#71 | |
Drives: scion frs
Hey sorry just seen this, although the noise does come back once in a while most of the time it's good. So far i noticed when I'm driving the car on higher rpms and stopping is when it mostly comes on. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to zman For This Useful Post: | Ultramaroon (12-25-2015) |
#72 | ||
hey you, yeah you <3
Drives: 2014 37J FR-S
I swapped to Shell and Chevron and its gone. Imo dont worry unless you find problems when accelerating. My 90 pickup does this too on super cheap gas. This one isnt normal. Theres 2 knocks going on. http://www.ft86club.com/forums/showthread.php?t=81496 ^^^cause for concern. Quote:
Also, @BRZnut Op said dealer said it was normal because of fuel pump. Op believes it may be bad gas.
| The Following User Says Thank You to Packofcrows For This Useful Post: | zman (12-25-2015) |
#73 | |
#74 | |
Drives: BRZ DGM Limited
No , mine when it happened sounded like this one: http://www.ft86club.com/forums/showthread.php?t=81496 So, I suspect rocker arms are going, on a babied BRZ with 22K miles! DD, no track, never been above 5K RPM. Ridiculous. Since very intermittent and only after I stop and then restart a fully warmed engine, I am just going to watch and see if it gets worse. If it does, no time or patience to deal with an engine repair. Will just trade it in for a non-Subaru. |
| The Following User Says Thank You to BRZnut For This Useful Post: | zman (12-25-2015) |
#75 | |
Drives: scion frs
Yes like mentioned above it could very well be bad gas. Try switching to shell v power premium. Idk if it really helps but that's what I'm using now. Also I think the dealer was right about the fuel pump thing. Overall most likely not a big deal. Sent from my iPhone using Tapatalk |
#76 | |
If all fails go to dealer.
#77 |
Drives: scion frs
Engine knock
Update: Knock still comes on randomly when the car is idle. Especially when I recently filled up from a different gas station.
I found this video online of the same noise but louder. The owner said they replaced the vacuum pump and it solved the problem. What is the vacuum pumps purpose? Here is the video I found [ame]https://m.youtube.com/watch?v=qIlHnd39iHU[/ame] Sent from my iPhone using Tapatalk |
| Engine Knock sound issue | nos145 | Issues | Warranty | Recalls / TSB | 65 | 10-20-2019 05:57 PM |
| Question about engine knock? | chaoskaze | Engine, Exhaust, Transmission | 12 | 06-09-2016 06:49 PM |
| Cold Engine Knock/Misfire | FR Sports | Engine, Exhaust, Transmission | 2 | 10-02-2015 01:07 AM |
| Is engine knock normal for the FA20? | Cal3000 | Engine, Exhaust, Transmission | 17 | 05-20-2013 02:12 PM |
| anyone experience engine knock on 91 octane? | chenshuo | BRZ First-Gen (2012+) -- General Topics | 15 | 01-13-2013 08:10 PM |
