86WORX
Old 10-15-2015, 04:34 PM   #15
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Originally Posted by churchx View Post
Hmm, wasn't rubbing with very worn engine mounts mentioned in relation to Type A? Shouldn't it be non issue for B-s?
The rubbing has to do with the OP selection, 150/250/350. The Type A vs Type B differences are just the angle of the merges in the 4-2 step down, which results in the Type A being TIG welded and the Type B being MIG welded.
NotSoJDM is offline   Reply With Quote
The Following User Says Thank You to NotSoJDM For This Useful Post:
WRB-DZA-BRZ (03-26-2016)
Old 10-15-2015, 04:34 PM   #16
raven1231
Well, we do have a 2015 WRX R&D car...
I'm listening lol
Old 10-15-2015, 06:06 PM   #17
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
@NotSoJDM did Phantasm tune your car with OFT? I'm in NC and I'm looking for a tuner to do my car with the Type A/350 and OFT. This'll be done once I finish putting in my new engine. If so maybe could you PM me some info about them. Thanks! And awesome job!
JimmyMac is offline   Reply With Quote
Old 10-15-2015, 06:13 PM   #18
NotSoJDM
NotSoJDM's Avatar
Hey Jimmy, I did the tune changes for the ACE header on my car. I just used the facilities at Phantasm to Dyno my car. I'll shoot you a message.
The Following 2 Users Say Thank You to NotSoJDM For This Useful Post:
CSG Mike (10-15-2015), JimmyMac (10-16-2015)
Old 10-16-2015, 10:08 AM   #19
BRZHarley
Drives: 69 Firebird, 2015 BRZ
Man...! I'm so looking forward to this setup for my BRZ....
Ed
BRZHarley is offline   Reply With Quote
The Following User Says Thank You to BRZHarley For This Useful Post:
CSG Mike (10-16-2015)
Old 10-16-2015, 05:14 PM   #20
wparsons
wparsons's Avatar
I thought the difference was that the Type A is all butt joints, while the Type B has slip joints (overlap)? Don't think it really changes the first collector merge angle?
flickr
Old 10-16-2015, 05:31 PM   #21
NotSoJDM
NotSoJDM's Avatar
You'll notice on a Type A the merge is fully TIG welded where as on a Type B the merge is MIG welded. This is due to the change in merge angle.
Type B: - 20 Degree Converging Angle.
^ Reference: http://counterspacegarage.com/ace-mu...-frs-gt86.html
Type A: - 15 Degree Converging Angle.
Old 10-16-2015, 06:30 PM   #22
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
So you are hearing the valve train noise through these headers but not the OFH? I wonder if this is more of a EL header thing than it is a "thin walled tubing" thing, since this noise can also be heard while I was running a Tomei EL.
Intent > Content
Old 10-16-2015, 07:33 PM   #23
bfrank1972
Drives: 2013 FR-S Argento
It's probably a tune thing, are they using OFT stage 2 el canned tune? You hear a lot of valve noise with those tunes.
bfrank1972 is offline   Reply With Quote
Old 10-16-2015, 07:53 PM   #24
solidONE
solidONE's Avatar
Yeah that's also a possibility since the UEL and EL tunes use different cam timing.
Intent > Content
Old 10-18-2015, 02:16 PM   #25
sw20kosh
Drives: 2013 Black FR-S
There is more power left on the table in the tune. My type A 350 makes 150-155 ft lbs from 3k rpm to 7k rpm dynojet on my track map. On dyno queen map it makes 160 ft lbs.
I would suggest having a really good tuner take a good amount of time to really dial in this header. My tuner said he was able to add a resiculous amount of timing over my uel header. The fact that you only added 1 deg makes me think that you have much more left un tapped.
The Following User Says Thank You to sw20kosh For This Useful Post:
solidONE (10-18-2015)
Old 10-18-2015, 03:11 PM   #26
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Unless someone can design a header that will also fit with the factory heat shield. Otherwise it is no go for me.
Muaddib is offline   Reply With Quote
Old 10-18-2015, 04:52 PM   #27
NotSoJDM
NotSoJDM's Avatar
I never invested much in tuning it because I already had my Edelbrock kit on order and made the switch to ECUtek. I agree there was definitely some room left had I had a chance to really invest in the VVT timing.
Old 10-18-2015, 07:07 PM   #28
solidONE
solidONE's Avatar
150tq from 3000?!? That's on E85 I'm assuming. And by timing, you mean ignition timing not cam timing, right? Very impressive.
Intent > Content
Search this Thread:
Advanced Search
PLM Header Review Cross Engine, Exhaust, Transmission 7 05-26-2016 06:46 PM
Driveway Labs Type II Diffuser (PRODUCT REVIEW) Ammonia User/Vendor/Sponsor Reviews, Feedback, Comments 7 08-07-2015 05:49 PM
Tomei Type 80R Review pnig Engine, Exhaust, Transmission 5 05-31-2015 12:15 PM
My BC Racing ER Type coilover review Bodyrollin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-23-2013 06:15 AM
