Old 10-25-2015, 12:00 PM   #15
Racecomp Engineering
Good advice here. Check out your local auto-x group and get some experience with your car as is before the season is over. Learn what you can about driving and suspension...try to feel what you want to improve before spending money on mods. But as mentioned, you'll want to decide on a class at some point.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
wparsons (10-28-2015)
Old 10-25-2015, 12:35 PM   #16
LenA
Drives: 2015 Silver BRZ
I'm also a newby to this car. Have owned Alfa's and a couple of E30' s in the past, so not new to low powered sport cars.
I would suggest reading the stickies on top of this page, mostly by CSG and RCE. Lot's of interesting reading.
My plan is to do camber bolts and maybe SPC LCA and get a good alignment and drive on stock tires/suspension until I can identify what I need to correct(if anything)
Len
LenA is offline   Reply With Quote
Old 10-25-2015, 03:11 PM   #17
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by johan View Post
#1 - Driver mod (seat time).
If you want to get into actual racing, doing autocross... don't touch a thing. Learn the sport, learn your car. When you can't improve your time any further with the car as is, start making small incremental changes.
At that point, then follow the recommendations of @cjd and do alignment and tires.
The stock car handles very, very well and you would be wise to just go out and learn how to drive it well as it as is.
^ this
Intent > Content
Old 10-25-2015, 09:41 PM   #18
Seth Hawkins
Seth Hawkins's Avatar
Drives: 2015 BRZ Limited
Thanks to all of you for the excellent advice. I'm going to follow it, and drive the car "as is" until I get comfortable with it - and autox-ing. I'm sure the car has at least a season's worth of driver upgrade in it. LoL.
Seth Hawkins is offline   Reply With Quote
The Following User Says Thank You to Seth Hawkins For This Useful Post:
Racecomp Engineering (10-26-2015)
Old 10-25-2015, 11:54 PM   #19
strat61caster
strat61caster's Avatar
hehe one season in, I know I'm a solid 1+ second slower than the car is, it's a long journey filled with lots of squealing rubber
ineedyourdiddly
Old 10-26-2015, 02:14 AM   #20
solidONE
solidONE's Avatar
Don't forget to get an alignment that's more performance oriented. Camber bolts to increase front negative camber and that's pretty much it. Enjoy!
Intent > Content
Old 10-26-2015, 04:36 AM   #21
akyp
Drives: 2012 86
Installed OEM crash bolts, went for an alignment (ended up with -1.4 deg camber at the front), then went to the track. Car drove like a dream! The phrase 'should've came from the factory like that' is probably over-used but not in this case. I have no desire to change anything else suspension-wise.
akyp is offline   Reply With Quote
The Following 3 Users Say Thank You to akyp For This Useful Post:
johan (10-26-2015), Racecomp Engineering (10-26-2015), wparsons (10-28-2015)
Old 10-28-2015, 01:18 PM   #22
strat61caster
Originally Posted by Erollin View Post
Sounds like you got some good advice. I saw http://www.furiouscustoms.com/suspen...-s-subaru-brz/ kit and it looks decent for the price.
That doesn't seem to be a kit oriented for autocrossing or even track use, strut bars are typically not seen as a significant performance enhancement and the vast majority of autocrossers upgrade the front sway bar, not the rear. A stiffer rear may be desirable to dial out the understeer for track usage for someone not looking to go outside the streetable envelope on alignment or spring/dampers.
ineedyourdiddly
Old 10-28-2015, 01:20 PM   #23
wparsons
wparsons's Avatar
It's already been said, but drive the car 100% stock. It's more than capable, and throwing the wrong parts at it can make it drive worse than stock.
Camber bolts and a better alignment would be the only thing I'd suggest doing right away.
flickr
Search this Thread:
Advanced Search
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 06:06 PM
Mods Recommendations (1/18 FR-S RC) fang_gt86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 01-02-2015 09:34 PM
FS: 2014 BRZ Sport Tech with suspension/wheel/tire mods BRZZZZZZZZZZ Canada Classifieds 24 10-31-2014 09:15 AM
TRD Suspension Mods Strat AFRICA 0 07-28-2013 12:32 PM
FRS BRZ Suspension Mods phm14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-15-2012 11:25 AM
