go_a_way1
Old 01-18-2017, 08:10 AM   #281
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by AceHeader-MT View Post
Everyone is right!
He's how we decided to do the center exit version first:
1. It went along with the AMB aero package we've been developing
2. We needed to produce a muffler with limited restrictions and meet strict sound requirements
3. We thought it was cool
We're selfish in the fact that we design things to help our factory cars improve first. This is not saying a twin tip version can not be aerodynamically efficient, but we hired Andrew Brilliant to help us and this is what we needed. After that we set about meeting the sound requirements.
Yes, there is more work involved to install a center exit muffler then a standard twin tip. There's also more work involved in installing our 4-2-1 headers because of the OP design. Again, that design was because of our specific track needs.
We're just a small shop full of nerds.
For the same reason Prego has 50 flavors of tomato sauce, there are 50 different kinds of exhaust systems. Not everyone like extra chunky...
Thanks for the support everyone and we'll keep updates coming regarding the twin tip version after the holiday.
Happy Driving
Ace Header
I hadn't realized there was an aero component to the center exit design.
My apologies.
How much of a difference are you seeing in cd between the center exit and twin exit?
The Following User Says Thank You to Calum For This Useful Post:
Silverfox (01-18-2017)
Old 01-18-2017, 08:39 AM   #282
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
My apologies.
No apologies necessary. We will have both versions soon and this discussion will be a thing of the past
I can't say exactly what kind of benefits the center has over the twin tip. We have spent a lot of time on the under-car aero and this design fit our needs (for the time being). With this kind of aero project we just listen to the pros, smile and nod.
Disclaimer- To those considering this center exit for aero purposes, be aware that we have a custom designed aero package. A single component by itself may or may not make a huge difference. Each piece is a collective part of the entire car.
AceHeader-MT is offline   Reply With Quote
The Following 9 Users Say Thank You to AceHeader-MT For This Useful Post:
Calum (01-18-2017), Cole (02-06-2017), CSG Mike (01-19-2017), DAEMANO (02-06-2017), Hawk77FT (02-22-2017), Jmonty (01-19-2017), Jonsey (01-18-2017), Reamer (02-04-2017), Silverfox (01-18-2017)
Old 02-04-2017, 11:30 AM   #283
Reamer
Drives: 2015 FRS
Doesn't all of the aero purposes go out the window when you add a diffuser? I'm going with the center exit for aesthetics, but it does take a little more work to look 'right' for the street over the dual tip design so I don't blame people for waiting on that. I installed the Diode Dynamics Turn as Tail kit last week and I have 2 exhaust hole covers ready to go on when the center exit installed, then I'm thinking a Driveway Labs Type 2 diffuser to eliminate any concerns about the 'parachute' effect with the stock bumper. Hopefully it'll be as clean and functional as I'm picturing without going through the work of cutting the bumper and doing something custom.
Reamer is offline   Reply With Quote
Old 02-04-2017, 12:29 PM   #284
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
I've gone a similar route with the turn as tails, exhaust hole covers but with with the Velox diffuser
Jmonty is offline   Reply With Quote
Old 02-06-2017, 12:34 AM   #285
Reamer
Drives: 2015 FRS
I've kinda been jumping back and forth between velox and driveway labs. I think if I was going to keep the dual exit design I would go with velox, but I like that driveway labs is constant across the back without the "cut outs" that velox has for a typical exhaust.
Sent from my HTC 10 using Tapatalk
The Following User Says Thank You to Reamer For This Useful Post:
Jmonty (02-07-2017)
Old 02-06-2017, 04:55 AM   #286
churchx
churchx's Avatar
Drives: 2014 GT86
Best center exhaust looks are for DAMD rear bumper/center exhaust imho
Old 02-06-2017, 07:52 AM   #287
Reamer
Drives: 2015 FRS
Are you trolling? Lol.
Sent from my Pixel using Tapatalk
Old 02-06-2017, 08:51 AM   #288
churchx
churchx's Avatar
Drives: 2014 GT86
Nope. I really like looks-wise damd/prova rear bumper/diffuser w. center exhaust. I guess, depending on exit tips type used maybe it can be used even with this Ace's exhaust. No clue though, how it will work together if one throws also some real diffuser into picture.
The Following 2 Users Say Thank You to churchx For This Useful Post:
Overdrive (02-06-2017), Reamer (02-06-2017)
Old 02-07-2017, 12:13 AM   #289
Jmonty
Back and forth I was too on the Driveway Labs, can't wait to get some install pictures when the Ace gets shipped
The Following User Says Thank You to Jmonty For This Useful Post:
Reamer (02-07-2017)
Old 02-08-2017, 01:04 AM   #290
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I like this exhaust. If I weren't going to a fully custom center exit design I came up with specifically for a highly efficient diffusor I'm also making, and needed to meet tight sound regulations, then it would be exactly what I'd want.
Personally I've never liked the rear 'diffusor' with twin exhaust cutouts on the FR-S... my temporary solution, spurred on by an aftermarket exhaust melting the passenger side cutout was this:
GET RID OF THE STUPID FAKE FACTORY 'DIFFUSOR'.
Cutting it out helped to bring more stability at high speeds too...was more unsettled than stock with the rear plastic in place without a stock type muffler. Eventually, once I get the custom exhaust mocked up then fabbed there will be a custom diffusor in store - like that of the TRD Griffon. Almost all of the premade diffusor solutions still use the stock 'diffusor'....meaning they won't be as efficient as a complete solution designed around a low profile center exit race exhaust that allows you to get rid of that factory nonsense.
The Diode Dynamic Tail as Turn module works great for reverse, especially with the XP80 LED bulbs. Way better than stock, which is pretty useless as a reverse light other than as an indication to others that you are in reverse.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 2 Users Say Thank You to Vracer111 For This Useful Post:
Reamer (02-08-2017), Silverfox (02-08-2017)
Old 02-11-2017, 02:39 PM   #291
Jmonty
The wait i hope is close to being over, late Christmas gift to myself
Old 02-13-2017, 11:14 PM   #292
Nab33
Drives: 2018 BRZ tS
Pm sent
Nab33 is offline   Reply With Quote
Old 02-21-2017, 02:55 AM   #293
AceHeader-MT
Drives: 2012 FR-S
Production is up and running and kits are finally being shipped
You can check out details here: http://aceheader.com/index.php/produ...-system-detail
The Following 8 Users Say Thank You to AceHeader-MT For This Useful Post:
churchx (02-21-2017), gramicci101 (02-21-2017), MaximeT (02-21-2017), new2subaru (02-21-2017), Reamer (02-21-2017), Silverfox (02-21-2017), TkTk (02-21-2017), Ultramaroon (02-21-2017)
Old 02-21-2017, 02:58 AM   #294
AceHeader-MT
Drives: 2012 FR-S
We also have completed a "straight pipe" version with no muffler that will be track tested on the 22nd of Feb and another kit is on it's way to Qatar for more feedback
This version measured 103db at tailpipe at 6,000rpm using complete catless Ace system with just resonated mid-pipe
No packing material, because Smooth is Fast
This kit is not on website yet but cost will be $559
[ame="https://www.youtube.com/watch?v=hFHoxkhnsEM"]Ace Laguna Unlimited catback exhaust for BRZ GT86 - YouTube[/ame]
The Following 6 Users Say Thank You to AceHeader-MT For This Useful Post:
churchx (02-21-2017), Iceman (02-22-2017), Pat (02-21-2017), Plxdjake89 (02-23-2017), Silverfox (02-21-2017), TkTk (02-21-2017)
Search this Thread:
Advanced Search
FNA rear fog light Kit 1 w/high power LED HATED1 Exterior Parts (Aero, Lighting, Etc.) 5 02-09-2015 05:31 AM
HKS High Power Spec-L Ti-Tip Tien Engine, Exhaust, Transmission 0 10-24-2013 12:54 AM
Mach V muffler delete prototype Mach V Dan Engine, Exhaust, Transmission 118 02-01-2013 08:41 AM
5W High Power CREE LED Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 0 09-21-2012 07:30 PM
