| Engine Swaps Discussion of engine swaps. |
#15 |
Drives: Whiteout FRS
I believe with the LS engine swap the front sway bar has to be removed to fit the engine, so handling isn't going to be like it is with the FA in there. I know there is a company I forgot the name that is making a sway bar for the LS swap.
#16 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
No. It doesn't. The reason somebody removed it in *another* swap was because it interfered with the factory oil pan on the chosen motor. You will not have to remove the sway bar if you have a suitable oil pan.
Inline 4 is best 4
There are many ways to displace. -Spartarus |
| The Following User Says Thank You to Spartarus For This Useful Post: | Basket Case (11-12-2015) |
#17 |
#18 | |
The car still drives and handles great. It is very well planted, it will go whereever you point it. I've been driving it for the past few days and it really doesn't feel any different than with the FA, it just has real power.
| The Following 5 Users Say Thank You to Amir Ghadiri For This Useful Post: | Basket Case (11-13-2015), pward08 (03-25-2018), raven1231 (01-19-2016), Spartarus (11-13-2015), Ultramaroon (11-13-2015) |
#19 |
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Any other input on the CX swap kit? Thinking about pulling the trigger on it before the CDN dollar gets worse. I'd like to wait for the vorshlag kit but still haven't seen anything yet
#20 | |
Drives: 2013 SWP BRZ Limited
#21 |
...Just add nauseum
Standalone ECU, custom wiring for the engine, appropriate tuning.
Only CANBUS enabled ECU's with a preconfigured profile for the FRS are viable (without a ridiculous amount of extra work). That leaves you with MoTeC, Haltech, and very few others.
Inline 4 is best 4
| The Following User Says Thank You to Spartarus For This Useful Post: | DAEMANO (02-02-2016) |
#22 |
Drives: FRS Silver LS1 swapped.
Can-bus integration is everything for this swap,..the steering is sluggish when its in the default mode and having the big tach on the dash to work would be nice....abs..traction control...everything else is pretty straight forward and fundamental....There are fixes in the work as we speak using stock ECU which will be.....yes... a retail product..i.e.less costly. And I'm sure others,.....because this car screams for more power that's reliable and N/A and I'm sure many will hit the streets before long....
| The Following User Says Thank You to cf6mech For This Useful Post: | wparsons (12-17-2015) |
#23 | |
TURBOLICIOUS
Drives: a machine :]
#24 |
#25 |
TURBOLICIOUS
#26 |
#27 |
TURBOLICIOUS
Come on get it bro. I'm right next to Plano lol
#28 |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| SOLD | MisterSheep | Brakes, Suspension, Chassis | 8 | 11-23-2015 12:34 PM |
| $1500 to spend | sixthree | BRZ First-Gen (2012+) -- General Topics | 40 | 03-11-2015 02:47 AM |
