Old 11-19-2015, 02:04 PM   #127
zonda
Drives: 2014 WRB BRZ
quick question for those who have the noise and crunchy feeling.
do you still hear/feel it if you press down the clutch with a lot more force?
for me, it goes down smooth if i put an unnatural amount of pressure on the clutch. if i push down normally, you hear/feel it.*
zonda is offline   Reply With Quote
Old 11-21-2015, 02:12 PM   #128
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by thambu19 View Post
So this sound happens when depressing it say 10% or so just enough to apply the initial pressure on the TOB? or when fully depressing the clutch.
It's from the moment the TOB makes contact with the pressure plate and all the way through the pedal stroke. It is, with 100% certainty, a failing TOB. It's the sound of an "unlubricated bearing".
I called the dealership and the service guy said that with this many miles (54k), that even though it's within it's warranty period, it's a considered a wear item and the likelihood of getting it warranty replaced is essentially zero. I had some choice words for him at that point.
If this car is going to require a new TOB every 55k miles I will considering trading it in and never looking back. I've probably done over a million miles in my life with manual transmissions and I've never had a TOB fail.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
strat61caster (11-21-2015)
Old 11-21-2015, 02:22 PM   #129
Ultramaroon
fabulous
Ultramaroon's Avatar
I see a golden aftermarket opportunity here. Well, silver at least.
Old 11-21-2015, 03:29 PM   #130
thambu19
Drives: Scion FRS
I wonder if the TOB is shared with the WRX because they are complaining about the same.
If TOB is failing due to lack of lubrication how is it supposed to be JUST a warranty item?
I hope people complain in the NHTSA website about how the TOB failed on the freeway at 70mph and how it caused an unsafe incident and NHTSA sue the crap out of Subaru and Toyota
thambu19 is offline   Reply With Quote
The Following User Says Thank You to thambu19 For This Useful Post:
Ultramaroon (11-21-2015)
Old 11-21-2015, 03:31 PM   #131
jcw99
Drives: swp mt '14 brz premium
The bearing on my Toyota pickup lasted 221,000 miles - it seems like these cars of ours have a problem with everything 'clutch.' I finally got the slave cylinder recommended by Ultramaroon and the MTEC pedal spring. Hope to install them this week.
jcw99 is offline   Reply With Quote
The Following User Says Thank You to jcw99 For This Useful Post:
Old 11-21-2015, 04:07 PM   #132
rice_classic
The whole "wear item" thing pisses me off. It's a car, the act of using it puts wear on every part of the car. The crankshaft bearings are a "wear item" but if they failed in 55k miles I bet you the warranty would cover that, or the wheel bearings, or the input shaft bearing etc etc etc.
A TOB should go at the very least 100k. It is what it is. I've removed, rebuilt and reinstalled a transmission in the paddock so I'm not worried about do the work. The only silver lining is that doing the repair myself is all of an afternoon and $175.
SCCA T4 - FRS
Old 11-21-2015, 09:23 PM   #133
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by SkAsphalt View Post
My throw out bearing went in less than 20,000 km. I thought my clutch went so I replaced the whole thing with a upgraded exedy clutch. So that was a waste of money
Just be glad you didn't have the dealer do it after a warranty claim inspection, you would have spent several times more for the same shoddy bearing and components. I wish I had done that myself, but I thought for sure they would have covered it. I thought wrong. Now I'm not so sure about future warranty coverage as Toyota's field tech deems the damage caused by "abuse" from "performance driving".
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Old 11-22-2015, 02:05 PM   #134
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I'm sure a lot of people will not want to or have the confidence to pull the tranny so easily over $1000 repair bill. My squeak and crunch seems to be getting worse by the week but with winter I have no desire to pull the tranny so hope it gets me to 70k.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
The Following User Says Thank You to Tt3Sheppard For This Useful Post:
thambu19 (11-22-2015)
Old 11-22-2015, 02:56 PM   #135
solidONE
solidONE's Avatar
Parts and labor you're looking at closer to $1700 from the dealer if not warrantied.
Intent > Content
Old 11-22-2015, 02:57 PM   #136
thambu19
Drives: Scion FRS
That's a lot
Sent from my HTC One_M8 using Tapatalk
Old 11-22-2015, 02:59 PM   #137
solidONE
solidONE's Avatar
That's a lot
I'm sure it varies depending on the labor rates and how many hours they charge for the job. Parts alone is about $600~700 flywheel, clutch and accessories. My dealership charges $120/hour labor rates.
If I changed out the clutch myself if would have cost me $300 or less in parts without new flywheel, or $30 just for the release bearing.
Intent > Content
Old 11-22-2015, 04:08 PM   #138
pantdino
Drives: Firestorm 2013 FR-S
I have an automatic car, but if I thought my TOB was going out I'd take the car to an independent mechanic that gets less per hour and have him replace JUST the TOB- replacing perfectly good clutch parts is bullshit and robbery.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
The Following User Says Thank You to pantdino For This Useful Post:
axelo (11-28-2015)
Old 11-26-2015, 12:07 PM   #139
riironman
riironman's Avatar
Drives: asphalt fr-s
yep. dealer fisted me good. same oem junk back in...I mostly drive in 6th gear on the highway...the tob still melted. never once had a clutch or parts fail on me in over 25 years of driving manual. kinda offended on people telling me to learn how to drive manual. I don't ride the clutch and we have a dead peddle to rest my left foot on. the dealer gave me a 1 year unlimited mileage warranty on this clutch...but the clutch went in 2 years...and pretty sure it covers parts only not labor. dealer left a bad taste in my mouth and lost another sale. my wife was shopping for another forerunner there...told them to fuck off
riironman is offline   Reply With Quote
Old 11-26-2015, 05:22 PM   #140
rice_classic
Ok, so I have bookmarked the thread with the DIY tranny removal... looks really straightforward. I'm going to set a timer as I've bet myself I can do it start-to-finish in 5 hours or less. My SKF TOB came in yesterday and it's time to change the transmission oil anyway. No time like the present.
Black Friday?!?... No way, TOB replacement Friday! (maybe I'll change my engine oil too).
SCCA T4 - FRS
The Following 5 Users Say Thank You to rice_classic For This Useful Post:
axelo (11-28-2015), jvincent (11-27-2015), RustySocket (11-26-2015), strat61caster (11-26-2015), Ultramaroon (11-27-2015)
act throwout bearing blown Engine, Exhaust, Transmission 0 08-30-2015 03:17 AM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 09:08 PM
Release Bearing or Pilot Bearing Cal3000 Engine, Exhaust, Transmission 11 01-27-2015 11:39 PM
Friday Ruined... mbh1101 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 07-20-2013 02:58 PM
How do you know that your day is already ruined? IloveBaldEagles Scion FR-S / Toyota 86 GT86 General Forum 4 12-03-2012 10:58 AM
