one.
its all volkswagen fault we have to deal with the modified ecu stuff.
but the ecutek shouldnt be a problem no??? since your keeping the ecutek programmed ecu and swapping it out with stock ... there should be an issue with the license that way. Maybe I need to talk to my buddy Kevin who use to own Garage Tuning; about the ecutek thing
Old 07-24-2021, 02:48 AM   #138
jflogerzi
jflogerzi's Avatar
stand corrected
Old 12-21-2021, 10:21 PM   #139
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Well guys, i finally went to smog the car for the first time. Put all OEM things back on & Flashed back to OEM tune with CALID ZA1JB01C. I’m running a 2016 motor in my 2013. No issues whatsoever from the smog place and everything passed.
So in case anyone else was worried about things not passing… it passes
Decimus is offline   Reply With Quote
The Following User Says Thank You to Decimus For This Useful Post:
Lonewolf (12-22-2021)
Old 01-23-2022, 07:04 AM   #140
Stigmaru
Stigmaru's Avatar
Drives: 2022 Halo White GR86
Originally Posted by TAKECLEAR_86 View Post
Are you sure you're not missing a 0 on that price? lol. All that done and they passed you? You are one lucky guy.
It just looks like it's possible to pass with one cat vs the two.
Stigmaru is offline   Reply With Quote
Smog check for out of state people? goshem Southern California 4 09-25-2015 07:20 PM
CA Smog Check?? JG Southern California 22 06-08-2015 12:05 PM
WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho continuecrushing Southern California 13 01-27-2015 12:19 AM
Need advice on passing smog in California rmak321 Northern California 7 07-12-2014 01:52 AM
Smog check and visual inspection help Corradooo Northern California 24 05-20-2014 12:57 AM
