Old 10-13-2021, 08:40 AM   #43
SydBRZ
SydBRZ's Avatar
Drives: MY14 BRZ, MY06 WRX
Originally Posted by thornad View Post
Interested too, do you still have the original tune, or at least the VVT tables ?
Wow, necrothread alert : )
If you're looking for an OFT tune suitable for ACE, look at WayneRoms.com - that would be the way to go.
SydBRZ is offline   Reply With Quote
Old 10-13-2021, 09:54 AM   #44
thornad
Drives: 2016 GT86 N/A
I've got Wayne's tune, but I think it needs some tweaks for my case.
The only difference between Wayne's tune for standard EL header and his ACE tune is that the VVT Intake table has uniformly about 4' less from 2800 to 6000. The VVT Exhaust and all other tables are identical between ACE and non-ACE EL tunes. So almost no difference, at least not what I would expect.
I assume this is because he has ACE 250 which has shorter runners than mine which is the equivalent of ACE CS400 with the longest runners.
This is why I am looking someone who's got for VVT tables for ACE 350 or CS400
thornad is offline   Reply With Quote
Old 10-13-2021, 03:59 PM   #45
tomm.brz
Drives: brz 2017 hksv2
36 of maximum intake advance I usually use for forced induction lol
just use El table from left, it s already good and then adjust afr and then maximize ignition timing advance and you will have the ace gains
Old 10-14-2021, 04:22 AM   #46
SydBRZ
SydBRZ's Avatar
Don't forget that for ACE, Wayne recommends running one level of timing above your chosen fuel type, 'Please flash one timing level above normal. E.g. flash 100 RON file for 98 RON fuel'.
You may have done this already, but if not, it's worth mentioning.
Old 10-20-2021, 11:42 AM   #47
thornad
Thank you, I tried the tune for 93/102 octane it and it knocks pretty bad (6 degrees FLKC). with 100 it is only about 3 degrees. The AFR also looks a bit wild and does not change much with adjusting MAF. Not in the parts with the large dips and peaks.
With default MAF:
https://datazap.me/u/thornad/v164-10...11&zoom=98-205
after adjusting WOT MAF:
https://datazap.me/u/thornad/m2-3?lo...11&zoom=30-138
So I'm thinking it must be VVT.
Old 10-21-2021, 12:31 AM   #48
SydBRZ
SydBRZ's Avatar
With default MAF:
How closely are you following the dialling in process on Wayne's page?
If you're knocking, you may need to flash a richer map.
There are moments during your WOT pull that look a bit lean.
As you may know, aside from the default map, Wayne provides maps from lean -4%, through to rich +4% on his site.
Have you tried reaching out to Wayno?
He's usually pretty responsive on email.
Search this Thread:
Advanced Search
PLM Header Review Cross Engine, Exhaust, Transmission 7 05-26-2016 06:46 PM
Driveway Labs Type II Diffuser (PRODUCT REVIEW) Ammonia User/Vendor/Sponsor Reviews, Feedback, Comments 7 08-07-2015 05:49 PM
Tomei Type 80R Review pnig Engine, Exhaust, Transmission 5 05-31-2015 12:15 PM
My BC Racing ER Type coilover review Bodyrollin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-23-2013 06:15 AM
