86WORX
Old 10-16-2015, 01:18 PM   #15
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
It doesn't matter if you are planning on going turbo as you will be replacing your headers anyways....
(don't mean to be a troll but I have been wanting to use this for a while haha)
Attachment 122901
True but doesn't PTUNING allow you to retain your headers? Not trying to be a smart ass or anything but that's the only one at the top of my head I can think of. They're pretty damn expensive though lol
Alltezza is offline   Reply With Quote
Old 10-16-2015, 01:21 PM   #16
kch
Senior Misanthrope
kch's Avatar
That's correct. I think the WORKS turbo kits also allow you to retain your header.
Old 10-16-2015, 01:24 PM   #17
Alltezza
Alltezza's Avatar
Well there's 2 options for the OP to look at, if he/she ever wants to go turbo route lol. But hey there also supercharger options as well(;
Old 10-16-2015, 01:28 PM   #18
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
HAHA good point! Ptuning I would look at but not the WORKS kit.
Old 10-16-2015, 01:31 PM   #19
kch
Senior Misanthrope
kch's Avatar
So as not to derail this thread too much:
I picked a UEL header because the rumble makes me happy. I'm not building a race car, so I don't care that EL headers produce more power in the high revs. OP, you should listen to video clips of various exhausts and see what sound you like best.
Old 10-16-2015, 04:49 PM   #20
Originally Posted by kevman_101 View Post
Unless you are in a competitive racing series, do you really need to have 2-5 extra wheel horsepower? Search youtube for headers and listen to the sound they make. Most EL will sounds nearly the same, but UEL`s will sound different because they don`t necessarily have the same length differences from one side to the other.
I like the Open flash and Borla UEL sounds. JDL is too but just find it too pricey. I know the quality is way better, but like I said, I`m not looking to make the max power, I`m not trying to out accelerate another car to make a pass in T6. I want to make the car sound good to my ears and just free up some power at the same time.
[ame="https://www.youtube.com/watch?v=8e31Ketqj38"]CSG Ace 4-2-1 FRS/BRZ header Laguna Seca fly-by Sound Clip at 86CUP - YouTube[/ame]
wparsons (10-16-2015)
Old 10-16-2015, 05:12 PM   #21
wparsons
wparsons's Avatar
It's not EL vs UEL for where the power is made, it's 4-1 vs 4-2-1. A 4-2-1 header will have better midrange gains, while a 4-1 will have better top end gains. That all assumes it's probably designed, and not just cobbled together with no thought to runner diameter, steps and runner length.
Personally I want no part of a header that is designed to give unequal backpressure, scavenging and heat to half the engine vs the other.
flickr
Old 10-16-2015, 05:23 PM   #22
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Originally Posted by bfrank1972 View Post
The whole UEL vs EL thing is overblown. It's down to sound, assuming you're using a well designed header and a custom tune by someone who knows what they're doing. All of the well designed EL headers (ACE for instance, or P&L, JDL, HKS, etc) that I've seen on here with custom tunes fix the torque dip. Also regarless of UEL vs EL, both designs show modest gains in the upper RPM range - certainly there, but nothing earth shattering for either configuration.
When it comes to 'lesser' (cheaper) headers, you'll see variance all over the place. I've seen cheap UEL and EL headers both fail to fix the torque dip. I've also seen poorly tuned 'good' headers fail to fix the torque dip.
In the end, just save your money and get a turbo kit that includes a header
Would Tomei EL or UEL be considered good?
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 10-16-2015, 05:31 PM   #23
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Tomei is a solid brand. Can't go wrong with them. Keep in mind the tubbing walls are thin.
Mr.Impreza (10-17-2015)
Old 10-16-2015, 05:42 PM   #24
bfrank1972
Drives: 2013 FR-S Argento
Honestly I'm not sure - it's a complicated thing, as a good tune for that specific header is important. Just look at the recent thread where the guy gutted the cat on his stock header and re-tuned. What makes a good header is way over my head - I just rely on aggregate dyno results of people who have tested various headers. The Tomei headers certainly look nice, maybe in the same league as the openflash headers, but I haven't seen any dyno results (with good custom tunes) to compare.
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
Old 10-16-2015, 06:37 PM   #25
steve99
You got to look at your end game.
Pick a sound
UEL - boxer rumble
EL - normal 4 cylinder sound
UEL - generally better gains in low/midrange, sacrifices a few hp top end
EL - not so good low/midrange but few more HP top end
Tomei, JDL, openflash Gruppe-s ect are your average priced headers
and plenty of flash & go or canned tunes available from ecutek and OFT guys for these
Then you have P-tuning and Nameless and ACE the higher priced headers
ACE header is probably the pick of the bunch as it combines benefits power/torque) of the normal EL/UEL header (it an EL header so no boxer rumble though). The ACE produces good gains entire rpm range.
Rub is its expensive and you will need a custom tune to get the max benefit as I dont think anyone is offering flash & go or canned tunes for ace header (or P-tuning or nameless)
If your just street driving and staying NA then probably just get a UEL header and a flash and go or off the shelf tune from ecutek or OFT guys
If you going turbo then most kits will require you to run a different exhaust manifold (header) to connect up to turbo, some can use original header but very few.
supercharger kits you can use your original header. , nameless might be an issue for some kits due to its design.
The Following 4 Users Say Thank You to steve99 For This Useful Post:
jsalaz03 (11-29-2015), mattyd97 (10-29-2015), Mr.Impreza (10-17-2015), Turdinator (10-29-2015)
Old 10-17-2015, 04:07 AM   #26
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by mattyd97 View Post
Hey everyone, can someone tell me the difference between equal length headers and unequal length headers, and what effects they will have on my car. I've also been told that I need to make sure my car has "equal back pressure," or something along the lines of that. I'm still learning about my car and I'm not sure what I'm looking to purchase next, so if headers seem more beneficial than a test pipe, I'm all in. Thank you in advance to all who help.
Personally I prefer the EL sound.
Both types will help increase power, but it's really the tune that makes the biggest difference. I wouldn't expect big gains with only an exhaust. Don't be fooled into thinking otherwise.
Like some of the dudes say - consider future plans too... Turbo? Then don't do a header now. SC, then sure. NA, then sure.
Have fun and post pics of what you do in the end?!
86 South Africa is offline   Reply With Quote
Old 10-17-2015, 05:03 AM   #27
churchx
churchx's Avatar
Drives: 2014 GT86
Nameless .. if you think of Cossworth's as Nameless (there are some changes though), then it has canned Cossworth's tune.
Old 10-17-2015, 07:33 PM   #28
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Pick a sound
UEL - boxer rumble
This answered every question i still had remaining regarding headers haha
Gaskets & Headers question Bach415 Engine, Exhaust, Transmission 16 06-30-2015 06:27 PM
Question about the Fa20club UEL headers Chuck. Engine, Exhaust, Transmission 7 04-22-2014 09:30 AM
Turbo Question regarding Headers Admired Forced Induction 13 10-16-2013 09:27 AM
Question about the design of Borla EL Headers... Kiske Engine, Exhaust, Transmission 4 07-26-2013 12:54 PM
question for guys with headers Xdragonxb0i Engine, Exhaust, Transmission 22 04-22-2013 01:49 PM
