#15 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
When the gear grinds you need a new transmission fluid! And since you are going to chabe the tranny fluid change the differential fluid too!
#16 | |
![]() Look at the previous threads, you are in there off topic also lol. http://www.ft86club.com/forums/showthread.php?t=59053 http://www.ft86club.com/forums/showthread.php?t=56014 New manual driver. Lots of crunched gears and a year and a half later... OP Take it to the dealer. Or A mechanic. Or a Transmission specialist. Do Something.
#17 |
Drives: 13 Sc10n FR-S
Make sure you have the right fluid in the Trans it takes 75w, not 75w90 or 80w90
Sent from my D6708 using Tapatalk |
#18 | |
![]() If you start listing threads, that I'm off topic in ...... it will be a looooog list ...... ![]() humfrz |
#19 | |
fabulous
| The Following User Says Thank You to Ultramaroon For This Useful Post: | JEDI (10-01-2015) |
#20 |
Ya the repair manual is wrong, I'm a tech for Toyota and that's what I was going to put in when they stopped me and handed me Toyota's special 75w
#21 |
It fixed that problem right away, though truthfully you need a transmission
#22 | |
fabulous
"They" can sound awfully convincing but that doesn't mean they are correct.
#23 |
Sorry don't have any just telling you what Toyota technical assistance told me and had me do. Only thing I can tell you is to go straight to a dealer and ask the parts department, we deal with it all the time
| The Following User Says Thank You to StegaDragon For This Useful Post: | Ultramaroon (09-27-2015) |
#24 |
hey you, yeah you <3
Drives: 2014 37J FR-S
slight grind. Normal very small. Tested 5 twins.
#25 | |
fabulous
![]() Welcome to the forum.
#26 |
Yup will do my best to share and help out, but Ya if it makes anything other than a small clunk type noise when engaging gears you probably need a new one
#27 |
Drives: Pearl White BRZ
Take it to dealership if under warranty they most likely will replace it. Mine got replaced at 30000 miles
#28 |
Drives: 2023 BRZ
Sounds like a warranty issue to me
Director of Rocky Mountain 86CUP
| *UPDATE FROM TOYOTA REP*: Regarding 4th and 5th gear grinding issues... | husker741 | Issues | Warranty | Recalls / TSB | 97 | 08-27-2015 11:46 AM |
| 5th gear grinding | Bernie | Issues | Warranty | Recalls / TSB | 1 | 05-15-2015 08:10 AM |
| 6th gear grinding | D-VO | Issues | Warranty | Recalls / TSB | 59 | 04-07-2015 02:26 PM |
| Grinding in 3rd gear...what's going on?! | hozouria | Engine, Exhaust, Transmission | 3 | 08-13-2014 02:31 PM |
| 6th Gear Grinding | KpAtch3s | Issues | Warranty | Recalls / TSB | 0 | 06-18-2013 08:07 PM |
