#15 |
Drives: '13 BRZ | '04 E55
It's stayed pretty much the same. Still shudders low rpm once the clutch gets some heat in it.
#16 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I just got the South Bend stage 2 daily. The shuddering is something you can live with without it being too annoying?
#17 | |
Had I known it would feel like this, I would have just went ahead and gotten something more agressive. Once you get it installed, and broken in, be sure to report back with your experience.
#18 | |
#19 | |
Question: I didn't get the SB flywheel with the clutch kit. I intended to keep using the OEM. I didn't see anything mentioned on their site about needing to use their flywheel. Do you know if it's compatible with OEM or other aftermarket flywheels?
#20 |
Alright so I have the South Bend Stage 2 daily kit installed on my car. I've only driven around 50 miles so take this with a grain of salt. So far, everything is running smooth, shifts are fine, and there is little rattle. I do have it paired with a resurfaced oem flywheel and Velox clutch fork, though. Engagements are smooth, but I don't rev it any higher than 3k RPM. I'll have to see how it feels after around 1,000 as I assume it will be broken in plenty.
I can't accurately comment on the clutch effort as, as it turned out my oem throwout baring had been pressing on the pressure plate teeth, regardless of clutch being depressed or not. So in turn, it made my clutch feel like some sort of crazy aftermarket pressure. Now! Now it feels amazing! Very soft like some others have said. Anyway, that's my take on it for now.
| The Following User Says Thank You to weederr33 For This Useful Post: | botbs (02-19-2021) |
#21 |
Drives: 2015 Halo FR-S
I just installed the stage 2 endurance clutch and have about 100 miles on it. Also have an exedy lightweight chromoly SMF and Edelbrock kit. Also very tame. Have noticed the shuttering you describe but it's pretty minor for me at this point. Super light clutch pedal as described before.
Will update when I finish breaking it in and seating the clutch. So far my biggest difficulty is launching because the engine revs so dang fast now. It's taking some getting used to. |
#22 |
I haven't noticed this shuttering anyone has mentioned....
#23 |
South Bend Stage 2 Daily Update
Ok, so I've been driving with my SB stage 2 daily for a while now, and it's still running like a champ. I've had no issues with it. Clutch peddle feel is soooo soft. I'd say only marginally heavier than stock. I haven't seen any sort of shuddering at low RPMs, nor any signs of slipping when wringing out the engine.
I had a local shop install it and they seem to have done a good job. I didn't change the flywheel, just had the OEM resurfaced. As well, I also have the Velox clutch fork installed (if anyone cares). For now, I don't think I'll hit the torque limit, so longevity should be good. If you're considering a clutch, this is the one I'd recommend.
#24 |
Has anyone noticed a strange chirping sounds with this clutch? As soon as I press on the clutch peddle, it goes away, but while idling it's kinda noisy. I'm guessing it's the TOB?
#25 | |
Drives: Late 2014 Subaru BRZ
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#26 |
A shop did it for me. And I moved recently so... :/ I need to get settled first. Hopefully it isn't anything harmful.
#27 | |
Human
Drives: 2015 BRZ Black
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
| Exedy Stage 1 Clutch (300RWHP) & Lightweight Flywheel - $400 shipped | STS-V | Transmission and Driveline | 8 | 10-04-2014 11:43 PM |
| Competition Clutch Stage 3 clutch and flywheel, who has one and what do you think? | OICU812 | Engine, Exhaust, Transmission | 2 | 05-17-2014 02:56 AM |
| Anyone have a South Bend stage 2 clutch? | Venator | Engine, Exhaust, Transmission | 7 | 04-22-2014 11:01 AM |
| Exedy stage 1 clutch/flyweel - Flywheel weight? | wparsons | Engine, Exhaust, Transmission | 5 | 01-03-2014 12:58 PM |
