Old 06-06-2016, 10:27 PM   #197
zeal86
zeal86's Avatar
Drives:
Originally Posted by sroby View Post
Zeal, I am so impressed with your polished Hks system, Just spoke with Torry ,I will probably have my unit for my 2015 hopefully by the end of July. Can you give me your technique at stages of polishing. I would like to mirror your setup. As it is probably one of the best looking I have ever seen, and being a retired Air Force Msgt. I worked F_15,s for 10 yrs and C-130,s for 14 yrs. I am used to perfection around the aircraft and for me yours is right there. look forward to taking my time and trying to get to your level. Best Regards Steve
Thanks for the props. Polishing the cast cast aluminum was some work but well worth it in the end... Definitely will set your HKS SC kit as well as your engine bay apart.
If you start reading my build thread beginning at this point you can read and see the steps I took. I bought my polishing wheels and rouges at Harbor Freight.
I also am former Air Force... Com/Nav on Pavelows for 6 years before cross-training to VI. I currently work on C550s and A-Stars.
I'll PM you my number if you have any questions while you are polishing and or installing your HKS v3 supercharger kit. Go AF!
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
Old 06-07-2016, 01:31 PM   #198
Acuradc5boy
Drives: Red frs
I have a question about this kit. I know it is available with a tune from hks but was wondering if going with the non ecu package and buying a ecutrek would be a better choice. I am looking to get closer to 300 whp.
Acuradc5boy is offline   Reply With Quote
Old 06-07-2016, 02:07 PM   #199
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
I may be a little biased, since I work for HKS, but I don't see any reason not to choose the HKS tune, since it it unbelievably simple to use and is cheaper than any of the other tune options from other companies.
Torry@HKSUSA is offline   Reply With Quote
Old 06-07-2016, 02:54 PM   #200
wbradley
Sarcastic SOB
wbradley's Avatar
Going Ecutek will probably result in another $800 to $1000 overall cost vs. canned tune. For your money, the tune will be calibrated to your particular car's hardware configuration, exhaust, restrictor size etc etc.
From a good tuner I'd say the custom tune will always yield the best results. It's a question of having availability of a good tuner, dyno tuned locally as well as being willing to spend the difference. I am not sure a remote e-tune can consistently provide the best outcome, or if so, with extra work and trial and error on the car owner's part sending back and forth data logs.
Old 06-11-2016, 03:44 PM   #201
Koj
Koj's Avatar
Drives: Toyota GT86
nice job with that polishing ;-)
@jackblack21
With the HKS kit, you need :
- an oil cooler
- an oil Temp jauge & Oil Pressure Jauge.
- a new Omnipower flowmeter / air flow sensor 3 bar
- bigger wheel because 215 is too short, unless you want to drift at all red light
- better brake pad & brake plate
- etc..
You can check my config is need more advice.
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more...
My Journal/Garage
Koj is offline   Reply With Quote
The Following User Says Thank You to Koj For This Useful Post:
zeal86 (06-11-2016)
Old 06-11-2016, 04:03 PM   #202
wbradley
Sarcastic SOB
wbradley's Avatar
@jackblack21
- an oil cooler
- etc..
2.5 bar MAP will do as well.
Torque can be set up for oil temp. Provided oil level is good and not over approx 125C you dont need a pressure gauge. Need heavier oil though. Agreed upgrade pads and fluid or just wear thru brakes quickly.
Old 06-12-2016, 08:26 AM   #203
Koj
Koj's Avatar
Drives: Toyota GT86
@wbradley an oil pressure gauge will show you that when the engine is cold, you can reach 7 bars (100 PSI) and you have to take care of your engine when you start at a red lite instead of doing "i'm the best" and reach 9 bars... help your rod bearing shell.
And with an alarm (it will beep when lower than 1 bar), you can prevent an oil leak and an engine damage.
I installed an oil pressure jauge when no one wanted to install an oil pressure jauge in France. Now I m so happy to have one, I dont regret my 100€ : A better investment than the stickers.
Koj
My Journal/Garage
wbradley (06-15-2016)
Old 06-14-2016, 08:05 PM   #204
pancake
Drives: 2015 BRZ Limited MT
Does this kit make any of them sexy supercharger noises? or is it relatively quiet?
pancake is offline   Reply With Quote
Old 06-14-2016, 08:59 PM   #205
Apex-Apex
Apex-Apex's Avatar
It's a rotrex based sc so it's on the quiet end.
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 06-14-2016, 10:52 PM   #206
pancake
can you vent to atmosphere? whether on stock bypass or with aftermarket BOV?
Old 06-14-2016, 11:20 PM   #207
Apex-Apex
Apex-Apex's Avatar
There's a bypass but I'm not sure about if you can fit aftermarket. The SC isn't completely quiet but it's definitely quiet compared to a Roots per se.
IG: @apexapexapex
Old 06-15-2016, 02:16 AM   #208
Shinra Inc
Shinra Inc's Avatar
Drives: Tiny Bronco
Hmm. My brz is a 2015 model, however my ecu id is ZA1JD00C which is on their list of confirmed ecu codes. Is there something else with my car that would make it incompatible being a 2015?
Also I have an ecutek tune on my car now. would the flash editor be able to overwrite it?
Shinra Inc is offline   Reply With Quote
Old 06-15-2016, 09:07 AM   #209
Torry@HKSUSA
Drives: HKS
That's because we just added your ECU ID to the website yesterday
We are making the announcement later today for confirmed fitment through 2016 with the Flash Editor.
However, the Flash Editor is *not* able to overwrite the Ecutek flash. You must be running a stock ROM to use the HKS FE.
Old 06-15-2016, 02:55 PM   #210
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Has anyone done a BOV on this kit?
HuntingtonFRS is offline   Reply With Quote
supercharger help... sosick Forced Induction 25 08-16-2013 12:02 AM
HKS GT Supercharger Evasive Motorsports Forced Induction 48 02-08-2013 07:21 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 11:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 11:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 04:11 PM
